电子发烧友论坛|
段码液晶屏驱动程序。很多客户在初次使用段码液晶屏的时候,总问我有没有可以参考的C语言驱动程序。因为驱动IC有很多,这里就以驱动IC HT1621,驰宇微CYW-D327段码液晶屏为例,做一个参考程序。
/*IC :HT1621*/ #include #include #include #define uchar unsigned char #define uint unsigned int //----------------------------------------------------------------------------- ***it DATAB =P3^7; ***it WRB =P3^6; ***it CSB =P2^7; //uchar zz; //Control the program to run #define BIAS 0x52 /*定义1 3 偏压4 背极*/ #define XTAL32 0x28 /*使用外部晶振*/ #define RC256 0x30 /*使用内部256KRC 振荡器*/ #define SYSEN 0x02 /*打开振荡发生器*/ #define LCDON 0x06 /*打开LCD*/ #define SYSDIS 0x00 /*关闭振荡发生器*/ #define LCDOFF 0x04 /*显示关闭*/ #define TONE4 0x80 /*设置BZ 输出频率为4K*/ #define TONEON 0x12 /*打开BZ 音频输出*/ #define TONEOFF 0x10 /*关闭BZ 音频输出*/ #define CLRWDT 0x1c /*清零WDT*/ #define IRQEN 0x10 /*IRQ 输出禁止*/ #define IRQDIS 0x00 /*IRQ 输出允许*/ #define WDTEN 0x0e /*打开WDT*/ #define WDTDIS 0x0a /*关闭WDT*/ #define tiMERDIS 0x08 /*关闭时基输出*/ //----------------------------------------------------------------------------- uchar code TAB0[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,}; uchar code TAB1[]={0xda,0x3c,0x83,0xc8,0x3c,0x83,0xc8,0x3c,0x83,0xc8,0x3b,0x96,0x4f,0x35,0xd3,0xfb,}; uchar code TAB2[]={0x3a,0xa5,0x8a,0x58,0xa5,0x8a,0x58,0xa5,0x8a,0x58,0xa4,0x69,0xbf,0xdb,0xdd,0xf7,}; uchar code TAB3[]={0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf0,0x00,0x6f,0x76,0xf7,0x13,}; //----------------------------------------------------------------------------- void delay_us(uchar us_value) //delay about 1 us { while(us_value--) { _nop_(); _nop_(); _nop_(); } } //----------------------------------------------------------------------------- void delay_ms(uint ms_value) //delay about 1 ms { uint k; for(k=0;k delay_us(200); } } //----------------------------------------------------------------------------- void init_cpu() //Initial 89C52 { P0=0xff; P1=0xff; P2=0xff; P3=0xff; } //----------------------------------------------------------------------------- void wr_cmd(uchar x) { uchar i,j=0x80; CSB=0; _nop_(); _nop_(); for(i=0;i<4;i++) { if(j&0x80) DATAB=1; else DATAB=0; WRB=0; _nop_(); _nop_(); WRB=1; _nop_(); j<<=1; } for(i=0;i<8;i++) { if(x&0x80) DATAB=1; else DATAB=0; WRB=0; _nop_(); _nop_(); WRB=1; _nop_(); x<<=1; } CSB=1; _nop_(); _nop_(); } //----------------------------------------------------------------------------- void wr_add(uchar y) { uchar i,j=0xa0; for(i=0;i<3;i++) { if(j&0x80) DATAB=1; else DATAB=0; WRB=0; _nop_(); _nop_(); WRB=1; _nop_(); j<<=1; } y<<=2; for(i=0;i<6;i++) { if(y&0x80) DATAB=1; else DATAB=0; WRB=0; _nop_(); _nop_(); WRB=1; _nop_(); y<<=1; } } //----------------------------------------------------------------------------- void wr_byte(uchar z) { uchar i; for(i=0;i<8;i++) { if(z&0x80) DATAB=1; else DATAB=0; WRB=0; _nop_(); _nop_(); WRB=1; _nop_(); z<<=1; } } //----------------------------------------------------------------------------- //----------------------------------------------------------------------------- void disp_all() { uchar i; CSB=0; wr_add(0); for(i=0;i<16;i++) { wr_byte(0xff); } CSB=1; } //----------------------------------------------------------------------------- void disp_off() { uchar i; CSB=0; wr_add(0); for(i=0;i<16;i++) { wr_byte(0x00); } CSB=1; } //----------------------------------------------------------------------------- void disp_bm0() { uchar i; CSB=0; wr_add(0); for(i=0;i<16;i++) { wr_byte(TAB0); } CSB=1; } //----------------------------------------------------------------------------- void disp_bm1() { uchar i; CSB=0; wr_add(0); for(i=0;i<16;i++) { wr_byte(TAB1); } CSB=1; } //----------------------------------------------------------------------------- void disp_bm2() { uchar i; CSB=0; wr_add(0); for(i=0;i<16;i++) { wr_byte(TAB2); } CSB=1; } //----------------------------------------------------------------------------- void disp_bm3() { uchar i; CSB=0; wr_add(0); for(i=0;i<16;i++) { wr_byte(TAB3); } CSB=1; } //----------------------------------------------------------------------------- void init_lcd() { CSB=1; WRB=0; DATAB=1; delay_ms(100); wr_cmd(BIAS); wr_cmd(SYSEN); wr_cmd(TIMERDIS); wr_cmd(LCDON); delay_ms(10); } //----------------------------------------------------------------------------- //----------------------------------------------------------------------------- void main(void) { init_cpu(); init_lcd(); while(1) { disp_all(); delay_ms(500); disp_bm0(); delay_ms(500); disp_bm1(); delay_ms(500); disp_bm2(); delay_ms(500); disp_bm3(); delay_ms(500); disp_off(); delay_ms(300); } } |
12 个讨论
只有小组成员才能发言,加入小组>>
3615 浏览 3 评论
1851 浏览 3 评论
5248 浏览 1 评论
2410 浏览 1 评论
3616 浏览 2 评论
/9
GMT+8, 2025-12-2 15:01 , Processed in 1.024530 second(s), Total 73, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
29897
