// sending packet
iStatus = sl_Send(iSockID, g_cBsdBuf, sTestBufLen, 0 ); 发送函数
1000指的是1000包数据
程序部分了做备注,参考
//! brief Opening a TCP client side socket and sending data
//! This function opens a TCP socket and tries to connect to a Server IP_ADDR
//! waiting on port PORT_NUM.
//! If the socket connection is successful then the function will send 1000
//! TCP packets to the server.
//! param[in] port number on which the server will be listening on
//! return 0 on success, -1 on Error.
int BsdTcpClient(unsigned short usPort)
int iCounter;
short sTestBufLen;
SlSockAddrIn_t sAddr;
int iAddrSize;
int iSockID;
int iStatus;
long lLoopCount = 0;
// filling the buffer
for (iCounter=0 ; iCounter
g_cBsdBuf[iCounter] = (char)(iCounter % 10);
sTestBufLen = BUF_SIZE;
//filling the TCP server socket address
sAddr.sin_family = SL_AF_INET;
sAddr.sin_port = sl_Htons((unsigned short)usPort); //目的IP地址端口号
sAddr.sin_addr.s_addr = sl_Htonl((unsigned int)g_ulDestinationIp); //目的IP地址IP_ADDR-手机上连接USR软件后配置TCP Server设置端口号并查看本机IP地址
iAddrSize = sizeof(SlSockAddrIn_t);
// creating a TCP socket
iSockID = sl_Socket(SL_AF_INET,SL_SOCK_STREAM, 0);
if( iSockID < 0 )
ASSERT_ON_ERROR(SOCKET_CREATE_ERROR);
// connecting to TCP server
iStatus = sl_Connect(iSockID, ( SlSockAddr_t *)&sAddr, iAddrSize); //<连接>目的IP地址及端口号
if( iStatus < 0 )
// error
sl_Close(iSockID);
ASSERT_ON_ERROR(CONNECT_ERROR);
// sending multiple packets to the TCP server
while (lLoopCount < g_ulPacketCount)
// sending packet
if( iStatus < 0 )
// error
sl_Close(iSockID);
ASSERT_ON_ERROR(SEND_ERROR);
lLoopCount++;
Report("Sent %u packets successfullynr",g_ulPacketCount);
iStatus = sl_Close(iSockID);
//closing the socket after sending 1000 packets
ASSERT_ON_ERROR(iStatus);
return SUCCESS;
//! brief Opening a TCP server side socket and receiving data
//! This function opens a TCP socket in Listen mode and waits for an incoming
//! TCP connection.
//! If a socket connection is established then the function will try to read
//! 1000 TCP packets from the connected client.
//! return 0 on success, -1 on error.
//! note This function will wait for an incoming connection till
//! one is established
int BsdTcpServer(unsigned short usPort)
SlSockAddrIn_t sLocalAddr;
int iCounter;
int iAddrSize;
int iSockID;
int iStatus;
int iNewSockID;
long lNonBlocking = 1;
int iTestBufLen;
iTestBufLen = BUF_SIZE;
sLocalAddr.sin_family = SL_AF_INET;
sLocalAddr.sin_port = sl_Htons((unsigned short)usPort); //仅用到本机IP的端口号即可
sLocalAddr.sin_addr.s_addr = 0; //建立TCP服务器时忽略本机IP地址
if( iSockID < 0 )
// error
// binding the TCP socket to the TCP server address
iStatus = sl_Bind(iSockID, (SlSockAddr_t *)&sLocalAddr, iAddrSize); //绑定该TCP socket
if( iStatus < 0 )
// error
sl_Close(iSockID);
ASSERT_ON_ERROR(BIND_ERROR);
// putting the socket for listening to the incoming TCP connection
iStatus = sl_Listen(iSockID, 0); //开始监听TCP连接
if( iStatus < 0 )
sl_Close(iSockID);
ASSERT_ON_ERROR(LISTEN_ERROR);
// setting socket option to make the socket as non blocking
iStatus = sl_SetSockOpt(iSockID, SL_SOL_SOCKET, SL_SO_NONBLOCKING, &lNonBlocking, sizeof(lNonBlocking)); //设置为非阻塞模式
if( iStatus < 0 )
sl_Close(iSockID);
ASSERT_ON_ERROR(SOCKET_OPT_ERROR);
iNewSockID = SL_EAGAIN;
// waiting for an incoming TCP connection
while( iNewSockID < 0 )
// accepts a connection form a TCP client, if there is any
// otherwise returns SL_EAGAIN
iNewSockID = sl_Accept(iSockID, ( struct SlSockAddr_t *)&sAddr, (SlSocklen_t*)&iAddrSize);
if( iNewSockID == SL_EAGAIN )
MAP_UtilsDelay(10000);
else if( iNewSockID < 0 )
// error
sl_Close(iNewSockID);
sl_Close(iSockID);
ASSERT_ON_ERROR(ACCEPT_ERROR);
// waits for 1000 packets from the connected TCP client
iStatus = sl_Recv(iNewSockID, g_cBsdBuf, iTestBufLen, 0);
if( iStatus <= 0 )
// error
sl_Close(iSockID);
ASSERT_ON_ERROR(RECV_ERROR);
lLoopCount++;
Report("Recieved %u packets successfullynr",g_ulPacketCount);
// close the connected socket after receiving from connected TCP client
iStatus = sl_Close(iNewSockID);
// close the listening socket
return SUCCESS;
//! brief Connecting to a WLAN Accesspoint
//! This function connects to the required AP (SSID_NAME) with Security
//! parameters specified in te form of macros at the top of this file
//! param[in] None
//! return Status value
//! warning If the WLAN connection fails or we don't aquire an IP
//! address, It will be stuck in this function forever.
static long WlanConnect()
SlSecParams_t secParams = [0];
long lRetVal = 0;
secParams.Key = (signed char*)SECURITY_KEY;
secParams.KeyLen = strlen(SECURITY_KEY);
secParams.Type = SECURITY_TYPE;
lRetVal = sl_WlanConnect((signed char*)SSID_NAME, strlen(SSID_NAME), 0, &secParams, 0);
ASSERT_ON_ERROR(lRetVal);
/* Wait */
while((!IS_CONNECTED(g_ulStatus)) || (!IS_IP_ACQUIRED(g_ulStatus))) //还是要在这等待网络事件产生!
// Wait for WLAN Event
#ifndef SL_PLATFORM_MULTI_THREADED
_SlNonOsMainLoopTask();
#endif
return SUCCESS;
//! Application startup display on UART
//! param none
//! return none
static void
DisplayBanner(char * AppName)
Report("nnnr");
Report("tt *************************************************nr");
Report("tt CC3200 %s Application nr", AppName);
Report("nnnr");
//! Board Initialization & Configuration
//! param None
//! return None
static void
BoardInit(void)
/* In case of TI-RTOS vector table is initialize by OS itself */
#ifndef USE_TIRTOS
// Set vector table base
#if defined(ccs) || defined (gcc)
MAP_IntVTableBaseSet((unsigned long)&g_pfnVectors[0]);
#endif
#if defined(ewarm)
MAP_IntVTableBaseSet((unsigned long)&__vector_table);
#endif
#endif
// Enable Processor
MAP_IntMasterEnable();
MAP_IntEnable(FAULT_SYSTICK);
PRCMCC3200MCUInit();
// MAIN FUNCTION
void main()
long lRetVal = -1;
// Board Initialization
BoardInit();
// Initialize the uDMA
UDMAInit();
// Configure the pinmux settings for the peripherals exercised
PinMuxConfig();
// Configuring UART
InitTerm();
// Display banner
DisplayBanner(APPLICATION_NAME);
InitializeAppVariables();
// Following function configure the device to default state by cleaning
// the persistent settings stored in NVMEM (viz. connection profiles &
// policies, power policy etc)
// Applications may choose to skip this step if the developer is sure
// that the device is in its default state at start of applicaton
// Note that all profiles and persistent settings that were done on the
// device will be lost
lRetVal = ConfigureSimpleLinkToDefaultState();
if(lRetVal < 0)
if (DEVICE_NOT_IN_STATION_MODE == lRetVal)
UART_PRINT("Failed to configure the device in its default state nr");
LOOP_FOREVER();
UART_PRINT("Device is configured in default state nr");
// Asumption is that the device is configured in station mode already
// and it is in its default state
lRetVal = sl_Start(0, 0, 0);
if (lRetVal < 0)
UART_PRINT("Failed to start the device nr");
LOOP_FOREVER();
UART_PRINT("Device started as STATION nr");
UART_PRINT("Connecting to AP: %s ...rn",SSID_NAME);
// Connecting to WLAN AP - Set with static parameters defined at common.h
// After this call we will be connected and have IP address
lRetVal = WlanConnect();
if(lRetVal < 0)
UART_PRINT("Connection to AP failed nr");
LOOP_FOREVER();
UART_PRINT("Connected to AP: %s nr",SSID_NAME);
UART_PRINT("Device IP: %d.%d.%d.%dnrnr",
SL_IPV4_BYTE(g_ulIpAddr,3),
SL_IPV4_BYTE(g_ulIpAddr,2),
SL_IPV4_BYTE(g_ulIpAddr,1),
SL_IPV4_BYTE(g_ulIpAddr,0));
#ifdef USER_INPUT_ENABLE //定义了USER_INPUT_ENABLE
lRetVal = UserInput();
if(lRetVal < 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
#else //不执行
lRetVal = BsdTcpClient(PORT_NUM); //建立CC3200-TCP Client并向目的IP及端口号5001发送TCP数据
if(lRetVal < 0)
UART_PRINT("TCP Client failednr");
LOOP_FOREVER();
lRetVal = BsdTcpServer(PORT_NUM); //建立TCP Server 等待连接并接收数据
if(lRetVal < 0)
UART_PRINT("TCP Server failednr");
LOOP_FOREVER();
#endif
UART_PRINT("Exiting Application ...nr");
// power of the Network processor
lRetVal = sl_Stop(SL_STOP_TIMEOUT);
while (1)
// sending packet
1000指的是1000包数据
程序部分了做备注,参考
int iCounter;
short sTestBufLen;
int iAddrSize;
int iSockID;
int iStatus;
if( iSockID < 0 )
if( iStatus < 0 )
// error
sl_Close(iSockID);
// sending packet
if( iStatus < 0 )
// error
sl_Close(iSockID);
lLoopCount++;
return SUCCESS;
//! TCP connection.
int iCounter;
int iAddrSize;
int iSockID;
int iStatus;
int iNewSockID;
int iTestBufLen;
if( iSockID < 0 )
// error
if( iStatus < 0 )
// error
sl_Close(iSockID);
if( iStatus < 0 )
sl_Close(iSockID);
if( iStatus < 0 )
sl_Close(iSockID);
// error
sl_Close(iSockID);
if( iStatus <= 0 )
// error
sl_Close(iSockID);
lLoopCount++;
return SUCCESS;
//! param[in] None
long lRetVal = 0;
/* Wait */
#endif
return SUCCESS;
//! param none
//! return none
static void
Report("nnnr");
Report("nnnr");
//! param None
//! return None
static void
BoardInit(void)
#ifndef USE_TIRTOS
#endif
#if defined(ewarm)
#endif
#endif
// Enable Processor
// MAIN FUNCTION
void main()
long lRetVal = -1;
BoardInit();
UDMAInit();
PinMuxConfig();
// Configuring UART
InitTerm();
// Display banner
if(lRetVal < 0)
LOOP_FOREVER();
if (lRetVal < 0)
LOOP_FOREVER();
if(lRetVal < 0)
LOOP_FOREVER();
if(lRetVal < 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
#else //不执行
if(lRetVal < 0)
LOOP_FOREVER();
if(lRetVal < 0)
LOOP_FOREVER();
#endif
while (1)
举报
