扫一扫,分享给好友
#include
#include #include "api.h" /* *This file is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTYT; * *uart:9600BPS */ /***************************************************/ #define uchar unsigned char #define TX_ADR_WIDTH 5 // 5 bytes TX(RX) address width #define TX_PLOAD_WIDTH 20 // 20 bytes TX payload uchar const TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static TX address uchar rx_buf[TX_PLOAD_WIDTH]; uchar tx_buf[TX_PLOAD_WIDTH]; uchar flag; /**************************************************/ ***it CE = P1^0; ***it CSN= P1^1; ***it SCK= P1^2; ***it MOSI= P1^3; ***it MISO= P1^4; ***it IRQ = P1^5; /**************************************************/ uchar bdata sta; ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /**************************************************/ /************************************************** Function: init_io(); Description: flash led one time,chip enable(ready to TX or RX Mode), Spi disable,Spi clock line init high /**************************************************/ #define KEY 0xaa void init_io(void) { P0=KEY; // led light CE=0; // chip enable CSN=1; // Spi disable SCK=0; // Spi clock line init high P0=0xff; // led close } /**************************************************/ /************************************************** Function: Inituart(); Description: set uart working mode /**************************************************/ void Inituart(void) { TMOD = 0x20; //timer1 working mode 1 TL1 = 0xfd; //f7=9600 for 16mhz Fosc,and ... TH1 = 0xfd; //...fd=19200 for 11.0592mhz Fosc SCON = 0xd8; //uart mode 3,ren==1 PCON = 0x80; //smod=0 TR1 = 1; //start timer1 } /**************************************************/ /************************************************** Function: init_int0(); Description: enable int0 interrupt; /**************************************************/ void init_int0(void) { EA=1; EX0=1; // Enable int0 interrupt. } /**************************************************/ /************************************************** Function: delay100(); Description: delay 100ms /************************************************** void delay(uchar ) { uchar x; uchar y; for(x=0;x<100;x++) { for(y=0;y<100;y++) _nop_(); } } /**************************************************/ void delay_ms(unsigned int x) { unsigned int i,j; i=0; for(i=0;i j=108; ; while(j--); } } /**************************************************/ /************************************************** Function: SPI_RW(); Description: Writes one byte to nRF24L01, and return the byte read from nRF24L01 during write, according to SPI protocol /**************************************************/ uchar SPI_RW(uchar byte) { uchar bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (byte & 0x80); // output 'byte', MSB to MOSI byte = (byte << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. byte |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(byte); // return read byte } /**************************************************/ /************************************************** Function: SPI_RW_Reg(); Description: Writes value 'value' to register 'reg' /**************************************************/ uchar SPI_RW_Reg(BYTE reg, BYTE value) { uchar status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status byte } /**************************************************/ /************************************************** Function: SPI_Read(); Description: Read one byte from nRF24L01 register, 'reg' /**************************************************/ BYTE SPI_Read(BYTE reg) { BYTE reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /**************************************************/ /************************************************** Function: SPI_Read_Buf(); Description: Reads 'bytes' #of bytes from register 'reg' Typically used to read RX payload, Rx/Tx address /**************************************************/ uchar SPI_Read_Buf(BYTE reg, BYTE *pBuf, BYTE bytes) { uchar status,byte_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status byte for(byte_ctr=0;byte_ctr CSN = 1; // Set CSN high again return(status); // return nRF24L01 status byte } /**************************************************/ /************************************************** Function: SPI_Write_Buf(); Description: Writes contents of buffer '*pBuf' to nRF24L01 Typically used to write TX payload, Rx/Tx address /**************************************************/ uchar SPI_Write_Buf(BYTE reg, BYTE *pBuf, BYTE bytes) { uchar status,byte_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status byte for(byte_ctr=0; byte_ctr CSN = 1; // Set CSN high again return(status); // return nRF24L01 status byte } /**************************************************/ /************************************************** Function: RX_Mode(); Description: This function initializes one nRF24L01 device to RX Mode, set RX address, writes RX payload width, select RF channel, datarate & LNA HCURR. After init, CE is toggled high, which means that this device is now ready to receive a datapacket. /**************************************************/ void RX_Mode(void) { CE=0; SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // Enable Auto.Ack:Pipe0 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // Enable Pipe0 SPI_RW_Reg(WRITE_REG + RF_CH, 40); // Select RF channel 40 SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:RX. RX_DR enabled.. CE = 1; // Set CE pin high to enable RX device // This device is now ready to receive one packet of 16 bytes payload from a TX device sending to address // '3443101001', with auto acknowledgment, retransmit count of 10, RF channel 40 and datarate = 2Mbps. } /**************************************************/ /************************************************** Function: TX_Mode(); Description: This function initializes one nRF24L01 device to TX mode, set TX address, set RX address for auto.ack, fill TX payload, select RF channel, datarate & TX pwr. PWR_UP is set, CRC(2 bytes) is enabled, & PRIM:TX. ToDo: One high pulse(>10us) on CE will now send this packet and expext an acknowledgment from the RX device. /**************************************************/ void TX_Mode(void) { CE=0; SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // Writes TX_Address to nRF24L01 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // RX_Addr0 same as TX_Adr for Auto.Ack SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // Writes data to TX payload SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // Enable Auto.Ack:Pipe0 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // Enable Pipe0 SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans... SPI_RW_Reg(WRITE_REG + RF_CH, 40); // Select RF channel 40 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:TX. MAX_RT & TX_DS enabled.. CE=1; } /**************************************************/ /************************************************** Function: check_ACK(); Description: check if have "Data sent TX FIFO interrupt",if TX_DS=1, all led light and after delay 100ms all led close /************************************************** void check_ACK() { uchar test; test=SPI_Read(READ_REG+STATUS); // read register STATUS's test=test&0x20; // check if have Data sent TX FIFO interrupt (TX_DS=1) if(test==0x20) // TX_DS =1 { P0=0x00; // turn on all led delay100(); // delay 100ms P0=0xff; } } /**************************************************/ /************************************************** Function: TxData(); Description: write data x to SBUF /**************************************************/ void TxData (uchar x) { SBUF=x; // write data x to SBUF while(TI==0); TI=0; } /**************************************************/ /************************************************** Function: CheckButtons(); Description: check buttons ,if have press,read the key values, turn on led and transmit it; after transmition, if received ACK, clear TX_DS interrupt and enter RX Mode; turn off the led /**************************************************/ void CheckButtons() { uchar Temp,xx,Tempi; P0=0xff; Temp=P0&KEY; //read key value from port P0 if (Temp!=KEY) { delay_ms(10); Temp=P0&KEY; // read key value from port P0 if (Temp!=KEY) { xx=Temp; Tempi=Temp>>1; // Left shift 4 bits P0=Tempi; // Turn On the led tx_buf[0]=Tempi; // Save to tx_buf[0] TX_Mode(); // set TX Mode and transmitting TxData(xx); // send data to uart //check_ACK(); // if have acknowledgment from RX device,turn on all led SPI_RW_Reg(WRITE_REG+STATUS,SPI_Read(READ_REG+STATUS)); // clear interrupt flag(TX_DS) delay_ms(500); P0=0xff; // Turn off the led RX_Mode(); // set receive mode while((P0&KEY)!=KEY); } } } /**************************************************/ /************************************************** Function: main(); Description: control all subprogrammes; /**************************************************/ void main(void) { uchar xx; init_io(); // Initialize IO port Inituart(); // initialize 232 uart //init_int0(); // enable int0 interrupt RX_Mode(); // set RX mode while(1) { CheckButtons(); // scan key value and transmit sta=SPI_Read(STATUS); // read register STATUS's value if(RX_DR) // if receive data ready (RX_DR) interrupt { SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer flag=1; } if(MAX_RT) { SPI_RW_Reg(FLUSH_TX,0); } SPI_RW_Reg(WRITE_REG+STATUS,sta);// clear RX_DR or TX_DS or MAX_RT interrupt flag if(flag) // finish received { flag=0; // set flag=0 P0=rx_buf[0]; // turn on led delay_ms(500); P0=0xff; // turn off led xx=rx_buf[0]>>1;// right shift 4 bits TxData(xx); // send data to uart } } } /**************************************************/ /************************************************** Function: ISR_int0() interrupt 0; Description: if RX_DR=1 or TX_DS or MAX_RT=1,enter this subprogram; if RX_DR=1,read the payload from RX_FIFO and set flag; /**************************************************/ void ISR_int0(void) interrupt 0 { sta=SPI_Read(STATUS); // read register STATUS's value if(RX_DR) // if receive data ready (RX_DR) interrupt { SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer flag=1; } if(MAX_RT) { SPI_RW_Reg(FLUSH_TX,0); } SPI_RW_Reg(WRITE_REG+STATUS,sta);// clear RX_DR or TX_DS or MAX_RT interrupt flag } /**************************************************/
23个回答
这是错误啊......
图片还不能直接显示么
图片的意思是SPI_read少个;
你把错误提示截图;
不是SPI_Read哪里缺少“;”吗
缺 “;”不一定是在提示的那一行,上下文看看
#include "api.h"改为
试过了。。。还是不行 |
我不知道那个库是什么来的,我也没有。程序是你下载的吧???如果不是系统自带的话,那就麻烦了!! |
从哪粘贴过来的程序啊?去掉api.h,看看哪里会报错.
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
331 浏览 0 评论
532 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
842 浏览 0 评论
1383 浏览 2 评论
824 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16911 浏览 31 评论
/9
GMT+8, 2025-12-3 09:59 , Processed in 1.079168 second(s), Total 112, Slave 91 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1994
