然后正常启动
先扩展sd卡
fa@NanoPi-M1:~$ sudo fs_resize
sudo: unable to resolve host NanoPi-M1
Disk /dev/mmcblk0: 7.4 GiB, 7985954816 bytes, 15597568 sectors
/dev/mmcblk0p1 49152 131071 81920 40M 83 Linux
/dev/mmcblk0p2 131072 15596544 15465473 7.4G 83 Linux
SD Total sectors(512byte): 15596544
Rootfs start sector: 131072
Rootfs end sector: 15596544
Part num: 2
Rootfs has been extended.
重启
fa@NanoPi-M1:~$ sudo reboot
顺便一提关机是shutdown now,蓝灯不闪了就可以断电了
裸系统启动时间在1分钟以内
NanoPi-M1:~$ cat /proc/up
time
56.64 163.40
系统占用2.3G,主要应该是被桌面环境吃了。之后试试能不能netinst一个debian
fa@NanoPi-M1:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.3G 2.3G 5.1G 32% /
devtmpfs 168M 0 168M 0% /dev
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 4.8M 243M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 248M 0 248M 0% /sys/fs/cgroup
/dev/mmcblk0p1 40M 4.6M 36M 12% /media/boot
tmpfs 50M 4.0K 50M 1% /run/user/1000
