想先做个ds12c887精确4位共阴数码管时钟,秒用发光二极管表示, 不加887时,时钟功能一步一步进展还算顺利,但加上后就不行了,症状是全显示0,可以设定按键时间,但设定好退出按键,又回到全0状态, 已经研究很久了,请大家帮帮忙看下,真没辙了~~~~~ 程序如下 #include #define uchar unsigned char #define uint unsigned int ***it led1 = P2^3; //小灯做秒显示 ***it led2 = P2^2; ***it wela1 = P2^7; //分 个位 ***it wela2 = P2^6; //分 十位 ***it wela3 = P2^5; //时 个位 ***it wela4 = P2^4; //时 十位 ***it k1= P3^2; //选择 ***it k2 = P2^1; //加 ***it k3 = P2^0; //减 //***it deep = P2^0; //蜂鸣器 ***it DS_DS = P3^4; ***it DS_RW = P3^5; ***it DS_AS = P3^6; ***it DS_CS = P3^7; void delayms(uint); void DS_init(); uchar hr,sec,min,num,k1_num,k1_flag; uchar qian,bai,shi,ge; uchar code table[] = { 0x3f,0x06,0x5b,0x4f,0x66, 0x6d,0x7d,0x07,0x7f,0x6f, }; void delayms(uint z) { uint i,j; for(i=z;i>0;i--) for(j=110;j>0;j--); } //时钟写 void write_ds(uchar add,uchar date) { DS_CS = 0; DS_AS = 1; DS_DS = 1; DS_RW = 1; P0 = add; DS_AS = 0; DS_RW = 0; P0 = date; DS_RW = 1; DS_AS = 1; DS_CS = 1; } //时钟读 uchar read_ds(uchar add) { uchar DS_date; DS_AS = 1; DS_DS = 1; DS_RW = 1; DS_CS = 0; P0 = add; DS_AS = 0; DS_DS = 0; P0 = 0xff; DS_date = P0; DS_DS = 1; DS_AS = 1; DS_CS = 1; return(DS_date); } void set_time()//设定时间 { write_ds(0,0); //秒 write_ds(2,43); //分 write_ds(4,3); //时 } //初始化时钟 void DS_init() { DS_AS=0; DS_DS=0; DS_RW=0; write_ds(0x0A,0x20); //打开晶振,开始计时 write_ds(0x0B,0x26); //设置24小时模式,数据二进制,开启闹钟中断 set_time(); //实际应用中set_alarm()和set_time()仅第一次烧写需要 } void display_smg(uchar qian,uchar bai,uchar shi,uchar ge)//以下显示程序不加887显示是正常的 { wela1 = wela2 = wela3 = wela4 = 0; wela4 = 1; P1=table[qian]; delayms(5); wela4 = 0; P1 = 0x00; wela3=1; P1=table[bai]; delayms(5); wela3 = 0; P1=0x00; wela2=1; P1=table[shi]; delayms(5); wela2 = 0; P1=0x00; wela1=1; P1=table[ge]; delayms(5); wela1 = 0; P1=0x00; } void keyscan()//按键功能 { if(k1==0)//选择键按下 { delayms(5); if(k1==0) { k1_num++; k1_flag=1; while(!k1); } } switch(k1_num) { case 1: display_smg(qian,bai,shi,ge); break; case 2: display_smg(qian,bai,shi,ge); break; case 3: k1_num=0; k1_flag=0; break; } if(k1_num!=0) { if(k2==0)//加键按下 { delayms(5); if(k2==0) { while(!k2); switch(k1_num) { case 1: min++; if(min==60) min=0; shi=min/10;//分钟的十位 ge=min%10;//分钟的个位 display_smg(qian,bai,shi,ge); write_ds(2,min); break; case 2: hr++; if(hr==24) hr=0; qian=hr/10;//时钟的十位 bai=hr%10;//时钟的个位 display_smg(qian,bai,shi,ge); write_ds(4,hr); break; } } } if(k3==0)//减键按下 { delayms(5); if(k3==0) { while(!k3); switch(k1_num) { case 1: min--; if(min==-1) min=59; shi=min/10;//分钟的十位 ge=min%10;//分钟的个位 display_smg(qian,bai,shi,ge); write_ds(2,min); break; case 2: shi--; if(shi==-1) shi=23; qian=hr/10;//时钟的十位 bai=hr%10;//时钟的个位 display_smg(qian,bai,shi,ge); write_ds(4,hr); break; } } } } } /*void shanshuo()//闪烁部分暂时不写 { } */ void main()//主函数 { DS_init(); while(1)//大循环 { keyscan(); if(k1_flag==0)//在S1没有按下时,flag为0 { hr=read_ds(4); //读取时 min=read_ds(2);//读取分 sec=read_ds(0);//读秒 } //shanshuo(); qian=hr/10;//时钟的十位 bai=hr%10;//时钟的个位 shi=min/10;//分钟的十位 ge=min%10;//分钟的个位 display_smg(qian,bai,shi,ge);//调用显示函数 } } |
5个回答
麻烦看下哪里问题~我都觉得是887是否坏了
哈哈 不知道,有ds1302的。
一位887这个芯片会精确些,所以
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
250 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
473 浏览 2 评论
571 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-内核编译之初次编译
260 浏览 0 评论
400 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11976 浏览 31 评论
GMT+8, 2024-12-20 07:55 , Processed in 0.688508 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
