程序可以正常读出温度,但是写入报警上限后,再将报警上限读出来总是为11111111(255),大家看看是哪里出了问题,程序如下:
void wirte_1() { chushihua();//对18b20初始化复位 delay1ms(1);//延时 write(0x4e);//这是写入th,tl和配置寄存器命令, write(0x21);//写进th的内容为0x21(33) } uchar wirte_2() { uchar f=0; chushihua();//复位 delay1ms(1);//延时 write(0xbe);//这是读取寄存器的命令,读取将从字节0开始,一只进行下去,知道第9字节(字节8,CRC)读完 f=read();//读取ls f=read();//读取ms f=read();//读取th if(f==0x21) return 1;//如果读取到的th与写入的th一致,返回1 else return f;//否则返回0 } void main() { uchar a; wirte_1(); a=wirte_2(); while(1) { display(a);//为显示函数,可以正常运行,显示总为255(11111111) } } |
1个回答
这是源码:
#include #include #define uchar unsigned char #define uint unsigned int #define DSPORT p3_7 //#include"lcd.h" unsigned char code DIG_CODE[17] = { 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; unsigned char code DIG_CODE2[20]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef, 0xf7,0xfc,0x99,0xde,0xf9,0xf1,0xf3,0xf6,0xee}; ***it p3_7=P3^7; void delay700us(void) //误差 0us { unsigned char a,b; for(b=41;b>0;b--) for(a=7;a>0;a--); } void delay1ms(unsigned int y) { unsigned int x; for( ; y>0; y--) { for(x=110; x>0; x--); } } void delay500us(void) //误差 -0.868055555556us { unsigned char a,b; for(b=1;b>0;b--) for(a=227;a>0;a--); } void delay65us(void) //误差 -0.980902777778us { unsigned char a; for(a=28;a>0;a--); } void delay500ms(void) //误差 -0.000000000114us { unsigned char a,b,c; for(c=98;c>0;c--) for(b=127;b>0;b--) for(a=17;a>0;a--); _nop_(); //if Keil,require use intrins.h } void display(unsigned int b) { unsigned char a; a=b%10; P0=DIG_CODE[a]; P2=0x07; delay500us(); delay500us(); a=b%100/10; P0=DIG_CODE[a]; P2=0x06; delay500us(); delay500us(); a=b%1000/100; P0=DIG_CODE2[a]; P2=0x05; delay500us(); delay500us(); a=b%10000/1000; P0=DIG_CODE[a]; P2=0x04; delay500us(); delay500us(); a=b%100000/10000; P0=DIG_CODE[a]; P2=0x03; delay500us(); delay500us(); a=b%1000000/100000; P0=DIG_CODE[a]; P2=0x02; delay500us(); delay500us(); a=b%10000000/1000000; P0=DIG_CODE[a]; P2=0x01; delay500us(); delay500us(); a=b%100000000/10000000; P0=DIG_CODE[a]; P2=0x00; delay500us(); delay500us(); } unsigned char chushihua(void) { p3_7=0; delay700us(); p3_7=1; while(1) { if(p3_7==0) { return 1; break; } } } void write(unsigned char ba)//写一个字节 { unsigned char i,j; for(i=0;i<8;i++) { p3_7=1; // delay65us(); p3_7=0; j++; p3_7=ba&0x01; j=6; while(j--); ba=ba>>1; p3_7=1; } } unsigned char read(void)//读一个字节 { unsigned char a=0,temp; unsigned char i,j; for(i=0;i<8;i++) { p3_7=0; j++; p3_7=1; j++; j++; a=p3_7; temp=(temp>>1)|(a<<7); j=4; while(j--); } return temp; } void com() { chushihua(); delay1ms(1); write(0xcc); write(0x44); } void date() { chushihua(); delay1ms(1); write(0xcc); write(0xbe); } void Read_1() { float zhi; uint thl,thh; thl=read(); thh=read(); thh=thh<<8; thh=thl+thh; zhi=thh; thh=zhi*0.0625*100+0.5; display(thh); } void wirte_1() { chushihua(); delay1ms(1); write(0x4e); write(0x21); } uchar wirte_2() { uchar f=0; chushihua(); delay1ms(1); write(0xbe); f=read(); f=read(); f=read(); if(f==0x21) return 1; else return f; } void main() { uchar a; while(1) { com(); date(); Read_1(); wirte_1(); a=wirte_2(); while(1) { display(a); } } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
有人有STM8H1K08T连接TM1650的源码吗,可以直接使用的那种,我的代码在烧录之后数码管一直处于熄灭状态
271 浏览 0 评论
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
493 浏览 0 评论
589 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
891 浏览 0 评论
1436 浏览 2 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16928 浏览 31 评论
/9
GMT+8, 2025-12-4 13:23 , Processed in 0.418380 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4055
