PCB覆铜技巧都有哪些呢?pcb覆铜设置方法呢?pcb覆铜的主要作用在于“回流和屏蔽”。pcb覆铜多用网格方式来进行。双面pcb覆铜厚度约为35um(1.4mil);50um是不常见的;pcb覆铜多层板表层为35um(1.4mil),内层为17.5um(0.7mil)。pcb覆铜厚度也有用OZ(盎司)表示的。pcb覆铜的好处就是“提高电源效率,减少高频干扰,提高美观度”。讲了那么多的pcb覆铜的知识,那么pcb覆铜技巧及设置?我们现在就马上来介绍系“pcb覆铜技巧及设置?”。
pcb覆铜技巧之大面积敷铜、网格铜哪一种好? 1、经常也有人问到,大面积覆铜好还是网格覆铜好,不好一概而论。为什么呢?大面积敷铜,具备了加大电流和屏蔽双重作用,但是大面积覆铜,如果过波峰焊时,板子就可能会翘起来,甚至会起泡。因此大面积敷铜,一般也会开几个槽,缓解铜箔起泡。 2、单纯的网格敷铜主要还是屏蔽作用,加大电流的作用被降低了,从散热的角度说,网格有好处(它降低了铜的受热面)又起到了一定的电磁屏蔽的作用。但是需要指出的是,网格是使由交错方向的走线组成的,我们知道对于电路来说,走线的宽度对于电路板的工作频率是有其相应的“电长度“的(实际尺寸除以工作频率对应的数字频率可得,具体可见相关书籍),当工作频率不是很高的时候,或许网格线的作用不是很明显,一旦电长度和工作频率匹配时,就非常糟糕了,你会发现电路根本就不能正常工作,到处都在发射干扰系统工作的信号。所以对于使用网格的同仁,我的建议是根据设计的电路板工作情况选择,不要死抱着一种东西不放。因此高频电路对抗干扰要求高的多用网格,低频电路有大电流的电路等常用完整的铺铜。 pcb覆铜与导线或过孔间距设置? 菜单栏-设计-规则-electrical-clearance-选中右键-新规则-左键点中新规则-右边出现设置框-在上面的“wherethefirstobjectmatches”框下面的高级旁边,点“询问构建器”-左边的条件类型点中出现的下拉框选择“objectkindis”,右边的“条件值”选择“poly”-确定-设置框右边出现“Ispolygon”,将其改为“Inpolygon”,即第二个字母S改为N-在最底下的约束条件里面选择最小间隔! PCB爱好者们的聚集地,期待你们的加入↓↓↓ (此群仅用于技术交流与学习讨论,群内不定时资料分享) 无法入群时,可添加管理员微信zcoreplayer007(请备注:PCB群)
31
评分
查看全部评分
gfjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj
