摩托罗拉V180手机元件列表
TS |
TS |
TS |
TS |
TS |
Part No(Full BOM) |
Part English Name |
Part Chinese Name |
Location Code |
Repair Level |
0609591M07 |
RES CHIP DUAL 33 5% 0.63W |
电阻 |
R601 |
2 |
0662057A13 |
CHIP RES 33 OHMS 5% |
电阻 |
R1003,R1002 |
2 |
0662057A22 |
CHIP RES 75 OHMS 5% |
电阻 |
R905,R904 |
2 |
0662057A35 |
CHIP RES 270 OHMS 5% |
电阻 |
R1005,R1006,R1007 |
2 |
0662057A47 |
CHIP RES 820 OHMS 5% |
电阻 |
R907 |
2 |
0662057A51 |
CHIP RES 1200 OHMS 5% |
电阻 |
R908 |
2 |
0662057M01 |
RES. CHIP 0 5% 20X40 |
电阻 |
R1000,R1001,R1010,R1011,R1021,R151,R510 |
2 |
0662057M02 |
RES. CHIP 1.0 5% 20X40 |
电阻 |
R150 |
2 |
0662057M46 |
RES. CHIP 68 5% 20X40 |
电阻 |
R405 |
2 |
0662057M48 |
RES. CHIP 82 5% 20X40 |
电阻 |
R100,R1012,R1013,R1016,R1017,R1018,R1019,R180 |
2 |
0662057M57 |
RES. CHIP 200 5% 20X40 |
电阻 |
R916 |
2 |
0662057M64 |
RES. CHIP 390 5% 20X40 |
电阻 |
R182,R181 |
2 |
0662057M70 |
RES. CHIP 680 5% 20X40 |
电阻 |
R171 |
2 |
0662057M74 |
RES. CHIP 1000 5% 20X40 |
电阻 |
R906 |
2 |
0662057M78 |
RES. CHIP 1500 5% 20X40 |
电阻 |
R170,R600 |
2 |
0662057M90 |
RES. CHIP 4700 5% 20X40 |
电阻 |
R400,R401 |
2 |
0662057M92 |
RES. CHIP 5600 5% 20X40 |
电阻 |
R300 |
2 |
0662057M95 |
RES. CHIP 7500 5% 20X40 |
电阻 |
R501 |
2 |
0662057M98 |
RES. CHIP 10K 5% 20X40 |
电阻 |
R1004,R2,R909,R404 |
2 |
0662057N06 |
RES. CHIP 20K 5% 20X40 |
电阻 |
R101,R102 |
2 |
0662057N01 |
RES CHIP 12K 5% 20X40 |
电阻 |
R900,R901,R903,R902 |
2 |
0662057N15 |
RES. CHIP 47K 5% 20X40 |
电阻 |
R402,R914,R700 |
2 |
0662057N16 |
RES. CHIP 51K 5% 20X40 |
电阻 |
R532 |
2 |
0662057N17 |
RES. CHIP 56K 5% 20X40 |
电阻 |
R530 |
2 |
0662057N19 |
RES. CHIP 68K 5% 20X40 |
电阻 |
R183,R535 |
2 |
0662057N28 |
RES. CHIP 160K 5% 20X40 |
电阻 |
R531 |
2 |
0662057N31 |
RES. CHIP 220K 5% 20X40 |
电阻 |
R915 |
2 |
0662057N32 |
RES. CHIP 240K 5% 20X40 |
电阻 |
R403 |
2 |
0662057N35 |
RES. CHIP 330K 5% 20X40 |
电阻 |
R999 |
2 |
0662057V02 |
RES CHIP 10K 1% 1/16W |
电阻 |
R800 |
2 |
0662057V29 |
RES CHIP 120K 1% 1/16W |
电阻 |
R912 |
2 |
0662057V43 |
RES CHIP 330K 1% |
电阻 |
R911 |
2 |
0685660C01 |
THERMISTOR 3% 0402 |
热敏电阻 |
RT900 |
2 |
0888600M24 |
CAP,FILM,8200PF,+5%,-5%,50V-DC |
电容 |
C186,C172 |
2 |
0970312B16 |
TA02-MINI-USB CONNECTOR |
连接器 |
J600 |
2 |
0985882K01 |
RECPT CHRG 3POSTN SMD |
连接器 |
J900 |
2 |
0987817K04 |
CONN,RCPT,M,30CONT,,GOLD/NICKE |
连接器 |
J800 |
2 |
0987837L04 |
CONN JACK |
连接器 |
J400 |
2 |
0988252L01 |
SOCKET,COIN CELL BATT |
连接器 |
J950 |
2 |
0988612M01 |
CONN,RCPT,,,,RF SWITCH, SMT |
连接器 |
J1 |
2 |
2113743F18 |
CAP CHIP 2.2 UF 16V +80-20% |
电容 |
C107 |
2 |
2113743L05 |
CAP CHIP 330 PF 10% X7R |
电容 |
C170 |
2 |
2113743L09 |
CAP CHIP 470 PF 10% X7R |
电容 |
C183 |
2 |
2113743L13 |
CAP CHIP 680 PF 10% X7R |
电容 |
C171 |
2 |
2113743L17 |
CAP CHIP 1000 PF 10% X7R |
电容 |
C101 |
2 |
2113743N32 |
CAP CHIP 18.0PF 5% COG |
电容 |
C115 |
2 |
2113743L21 |
CAP CHIP 1500 PF 10% X7R |
电容 |
C416,C185 |
2 |
2113743L37 |
CAP CHIP 6800 PF 10% X7R |
电容 |
C105 |
2 |
2113743L41 |
CAP CHIP 10000 PF 10% X7R |
电容 |
C900,C601,C817,C804,C901,C156,C700,C820,C821,C702,C827,C151,C703,C701,C403 |
2 |
2113743M24 |
CAP CHIP 100000 PF +80-20% Y5V |
电容 |
C930,C915,C427,C919,C929,C415,C920,C304,C805,C806 |
2 |
2113743N02 |
CAP CHIP 0.75PF +-.25PF |
电容 |
C3 |
2 |
2113743N13 |
CAP CHIP 3.0 PF +-.25PF COG |
电容 |
R1 |
2 |
2113743N20 |
CAP CHIP 5.6 PF + -.5PF COG |
电容 |
C187 |
2 |
2113743N26 |
CAP CHIP 10.0 PF 5% COG |
电容 |
C154,C158,C302,C406,C407,C408,C414,C419,C421,C432,C433,C434,C435 |
2 |
2113743N25 |
CAP CHIP 9.1 PF + -.5PF COG |
电容 |
C4 |
2 |
2113743N30 |
CAP CHIP 15.0 PF 5% COG |
电容 |
C905,C903,C913,C914 |
2 |
2113743N38 |
CAP CHIP 33.0 PF 5% COG |
电容 |
C909,C2,C5 |
2 |
2113743N40 |
CAP CHIP 39.0 PF 5% COG |
电容 |
C103,C102,C109,C413,C104,C106,C811,C810,C904,C155,C100,C152,C153,C1,C430,C420,C110,C111,C422,C431,C114,C113 |
2 |
2113743N42 |
CAP CHIP 47.0 PF 5% COG |
电容 |
C157 |
2 |
2113743N52 |
CAP CHIP 120 PF 5% COG |
电容 |
C182,C184 |
2 |
2113743N54 |
CAP CHIP 150 PF 5% COG |
电容 |
C911 |
2 |
2113928C04 |
CAP CER CHIP 4.7UF 6.3V10%0805 |
电容 |
C159,C161,C429,C812,C912,C92,C924 |
2 |
2113928C12 |
CAP,CER,10UF,,+10%,-10%,,0805 |
电容 |
C423,C902,C910,C918 |
2 |
2113928N01 |
CAP CER CHIP 0.1UF 10% 6.3 |
电容 |
C160 |
2 |
2113928S04 |
CAP,CHIP,.1UF,,+10,-10,10V-DC, |
电容 |
C400,C401,C409,C437,C813,C814,C815,C816,C818,C819,C906,C908,C926,C927 |
2 |
2113946D05 |
CAP,CHIP,2.2UF,,+10,-10,6.3V-D |
电容 |
C108,C504,C505 |
2 |
2170282K01 |
CAP,TANTALUM,10UF,+20%,-20%,6. |
电容 |
C934 |
2 |
2187893N01 |
CAP,,1UF,,+20%,-20%,6.3V-DC,04 |
电容 |
C809,C600,C150,C808,C807,C503,C822,C502,C928,C803,C801,C832,C802 |
2 |
2187906N01 |
CAP,CHIP,4.7UF,940000PF+/-,+20 |
电容 |
C426,C916,C923,C931 |
2 |
2409154M20 |
FIXED INDUCTOR,CHIP,39NH,5%,,1 |
电感 |
L3,L400,L401,L402,L404,L405,L406 |
2 |
2409154M21 |
FIXED INDUCTOR,CHIP,47NH,5%,,2 |
电感 |
L403 |
2 |
2113743N03 |
CAP CHIP 1.0 PF +-.25PF COG |
电感 |
C6 |
2 |
2409154M36 |
FIXED INDUCTOR,CHIP,10NH,5%,,. |
电感 |
L1,L150 |
2 |
2409154M57 |
FIXED INDUCTOR,CHIP,3.9NH,7.69 |
电感 |
L5 |
2 |
2409154M73 |
FIXED INDUCTOR,CHIP,68NH,5%,,4 |
电感 |
L300 |
2 |
2409646M13 |
IND CER MULTILYR 39NH 1608 |
电感 |
L407,L408 |
2 |
2489970L37 |
IDCTR,WW,270NH,2,,,,,,HI_Q_160 |
电感 |
L180 |
2 |
2587957N02 |
IDCTR,,,,,,,SM,,,D312F PH-FREE |
电感 |
L900 |
2 |
2603506B01 |
SHIELD,RF,,,,,,,,V180 NEPTUNE |
屏蔽罩 |
SH800 |
2 |
2603507B01 |
SHIELD,RF,,,,,,,,V180 SEAWD |
屏蔽罩 |
SH900 |
2 |
2688210N01 |
SHIELD,RF,,24.64MMLG,10.36MMW, |
屏蔽罩 |
SH200 |
2 |
2688211N01 |
SHIELD,RF,CRS,,TIN,13.5MMLG,12 |
屏蔽罩 |
SH100 |
2 |
3970350D02 |
CONN HW,SIM,CRD,,,,RB T725 |
连接器 |
J300 |
2 |
3986859P01 |
CONN,BAT,NONE,3,,,,CONT |
连接器 |
P900 |
2 |
3988194N03 |
CONN,POGO,,,,,,2-POSITION |
连接器 |
J410 |
2 |
3989013L05 |
CONT ANT |
连接器 |
ANT_FEED 1 |
2 |
4087635K01 |
MECH PUSH BUTTON SWITCH,TACTIL |
开关按钮 |
S526,S527 |
2 |
4809612J43 |
RESON,QRTZ,26MHZ,+/-10,FUND,,- |
振荡器 |
Y800 |
2 |
4809788E06 |
DIODE ZENER 6.8V UDZ6.8B |
二级管 |
VR400 |
2 |
4809924D18 |
DIODE,SHTK,EMD2SC79,,,,30UA,30 |
二级管 |
D500,D505,D506 |
2 |
4809948D37 |
DIODE,PIN,BA892,SM,SM2,100MA,3 |
二级管 |
D100,D101 |
2 |
4809948D44 |
4 CHANNEL ESD ARRAY 5-PIN CHIP |
二级管 |
VR802 |
2 |
4809995L09 |
XTAL QUARTZ 32.768KHZ MC-146 |
振荡器 |
Y900 |
2 |
4813823A16 |
TSTR N-CH HDTMOS RDS |
晶体管 |
Q903 |
2 |
4813824B11 |
TSTR PNP 30V HI BETA |
晶体管 |
Q900 |
2 |
4813824M28 |
TSTR NPN 40V .2A GEN PURP |
晶体管 |
Q901,Q902 |
2 |
4813830A70 |
DIODE DL 5.6V COM ANODE |
二级管 |
VR401,VR900,VR600 |
2 |
4870370A51 |
DIODE,SHTK,MA3S795E,,,30MA,1V, |
二级管 |
D513,D514,D515,D516,D517,D518,D519,D520,D521 |
2 |
4888112M04 |
INDCTR,LED,SM,,,5V,100MA,BLU,R |
二级管 |
D501,D502,D508,D509,D510,D511 |
2 |
4888182N01 |
IC,SENSOR,,,PHOTO LT,5 PIN PLA |
集成电路 |
DS530 |
2 |
5103536B01 |
IC,FLSH,,128MB,8MX16,85 |
集成电路 |
U701 |
2 |
5109509A51 |
IC,SRAM,,,2MX16,85,,BGA48,3.3V |
集成电路 |
U705 |
2 |
5109923D61 |
IC,CUST,,,,,,,SIGEALGAEMB 48PI |
集成电路 |
U150 |
2 |
5162852A16 |
IC,COMPTR,LMC7211,SM,,1PER PKG |
集成电路 |
U530 |
2 |
5170200A08 |
IC,DRIVER,DL DISP,3/2X SWITCHE |
集成电路 |
U500 |
2 |
5187970L44 |
IC,,,,,,,,,,3/2 CHG PUMP WHT L |
集成电路 |
2 |
5170200A11 |
IC,DC TO DC CONVERTER,,SM,,,2. |
集成电路 |
U930 |
2 |
5185143E94 |
集成电路 |
2 |
5187970L15 |
IC USB TRANS FULL-SPEED |
集成电路 |
U600 |
2 |
5187970L26 |
IC,,,,,BGA,,,DH3 CHGR |
集成电路 |
U920 |
2 |
5188450M15 |
IC,CUST,,,,,,,SEAWEED2 VER 2.3 |
集成电路 |
U900 |
2 |
5189818N01 |
IC,RF AMPLIFIER,,,,,,,824MHZMI |
集成电路 |
U100 |
2 |
5199129K04 |
IC,CUST,,,1PER PKG,,,,NEPTUNE |
集成电路 |
U800 |
2 |
5199129K05 |
IC,CUST,,,,,,,CUST PGM BGA 280 |
集成电路 |
2 |
6589735L01 |
FUSE FAST 32V 2.0A 0603 |
保险丝 |
F900 |
2 |
8486962P01 |
PCB,MN,,V180,8 LAYER,BRD |
PCB板 |
PCB |
2 |
9188668L06 |
FLTR,SAW,,1.96GHZNOM,,,,SM,,QU |
滤波器 |
FL100 |
2 |
5485042F01 |
LBL,MISC,,,,,LBL WATER INDCTR |
防水标签 |
1 |
5089405N01 |
MIC,,200-3400,,,OMNI-DIRECTION |
麦克风 |
1 |
6087603L01 |
RECHARGEABLE COIN CELL, 3V |
小电池 |
1 |
8586901P02 |
ANT,STUBBY,824MHZMIN,1.99GHZMA |
天线 |
1 |
0370303E01 |
SCR,SLFTP,M1.6,4.8MM,STAR,SPCL |
螺丝 |
1 |
5486970P01 |
LBL,ADHES,,V180,,PLASTIC - POL |
标签 |
1 |
3803619B03 |
KYPD,SOFT CAPS,PC,V180 STROKE |
键盘板 |
1 |
0103662B01 |
ASSY,HSG,REAR,V180 |
后盖 |
1 |
0103656B01 |
ASSY,HSG,FRNT,V180 |
前盖 |
1 |
5570373B01 |
HNG,FLIP,SS,,SMOOTH,RIGHTHAND, |
转轴 |
1 |
0370303E02 |
SCR,SLFTP,M1.6,3.6MM,STAR,SPCL |
螺丝 |
1 |
0703649B01 |
BRKT,MTG,,V180 FLIP OVERSHIELD |
翻盖支架 |
1 |
0103659B01 |
ASSY,HSG,OTHR,V180,,INNER |
翻盖的内壳 |
1 |
6103597B01 |
LENS,FLIP,,V180 |
LENS |
1 |
0103667B01 |
ASSY,FLXCKT,MDL,,,V180,CLI |
综合FPC |
1 |
0786909P01 |
BRKT,LCD,SS,V200 |
次显示屏支架 |
1 |
0186861P02 |
DISP,LCD,,,,2.775V,SQUARE PIXE |
显示屏 |
1 |
5089081L02 |
SPKR EARPC 32 OHM 13MM PINS |
话筒 |
1 |
3203660B01 |
GSKT,,DUST,,,,,,,,V180 MN DISP |
垫片 |
1 |
1503596B01 |
HSG,OUTSIDE FLIP,,V180 |
翻盖的外壳 |
1 |
3203538B01 |
GSKT,,DUST,,,,,,,,V180 CLI |
橡胶垫 |
1 |
4003650B01 |
SW,METAL DOME,21,,,,,,,,,,V180 |
按键薄膜 |
1 |
1070295C01 |
Copper Foil |
铜片 |
1 |
AAUG1530AA |
V180 TXCR |
V180 |
1 |
2008-6-10 01:25:20
淘帖0
