扫一扫,分享给好友
/*主机程序*/
#include #include "Cry12864HZ.c" #include "Cry12864HZ.h" #define keyin (P5IN & 0x0f) #define DRE_out P3DIR |= BIT3 //连接485芯片的DE,RE端口的IO设置为输出状态 #define DE P3OUT |= BIT3 //设置485芯片处于发送状态 #define RE P3OUT &= ~BIT3 //设置485芯片处于接收状态 void Init_uat0(void); void delay(void);//收发都需要 char receive(void); //接受函数 void rade_init(); void display(); //unsigned char DATA[6]={"------"}; unsigned char RR=0; unsigned char TT=0; uchar R_shi,R_ge,T_shi,T_ge,T_xs1,T_xs2,R_xs1,R_xs2; uchar num,flag,keyval; uint r[7]; uchar string[]={"温湿测试系统"}; uchar string1[]={"温湿测试从1"}; uchar string2[]={"温湿测试从2"}; uchar str_t[]={"温 度:"}; uchar str_r[]={"湿 度:"}; uchar str_suit[]={"适宜度:"}; uchar str1[]={"适 宜"}; uchar str2[]={"不适宜"}; unsigned char sendBytes[16]={"ABCDEF0123456789"}; /*****************子函数********************/ void delay(void) { unsigned int i=1800; while(i--); } void delay_1ms(uint z) { uint i,j; for(i=z;i>0;i--) for(j=80;j>0;j--); } void keycantrol() { uchar s; if(keyin != 0x0f) //键值有改变 { delay_1ms(10); //延时消抖 if(keyin != 0x0f) //再次检测按键状态 { s=keyin; while(keyin != 0x0f); //等待按键被放开 switch(s) //转换键值 { case 0x0e: keyval = 0x01;break; case 0x0d: keyval = 0x02;break; case 0x0b: keyval = 0x03;break; case 0x07: keyval = 0x04;break; default: break; } delay_1ms(1);delay_1ms(1);delay_1ms(1);delay_1ms(1); } } } void display() { if(keyval==0x01) { Disp_HZ(0x81,string1,6); } if(keyval==0x02) { Disp_HZ(0x81,string2,6); } Write_Cmd(0x94); delay_1ms(10); Write_Data(T_shi); Write_Data(T_ge); delay_1ms(10); Write_Data('.'); Write_Data(T_xs1); Write_Data(T_xs2); Write_Data(' '); Write_Data(str_t[4]); Write_Data(str_t[5]); Write_Cmd(0x8C); delay_1ms(10); Write_Data(R_shi); Write_Data(R_ge); delay_1ms(10); Write_Data('.'); Write_Data(R_xs1); Write_Data(' '); Write_Data('%'); Write_Data('R'); Write_Data('H'); if(r[0]>10 && r[0]<33 && r[2]>30 && r[2]<80) Disp_HZ(0x98+4,str1,3); else Disp_HZ(0x98+4,str2,3); } void main(void) { unsigned int i; WDTCTL=WDTPW+WDTHOLD; //停止看门狗 BCSCTL1 &= ~XT2OFF; // XT2on do { IFG1 &= ~OFIFG; // Clear OSCFault flag for (i = 0xFF; i > 0; i--); // time for flag to set } while ((IFG1 & OFIFG)); // OSCFault flag still set? BCSCTL2 |= SELM_2 + SELS; // MCLK = SMCLK = XT2 (safe) DRE_out; RE;//收允许 P5DIR = 0xf0; //设置P5.0~P5.3为输入状态 Init_uat0(); Ini_Lcd(); //初始化液晶 Disp_HZ(0x81,string,6); Disp_HZ(0x90,str_t,4); Disp_HZ(0x88,str_r,4); Disp_HZ(0x98,str_suit,4); _EINT(); //中断 while(1) { keycantrol(); display(); } } void Init_uat0(void) { P3SEL |= 0x30; //将P3.4,P3.5选做UART1的通信端口TXD/RXD ME1 |= UTXE0 + URXE0; // Enable USART0 TXD/RXD UCTL0 |= CHAR; // 8-bit character UTCTL0 |= SSEL1; // UCLK = SMCLK UBR00 = 0x0; // 8Mhz/19200 ~ 417 UBR10 = 0x03; // 7.3728/19200~180H UMCTL0 = 0x0; // no modulation UCTL0 &= ~SWRST; // Initialize USART state machine IE1 |= URXIE0+ UTXIE0; // Enable USART0 RX interrupt } #pragma vector = UART0RX_VECTOR __interrupt void UART0_RXISR(void) { r[RR] = RXBUF0; RR++; if(RR >= 7) { R_shi =(0X30+r[0]); R_ge =(0X30+r[1]); R_xs1=(0X30+r[2]); //温度整数部分 T_shi =(0X30+r[3]); T_ge =(0X30+r[4]); //温度小数部分 T_xs1 = (0X30+r[5]); T_xs2 = (0X30+r[6]); DE; RR = 0; IFG1 |= UTXIFG0; // 设置中断标志,进入发送中断程序 } // _BIC_SR_IRQ(LPM3_bits); } #pragma vector = UART0TX_VECTOR __interrupt void UART0_TXISR(void) { if(keyval==0x01) { TXBUF0 = 0x01; //从机1地址 delay(); RE; } else if(keyval==0x02) { TXBUF0 = 0x02; //从机2地址 delay(); DE; } else { delay(); RE; } } /*从机2程序*/ #include #define DRE_out P2DIR |= BIT6 //连接485芯片的DE,RE端口的IO设置为输出状态 #define DE P2OUT |= BIT6 //设置485芯片处于发送状态 #define RE P2OUT &= ~BIT6 //设置485芯片处于接收状态 //#define DRE_out P3DIR |= BIT3 //连接485芯片的DE,RE端口的IO设置为输出状态 //#define DE P3OUT |= BIT3 //设置485芯片处于发送状态 //#define RE P3OUT &= ~BIT3 //设置485芯片处于接收状态 #define uchar unsigned char #define uint unsigned int #define HIGH P3OUT|=BIT1; //DHT11的DATA #define LOW P3OUT&=~BIT1; void Init_uat0(void); void delay(void);//收发都需要 uchar TH_data,TL_data,RH_data,RL_data,CK_data; uchar TH_temp,TL_temp,RH_temp,RL_temp,CK_temp; uchar com_data,untemp,temp; uchar respond,num; uchar P[7]; unsigned char RR=0; unsigned char TT=0; /*****************子函数********************/ void delay(void) { unsigned int i=1800; while(i--); } void delay_1ms(uint z) { uint i,j; for(i=z;i>0;i--) for(j=80;j>0;j--); } void DelayNus(uint n)//延时1US函数 { TACTL|= TASSEL_2+TACLR+ID_3;//定时器A,时钟为SCLK,8分频; TACTL |= MC_1; //增计数到CCR0 TACCR0 = n; while((TACTL & BIT0)!=0x01); //等待 TACTL &= ~MC_1; //停止计数 TACTL &= ~BIT0; //清除中断标志 } char receive(void) //接受函数 { uchar i; com_data=0; for(i=0;i<=7;i++) { respond=2; while(!(P3IN&BIT1)&& respond++); //等待50us的低电平结束 DelayNus(20); if(P3IN&BIT1) //长于30us定义为1 { temp=1; respond=2; while((P3IN&BIT1)&& respond++); //结束高电平,即下一位数据的到来 } else temp=0; com_data<<=1; com_data|=temp; } return(com_data); } void rade_init() { P3DIR |= BIT1; //设置P3.1为输出状态 LOW; DelayNus(24000); //开始信号 HIGH; DelayNus(20); HIGH; P3DIR&=~BIT1; //设置P3.1为输入状态,检测传感器响应 /* DelayNus(20); //20US后 P3IN 是否为低电平,不为低电平 说明复位失败,重新开始 while((P3IN&BIT1)!=0)//如果没有检测到响应信号 继续发送开始信号 { P3DIR |= BIT1; //设置P3.1为输出状态 HIGH; _NOP();_NOP();_NOP(); LOW; DelayNus(20000); //开始信号 HIGH; DelayNus(20); HIGH; P3DIR&=~BIT1; //设置P3.1为输入状态,检测传感器响应 DelayNus(20); }*/ if(!(P3IN&BIT1)) { respond=2; while(!(P3IN&BIT1)&& respond++);//等待拉高,准备输出数据 respond=2; while((P3IN&BIT1)&& respond++); //等待低电平,输出数据 //下面开始接受数据 RH_temp = receive(); RL_temp = receive(); TH_temp = receive(); TL_temp = receive(); CK_temp = receive(); P3DIR|=BIT1; HIGH; untemp=(RH_temp+RL_temp+TH_temp+TL_temp); if(untemp==CK_temp) { RH_data = RH_temp; RL_data = RL_temp; TH_data = TH_temp; TL_data = TL_temp; CK_data = CK_temp; } } P[0] = RH_data/10; P[1] = RH_data%10; P[2]= RL_data/10; //温度整数部分 P[3] = TH_data/10; P[4] = TH_data%10; //温度小数部分 P[5] = TL_data/10; P[6] = TL_data%10; } void main(void) { unsigned int i; WDTCTL=WDTPW+WDTHOLD; //停止看门狗 BCSCTL1 &= ~XT2OFF; // XT2on do { IFG1 &= ~OFIFG; // Clear OSCFault flag for (i = 0xFF; i > 0; i--); // Time for flag to set } while ((IFG1 & OFIFG)); // OSCFault flag still set? BCSCTL2 |= SELM_2 + SELS; // MCLK = SMCLK = XT2 (safe) DRE_out; RE;//收允许 Init_uat0(); _EINT(); //中断 for(;;) { _NOP(); rade_init(); delay_1ms(100);//等待下次采样 //_BIS_SR(LPM3_bits+GIE); //进入LPM3模式/允许总中断 } } void Init_uat0(void) { P3SEL |= 0x30; //将P3.4,P3.5选做UART1的通信端口TXD/RXD ME1 |= UTXE0 + URXE0; // Enable USART0 TXD/RXD UCTL0 |= CHAR; // 8-bit character UTCTL0 |= SSEL1; // UCLK = SMCLK UBR00 = 0x0; // 8Mhz/19200 ~ 417 UBR10 = 0x03; // 7.3728/19200~180H UMCTL0 = 0x0; // no modulation UCTL0 &= ~SWRST; // Initialize USART state machine IE1 |= URXIE0+ UTXIE0; // Enable USART0 RX interrupt } #pragma vector = UART0RX_VECTOR __interrupt void UART0_RXISR(void) { num = RXBUF0; if(num == 0x02) //从机地址 { DE; num = 0; IFG1 |= UTXIFG0; // 设置中断标志,进入发送中断程序 } } #pragma vector = UART0TX_VECTOR __interrupt void UART0_TXISR(void) { if(TT < 7) { TXBUF0 = P[TT]; TT++; } else { delay(); TT=0; RE; } } |
4个回答
是程序问题还是电路问题。电路是3片485芯片,DE,RE短接加100欧电阻连单片机,A、B各加上拉电阻和下拉电阻。
顶,在线等啊,
顶。。。急救啊
第一,首先把显示调试好,然后再来调试通信,分开调试好,然后组合起来就ok了
只有小组成员才能发言,加入小组>>
2901个成员聚集在这个小组
加入小组2637 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
2942 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2247 浏览 1 评论
4659 浏览 1 评论
2450 浏览 1 评论
909浏览 3评论
2942浏览 2评论
2637浏览 1评论
1035浏览 0评论
GMT+8, 2024-8-6 22:29 , Processed in 1.352634 second(s), Total 87, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
