扫一扫,分享给好友
我的cmd程序如下: MEMORY { PAGE 0 : /* SARAM H0 is split between PAGE 0 and PAGE 1 */ PRAMH0 : origin = 0x3f8000 length = 0x002000 /* This memory block loaded with the reset vector only if booting from XINTF Zone 7. Otherwise reset vector is fetched from boot ROM. See .reset section below */ RESET : origin = 0x3FFFC0, length = 0x000002 PAGE 1 : /* SARAM */ RAMM0 : origin = 0x000000, length = 0x00040 RAMM0_1 : origin = 0x100000, length = 0x003c0 RAMM1 : origin = 0x000400, length = 0x000400 /* Peripheral Frame 0: */ DEV_EMU : origin = 0x000880, length = 0x000180 FLASH_REGS : origin = 0x000A80, length = 0x000060 CSM : origin = 0x000AE0, length = 0x000010 XINTF : origin = 0x000B20, length = 0x000020 CPU_TIMER0 : origin = 0x000C00, length = 0x000008 CPU_TIMER1 : origin = 0x000C08, length = 0x000008 CPU_TIMER2 : origin = 0x000C10, length = 0x000008 PIE_CTRL : origin = 0x000CE0, length = 0x000020 PIE_VECT : origin = 0x000D00, length = 0x000100 /* Peripheral Frame 1: */ ECAN_A : origin = 0x006000, length = 0x000100 ECAN_AMBOX : origin = 0x006100, length = 0x000100 /* Peripheral Frame 2: */ SYSTEM : origin = 0x007010, length = 0x000020 SPI_A : origin = 0x007040, length = 0x000010 SCI_A : origin = 0x007050, length = 0x000010 XINTRUPT : origin = 0x007070, length = 0x000010 GPIOMUX : origin = 0x0070C0, length = 0x000020 GPIODAT : origin = 0x0070E0, length = 0x000020 ADC : origin = 0x007100, length = 0x000020 EV_A : origin = 0x007400, length = 0x000040 EV_B : origin = 0x007500, length = 0x000040 SPI_B : origin = 0x007740, length = 0x000010 SCI_B : origin = 0x007750, length = 0x000040 MCBSP_A : origin = 0x007800, length = 0x000040 /* CSM Password Locations */ CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* SARAM H0 is split between PAGE 0 and PAGE 1 */ DRAMH0 : origin = 0x3f9000, length = 0x002000 } -stack 350 SECTIONS { /* Allocate program areas: */ /* Setup for "boot to H0" mode: The codestart section (found in CodeStartBranch.asm) re-directs execution to the start of user code. Place this section or the .text section at the start of H0 */ codestart : > PRAMH0, PAGE = 0 .text : > PRAMH0, PAGE = 0 .cinit : > PRAMH0, PAGE = 0 ramfuncs : > PRAMH0, PAGE = 0, TYPE = DSECT /* not used when only using RAM */ /* Allocate data areas: */ .stack : > RAMM1, PAGE = 1 .bss : > DRAMH0, PAGE = 1 .ebss : > DRAMH0, PAGE = 1 .const : > DRAMH0, PAGE = 1 .econst : > PRAMH0, PAGE = 0 .sysmem : > DRAMH0, PAGE = 1 chang : > RAMM0_1, PAGE = 1 /* .reset indicates the start of _c_int00 for C Code. /* When using the boot ROM this section is not needed. /* Thus, the default type is set to DESECT */ .reset : > RESET, PAGE = 0, TYPE = DSECT /* Allocate Peripheral Frame 0 Register Structures: */ DevEmuRegsFile : > DEV_EMU, PAGE = 1 FlashRegsFile : > FLASH_REGS, PAGE = 1 CsmRegsFile : > CSM, PAGE = 1 XintfRegsFile : > XINTF, PAGE = 1 CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1 /* CPU_TIMER1 and CPU_TIMER2 are reserved for DSP BIOS and RTOS use. Therefore these sections are not allocated in these examples CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1 CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1 */ PieCtrlRegsFile : > PIE_CTRL, PAGE = 1 PieVectTable : > PIE_VECT, PAGE = 1 /* Allocate Peripheral Frame 2 Register Structures: */ ECanaRegsFile : > ECAN_A, PAGE = 1 ECanaMboxesFile : > ECAN_AMBOX PAGE = 1 /* Allocate Peripheral Frame 1 Register Structures: */ SysCtrlRegsFile : > SYSTEM, PAGE = 1 SpiaRegsFile : > SPI_A, PAGE = 1 SciaRegsFile : > SCI_A, PAGE = 1 XIntruptRegsFile : > XINTRUPT, PAGE = 1 GpioMuxRegsFile : > GPIOMUX, PAGE = 1 GpioDataRegsFile : > GPIODAT PAGE = 1 AdcRegsFile : > ADC, PAGE = 1 EvaRegsFile : > EV_A, PAGE = 1 EvbRegsFile : > EV_B, PAGE = 1 ScibRegsFile : > SCI_B, PAGE = 1 McbspaRegsFile : > MCBSP_A, PAGE = 1 /* CSM Password Locations */ CsmPwlFile : > CSM_PWL, PAGE = 1 } 报错的位置如图所示 有两个问题: 1、.econst的空间大小怎么增大? 2、PRAMH0和DRAMH0的大小怎么增大?这个length大小怎么计算的?对应的origin是不是也要更改?主要是这个0x巴拉巴拉的部分计算我不太会。。。 谢谢懂得人士的指导~
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于 DSP5509 进行数字图像处理中 Sobel 算子边缘检测的硬件连接电路图
3370 浏览 0 评论
811 浏览 0 评论
普中科技F28335开发板中,如何使用aic23播放由代码生成的正弦波
3789 浏览 0 评论
4551 浏览 1 评论
1415 浏览 1 评论
GMT+8, 2024-12-27 09:35 , Processed in 0.516899 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
