Motion是一个开源的移动图像监控的程序 下载地址: ********************************************** 输出如下 Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will beinstalled: libjpeg62 libpq5 Suggested packages: mysql-client postgresql-client Recommended packages: ffmpeg The following NEW packages will beinstalled: libjpeg62 libpq5 motion 0 upgraded, 3 newly installed, 0 to removeand 26 not upgraded. Need to get 360 kB of archives. After this operation, 1067 kB of additionaldisk space will be used. Do you want to continue [Y/n]? y Get:1 http://ports.ubuntu.com/ubuntu-ports/precise-security/main libjpeg62 ARMh f 6b1-2ubuntu1.1 [72.6 kB] Get:2 http://ports.ubuntu.com/ubuntu-ports/precise-updates/main libpq5 armhf 9. 1.18-0ubuntu0.12.04 [73.3 kB] Get:3 http://ports.ubuntu.com/ubuntu-ports/precise/universe motion armhf 3.2.12 -3.1 [214 kB] Fetched 360 kB in 3s (106 kB/s) Preconfiguring packages ... Selecting previously unselected packagelibjpeg62. (Reading database ... 68981 files anddirectories currently installed.) Unpacking libjpeg62 (from.../libjpeg62_6b1-2ubuntu1.1_armhf.deb) ... Selecting previously unselected packagelibpq5. Unpacking libpq5 (from .../libpq5_9.1.18-0ubuntu0.12.04_armhf.deb)... Selecting previously unselected packagemotion. Unpacking motion (from.../motion_3.2.12-3.1_armhf.deb) ... Processing triggers for ureadahead ... Setting up libjpeg62 (6b1-2ubuntu1.1) ... Setting up libpq5 (9.1.18-0ubuntu0.12.04)... Setting up motion (3.2.12-3.1) ... Adding group `motion' (GID 115) ... Done. Adding system user `motion' (UID 109) ... Adding new user `motion' (UID 109) withgroup `motion' ... Not creating home directory `/home/motion'. Adding user `motion' to group `video' ... Adding user motion to group video Done. *Not starting motion daemon, disabled via /etc/default/motion Processing triggers for libc-bin ... ldconfig deferred processing now takingplace 完成后开启 root@ubuntu:~# motion -c motion-dist.conf 输出信息如下 [0] Configfile motion-dist.conf not found -trying defaults.: No such file or directory [0] Processing thread 0 - config file/etc/motion/motion.conf [0] Motion 3.2.12 Started [0] ffmpeg LIBAVCODEC_BUILD 3482112LIBAVFORMAT_BUILD 3478528 [0] Thread 1 is from/etc/motion/motion.conf [1] Thread 1 started [1] cap.driver: "uvcvideo" [1] cap.card: "PC Camera" [1] cap.bus_info: "u***-sw-ehci-1" [1] cap.capabilities=0x04000001 [1] - VIDEO_CAPTURE [1] - STREAMING [1] Config palette index 8 (YU12) doesn'twork. [1] Supported palettes: [1] 0: MJPG (MJPEG) [1] 1: YUYV (YUV 4:2:2 (YUYV)) [1] Selected palette YUYV [0] motion-httpd/3.2.12 running, acceptingconnections [0] motion-httpd: waiting for data on portTCP 8080 [1] Test palette YUYV (320x240) [1] Using palette YUYV (320x240)bytesperlines 640 sizeimage 153600 colorspace 00000008 [1] found control 0x00980900,"Brightness", range -255,255 [1] "Brightness", default 0, current 0 [1] found control 0x00980901,"Contrast", range 0,30 [1] "Contrast", default 15, current 15 [1] found control 0x00980902,"Saturation", range 0,127 [1] "Saturation", default 32, current 32 [1] found control 0x00980903,"Hue", range -16000,16000 [1] "Hue", default 0, current 0 [1] found control 0x00980910,"Gamma", range 20,250 [1] "Gamma", default 100, current 100 [1] mmap information: [1] frames=4 [1] 0 length=153600 [1] 1 length=153600 [1] 2 length=153600 [1] 3 length=153600 [1] Using V4L2 [1] Resizing pre_capture buffer to 1 items [1] Started stream webcam server in port8081 在浏览器中输入192.168.1.122:8081 没有看到视频信息 手动安装ffmpeg库 sudo apt-get install ffmpeg 再次运行还是不行 需要修改motion.conf文件 该文件在/etc/motion/motion.conf vim /etc/motion/motion.conf 修改# Restrict webcam connections to localhost only (default: on) webcam_localhost off 限制仅本地通过网页访问视频 再次运行: root@ubuntu:/etc/motion# motion -cmotion.conf 在浏览器中输入192.168.1.122:8081 成功看到视频 |
相关推荐 |
只有小组成员才能发言,加入小组>>
「含关键代码」基于AM3352/AM3354/AM3359的Linux开发案例分享
4728 浏览 0 评论
87129 浏览 0 评论
【高手问答】如何做到精通linux技术?资深工程师带你突破难点
4349 浏览 2 评论
3357 浏览 2 评论
解读Linux :先从创建一个文件夹用来存放jdk压缩文件开始
2319 浏览 0 评论
1545浏览 3评论
这是i.mx6ull的关于usb的宏定义,能解释下这些宏定义的意思
1159浏览 1评论
787浏览 1评论
求解:aarch64交叉编译工具已经安装成功,环境变量已经配置,怎么将系统架构切换为ARM的架构
927浏览 0评论
1453浏览 0评论
GMT+8, 2024-7-13 13:08 , Processed in 0.876305 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
