根据宋宝华的《Linux设备驱动开发详解》,第六章字符设备驱动,我改写了,添加了自动创建设备的部分代码。
问题出来了,导致cat /dev/globalfifo* 循环显示???不知道为什么????
- * [url=home.php?mod=space&uid=1455510]@file[/url] globalfifo.c
- * [url=home.php?mod=space&uid=40524]@author[/url] yang yongsheng
- * @date 2016.10.17
- #include
- #include
- #include
- #include // Required for the GPIO functions
- #include
- #include
- #include
- #include
- #include
- #include
- #include
- MODULE_LICENSE("GPL");
- MODULE_AUTHOR("yang yongsheng");
- MODULE_DESCRIPTION("A fifo test driver for the BBB");
- MODULE_VERSION("0.1");
- #define GLOBALFIFO_SIZE 64
- #define NAME_SIZE 16
- #define GLOBALFIFO_NUM 3
- #define GLOBALFIFO_MAGIC 'f'
- #define MEM_CLEAR _IO(GLOBALFIFO_MAGIC,0)
- static int major = 0;
- static dev_t devnum;
- struct globalfifo_dev{
- struct cdev cdev;
- int cur_len;
- char mem[GLOBALFIFO_SIZE];
- struct mutex mutex;
- wait_queue_head_t r_wait;
- wait_queue_head_t w_wait;
- struct globalfifo_dev *globalfifo_devp;
- static struct class *globalfifo_class;
- static struct device *globalfifo_device[GLOBALFIFO_NUM];
- static int globalfifo_open(struct inode *inode, struct file *filp)
- struct globalfifo_dev *globalfifo_devp_tmp = container_of(inode->i_cdev, struct globalfifo_dev, cdev);
- filp->private_data = globalfifo_devp_tmp;
- return 0;
- static ssize_t globalfifo_read(struct file *filp, char __user *buf, size_t count, loff_t *ppos)
- int ret = 0;
- unsigned long p = *ppos;
- unsigned int size = count;
- struct globalfifo_dev *devp_tmp = filp->private_data;
- if(p >= GLOBALFIFO_SIZE)
- printk("buf longer than sizen");
- return 0;
- if(size > GLOBALFIFO_SIZE - p)
- size = GLOBALFIFO_SIZE - p;
- if(copy_to_user(buf, devp_tmp->mem + p, size))
- ret = -EFAULT;
- else
- ret = size;
- printk(KERN_INFO "read %u bytes from %lu", size, p);
- return ret;
- static ssize_t globalfifo_write (struct file *filp, const char __user *buf, size_t count, loff_t *ppos)
- int ret = 0;
- struct globalfifo_dev * devp_tmp = filp->private_data;
- if(p > GLOBALFIFO_SIZE)
- printk("buf longer than size.n");
- return 0;
- if(copy_from_user(devp_tmp->mem + p, buf, size))
- ret = -EFAULT;
- else
- *ppos += size;
- ret = size;
- printk(KERN_INFO "written %u bytes from %lu", size, p);
- return ret;
- static loff_t globalfifo_llseek (struct file *filp,loff_t offset,int orig)
- loff_t ret = 0;
- switch(orig)
- case 0:
- if(offset < 0)
- ret = -EINVAL;
- break;
- if((unsigned int)offset > GLOBALFIFO_SIZE)
- ret = -EINVAL;
- break;
- filp->f_pos = (unsigned int)offset;
- ret = filp->f_pos;
- break;
- case 1:
- if((filp->f_pos + offset) > GLOBALFIFO_SIZE)
- ret = -EINVAL;
- break;
- ret = -EINVAL;
- break;
- filp->f_pos += offset;
- break;
- default:
- ret = -EINVAL;
- break;
- return ret;
- static long globalfifo_ioctl(struct file *filp,unsigned int cmd,unsigned long arg)
- switch(cmd)
- //case MEM_CLEAR:
- case 0:
- memset(devp_tmp->mem, 0, GLOBALFIFO_SIZE);
- printk(KERN_INFO "globalfifo has been cleared.n");
- break;
- default:
- printk(KERN_INFO "invalid cmd.n");
- return -EINVAL;
- return 0;
- static int globalfifo_release (struct inode *inode, struct file *filp)
- int ret = 0;
- return ret;
- static struct file_operations globalfifo_fops = {
- .owner = THIS_MODULE,
- .open = globalfifo_open,
- .read = globalfifo_read,
- .write = globalfifo_write,
- .unlocked_ioctl = globalfifo_ioctl,
- .llseek = globalfifo_llseek,
- .release = globalfifo_release,
- static void globalfifo_setup(struct globalfifo_dev *devp,int index)
- char name_buf[NAME_SIZE];
- int err;
- cdev_init(&devp->cdev,&globalfifo_fops);
- devnum = MKDEV(major,index);
- devp->cdev.owner = THIS_MODULE;
- err = cdev_add(&devp->cdev,devnum,1);
- if(err)
- printk(KERN_INFO "Error %d adding globalfifo%d", err, index);
- sprintf(name_buf,"globalfifo%d",index);
- globalfifo_device[index] = device_create(globalfifo_class,NULL,devnum,NULL,name_buf);
- static int __init globalfifo_init(void)
- int i,ret = 0;
- devnum = MKDEV(major,0);
- if(major)
- ret = register_chrdev_region(devnum,GLOBALFIFO_NUM,"globalfifo");
- else
- ret = alloc_chrdev_region(&devnum,0,GLOBALFIFO_NUM,"globalfifo");
- major = MAJOR(devnum);
- if(ret < 0)
- goto fail;
- globalfifo_devp = kzalloc(sizeof(struct globalfifo_dev) * GLOBALFIFO_NUM,GFP_KERNEL);
- globalfifo_device[0] = kzalloc(sizeof(struct device) * GLOBALFIFO_NUM,GFP_KERNEL);
- if(!globalfifo_devp)
- ret = ENOMEM;
- goto fail;
- globalfifo_class = class_create(THIS_MODULE,"globalfifo");
- for(i=0; i
- globalfifo_setup(globalfifo_devp + i, i);
- printk(KERN_INFO "fifo test begin and the major is %d!n",major);
- fail:
- unregister_chrdev_region(devnum,GLOBALFIFO_NUM);
- return ret;
- static void __exit globalfifo_exit(void)
- int i;
- for(i=0; i
- cdev_del(&(globalfifo_devp + i)->cdev);
- devnum = MKDEV(major,i);
- unregister_chrdev_region(devnum,1);
- kfree(globalfifo_devp);
- printk(KERN_INFO "fifo test over!n");
- module_init(globalfifo_init);
- module_exit(globalfifo_exit);
复制代码
已退回3积分
6个回答
