最好用的bootloader!可以基于WINDOWS来开发,比UBOOT方便多了。要是有帮助的话麻烦各位支持一下,小弟继续发。
to support wr/rd parameters to/from eeprom
#include "def.h"
#include "2440addr.h"
#include "2440lib.h"
#define SLV_ADDR_24C02 0xa0
#define SLV_ADDR_CAMERA 0x42//0x5a
void mdelay(int ms);
static volatile int iic_ints;
static void __irq IicInt(void)
ClearPending(BIT_IIC);
iic_ints++;
static int iic_wr(U8 data, U8 cnt)
int i, c;
for(i=0; i<20; i++);
if(cnt)
rIICDS = data;
rIICCON &= ~0x10; //Resume IIC operation to send
i = 3; //3ms
//while(!(rIICCON&0x10)&&i--) mdelay(1);
c = iic_ints;
while(iic_ints==c&&i--) mdelay(1);
//rIICCON &= ~0x10;
if(!i)
return -1;
return (rIICSTAT&1)?-1:0;
static int iic_rd(U8 *pBuf)
int i, c;
rIICCON &= ~0x10; //Resumes IIC operation to receive
i = 3; //3ms
c = iic_ints;
while(iic_ints==c&i--) mdelay(1);
if(i) {
*pBuf = rIICDS;
return 0;
return -1;
static int seek_iic_device(U8 slvAddr)
int i;
U8 d;
i = 200; //200ms
while(i--) {
rIICDS = slvAddr;
rIICSTAT = 0xb0; //read mode
if(!iic_wr(0, 0)) {
iic_rd(&d);
break;
mdelay(1);
rIICSTAT = 0x90;
rIICCON &= ~0x10; //Resume IIC operation to send stop
mdelay(1);
return (i>=0)?0:-1;
//8 bits register address only
static int write_eeprom(U8 slvAddr, U8 addr, U8 data)
int i;
U8 ch[3];
ch[1] = addr;
ch[2] = data;
rIICDS = slvAddr;
rIICSTAT = 0xf0; //MasTx,Start
for(i=0; i<3; i++)
if(iic_wr(ch, i))
break;
rIICSTAT = 0xd0; //Stop MasTx condition
mdelay(1);
if(i<3)
return -1;
return seek_iic_device(slvAddr);
static int read_eeprom(U8 slvAddr, U8 addr, U8 *pBuf)
int i;
U8 ch[2];
ch[1] = addr;
rIICDS = slvAddr;
for(i=0; i<2; i++)
if(iic_wr(ch, i))
break;
if(i<2) {
mdelay(1);
return -1;
rIICDS = slvAddr;
rIICSTAT = 0xb0; //Master Rx,Start
if(!iic_wr(0, 0)) //wait ack
i = iic_rd(pBuf);
rIICSTAT = 0x90; //Stop MaxRx condition
mdelay(1);
return i;
static void init_iic_op(void)
rCLKCON |= 1<<16;
rGPEUP |= 0xc000; //Pull-up disable
rGPECON &= ~0xf0000000;
rGPECON |= 0xa0000000; //GPE15:IICSDA , GPE14:IICSCL
//Enable ACK, Prescaler IICCLK=PCLK/16, Enable interrupt, Transmit clock value Tx clock=IICCLK/16
// If PCLK 50.7MHz, IICCLK = 3.17MHz, Tx Clock = 0.198MHz
//rIICCON = (1<<7) | (1<<6) | (1<<5) | (0); //IICCLK=PCLK/512=97K
//just read one byte, don't enable ack!
rIICCON = (0<<7) | (1<<6) | (1<<5) | (0); //IICCLK=PCLK/512=97K
rIICSTAT = 0x10; //IIC bus data output enable(Rx/Tx)
rIICADD = 0x10; //2410 slave address = [7:1]
pISR_IIC = (unsigned)IicInt;
EnableIrq(BIT_IIC);
static void end_iic_op(void)
// rCLKCON &= ~(1<<16);
DisableIrq(BIT_IIC);
int write_24c02(U8 *pBuf)
int i;
init_iic_op();
for(i=0; i<256; i++) {
//if(seek_iic_device(SLV_ADDR_24C02))
// break;
if(write_eeprom(SLV_ADDR_24C02, i, pBuf))
break;
end_iic_op();
Uart_Printf("Write EEPROM %s!n", (i<256)?"Fail":"Success");
return i<256;
int read_24c02(U8 *pBuf)
int i;
init_iic_op();
if(read_eeprom(SLV_ADDR_24C02, i, pBuf+i))
break;
end_iic_op();
Uart_Printf("Read EEPROM %s!n", (i<256)?"Fail":"Success");
return i<256;
int find_camera(void)
int ret = -2;
U8 d[256];
rGPGCON &= ~(3<<24);
rGPGCON |= 1<<24;
rGPGUP &= ~(1<<12);
rGPGDAT |= 1<<12;
rGPJCON = 0x1aaaaaa;
rGPJUP = 0;
rGPJDAT = 0;
mdelay(10);
rGPJDAT = 1<<12;
mdelay(10);
init_iic_op();
if(!write_eeprom(SLV_ADDR_CAMERA, 0xec, 0)) {
int i, a;
ret = -1;
a = 0xb0;
for(i=0; i<4; i++)
if(read_eeprom(SLV_ADDR_CAMERA, a+i, d+i))
break;
if(i>=4)
ret = 0;
// Uart_Printf("i = %dn", i);
// for(i=0; i<256; i++)
// Uart_Printf("%c%02x", (i%16)?' ':'n', d);
end_iic_op();
switch(ret) {
case -2:
Uart_Printf("Fail to write camera IIC!n");
break;
case -1:
Uart_Printf("Fail to read camera IIC!n");
break;
case 0:
Uart_Printf("Read camera ID is 0x%04x, ", (d[0]<<8)|d[1]);
Uart_Printf("chip version is 0x%04xn", (d[2]<<8)|d[3]);
break;
default:
break;
return ret;
