Eric,
我的中断设置检查过了,接收中断是一致的,发送我用的是定时发送,但是进不了接收中断,现在我把程序改成用FIFO接收一个字就进入中断仿真就可以了,程序初始化设置如下:
SciaRegs.SCICCR.all =0x0007; // 1 stop bit, No loopback
// No parity,8 char bits,
// async mode, idle-line protocol
SciaRegs.SCICTL1.all =0x0003; // enable TX, RX, internal SCICLK,
// Disable RX ERR, SLEEP, TXWAKE
SciaRegs.SCICTL2.bit.TXINTENA =0;
SciaRegs.SCICTL2.bit.RXBKINTENA =1;
SciaRegs.SCIHBAUD = 0x01;
SciaRegs.SCILBAUD = 0x03; //baudrate set 9600
SciaRegs.SCIFFTX.all=0xC041;
SciaRegs.SCIFFRX.all=0x0021;
SciaRegs.SCIFFCT.all=0x00;
SciaRegs.SCICTL1.all =0x0023; // Relinquish SCI from Reset
SciaRegs.SCIFFTX.bit.TXFIFOXRESET=1;
SciaRegs.SCIFFRX.bit.RXFIFORESET=1;
中断设置为:
EALLOW;
PieVectTable.TINT0 = &cpu_timer0_isr;
PieVectTable.SCIRXINTA = &sciaRxIsr;
EDIS;
PieCtrlRegs.PIECTRL.bit.ENPIE = 1; // Enable the PIE block
PieCtrlRegs.PIEIER9.bit.INTx1=1; // PIE Group 9, INT3 SCIATINT
IER = 0x100; // Enable CPU INT
//使能全局中断
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global real time interrupt DBGM
Eric,
中断设置为:
EALLOW;
EDIS;
//使能全局中断
举报
