引用: muuwfwr 发表于 2018-8-30 14:26
你好,
这些驱动程序文件已签署-
http://www.cypress.com/documentation/software-and-drivers/microsoft-certified-u***-uart-driver
你好,
谢谢你的回复。
但这不管用。当我安装了CyWINCDC.INF,我从你提到的链接下载,Windows找不到驱动程序。
当我安装我自己的驱动程序是从项目自动生成的,它需要在Windows 10的签名。我还尝试下载最新的PSoC创建者4.2并更新所有组件并重新合成,重新编译以生成UsBuTARTH.CDC.IF。但问题仍然存在。
期待您的回复。先谢谢你。
春燕
以上来自于百度翻译
以下为原文
Hello,
Thank you for your reply.
but this doesn't work. when I install CyWinCDC.inf which I downloaded from the link you mentioned, windows can't find the driver.
when I install my own driver that is auto generated from project, it need the signature on windows 10.. I also tried to download latest psoc creator 4.2 and update all the component and re-synthesis, re-compile again to generate USBUART_CDC.inf. but the issue is still there.
looking forward to your reply. thank you in advance.
Chunyan
你好,
这些驱动程序文件已签署-
你好,
谢谢你的回复。
期待您的回复。先谢谢你。
春燕
以上来自于百度翻译
以下为原文
Hello,
Chunyan
举报
