ThingMagic NANO 超高频RFID模块/模组简介: ThingMagic Nano 是M6e 系列中最小的单元,系低功耗超高频RFID识别模块,它提供了一个更加宽阔的射频输出范围,而这对于内置电源驱动的 RFID打印机(battery-operated RFID-enabled printers),标签调试站(tag commissioning stations)产品认证(product authentication) 和门禁读卡器(access control readers)是非常重要 ThingMagic Nano 超高频RFID读写模块是M6e系列中最小的超高频射频嵌入单元,旨在提供一个低功耗、低成本、小型化的便携式射频读写器解决方案。 ThingMagicNano 的射频输出范围(0 dBm to +27 dBm)对于基于RFID打印机和标签调试站的读写需求是很重要的。它的表面封装为SMT生产的效率而设计,同时降低批量内嵌RFID应用程序的总成本,包括耗材认证和设备配置。 Physical Dimensions 22 mm Lx26mm W x 3.0 mm H (0.866inLx1.024 inWx0.118 in H) Tag / Transponder Protocols RFID Protocol Support EPCglobal Gen 2 (ISO 18000-6C) RF Interface Antennas Single 50 Ω connection (board-edge) RF Power Output Separate read and write levels, commandadjustable from 0 dBm to +27 dBm in 0.01 dB steps Regulatory Pre-configured for the following regions: • FCC (NA, SA) 917.4 – 927.2 MHz • ETSI (EU) 865.6 – 867.6 MHz • TRAI (India) 865 – 867 MHz • KCC (Korea) 917– 923.5 MHz • MIC (Japan) 916.8 – 923.4 MHz • ACMA (Australia) 920 – 926 MHz • SRRC-MII (P.R.China) 920.1–924.9 MHz • ‘Open’ (Customizable channel plan; 859 – 873 MHz and 915 – 930 MHz) Data/Control Interface Physical 41 board-edge connections providing access to RF, DC power, communication,and GPIO signals Control/Data Interfaces • UART; 3.3V logic levels; 9.6 to 921.6 kbps • Shutdown control GPIO Sensors and Indicators Four 3.3V bidirectional ports configurable as input (sensor) ports or output (indicator) ports API support C#/.NET, Java, and Embedded “C”APIs Power DC Power Required • DC Voltage: 3.3 to 5.5 V for +25 dBm out 3.7 to 5.5 V for +27 dBm out • DC power consumption when reading: 3.2 W @ 5 VDC for +27 dBm out 2.9 W @ 5 VDC for +25 dBm out 1.5 W @ 5 VDC for 0 dBm out Idle Power Consumption • 0.84 W in ready mode • 0.015 W in sleep mode • 0.00025 W in shutdown mode Environment Certification • FCC 47 CFR Ch. 1 Part 15 • Industrie Canada RSS-21 0 • ETSI EN 302 208 v1.4.1 Operating Temp. -20C to +60C (case temperature) Storage Temp. -40C to +85C Shock and Vibration Survives 1 meter drop during handling Performance Boot time Less than 30 msec after initial calibration boot Performance Up to 200 tags/sec reading 96-bit EPC
2 个讨论
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
FM17580是否能够只配置一次启动自动寻卡功能,之后就直接通过中断引脚IRQ传递给MCU,完成插拔卡的检测
13473 浏览 0 评论
5524 浏览 0 评论
ADL5801ACPZ混频器调试遇到了个问题:1.现象:混频器转换增益很差
5891 浏览 1 评论
11693 浏览 0 评论
10467 浏览 1 评论
/9
GMT+8, 2025-12-3 04:20 , Processed in 0.746365 second(s), Total 48, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3340
