## Booting kernel from Legacy Image at 30000000 ...
Image Name: Linux-3.17.2 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1427952 Bytes = 1.4 MiB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK kernel data at 0x30000040, len = 0x0015c9f0 (1427952) ## Flattened Device Tree blob at 38000000 Booting using the fdt blob at 0x38000000 Loading Kernel Image ... OK kernel loaded at 0x30008000, end = 0x301649f0 images.os.start = 0x30000000, images.os.end = 0x3015ca30 images.os.load = 0x30008000, load_end = 0x301649f0 using: FDT Loading Device Tree to 4fcbe000, end 4fcc74f5 ... OK ## Transferring control to Linux (at address 30008000)... Starting kernel ... Uncompressing Linux... done, booting the kernel. __atags_pointer is 4FCBE000 Now setup_machine_fdt phys_to_virt(dt_phys) is 9FCBE000 setup_machine_fdt stop! return NULL no return _machine_arch_type = Samsung S5PC110/S5PV210-based board Booting Linux on physical CPU 0x0 Linux version 3.17.2 (tom@tom-virtual-machine) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #17 PREEMPT Thu Sep 24 00:08:00 CST 2015 CPU: ARMv7 Processor [412fc082] revision 2 (ARMv7), cr=10c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache __atags_pointer is 4FCBE000 Now setup_machine_fdt phys_to_virt(dt_phys) is 9FCBE000 setup_machine_fdt stop! return NULL no return Machine model: YIC System SMDKV210 based on S5PV210 _machine_arch_type = Samsung S5PC110/S5PV210-based board debug: ignoring loglevel setting. bootconsole [earlycon0] enabled Memory policy: Data cache writeback On node 0 totalpages: 131072 free_area_init_node: node 0, pgdat 802b3f84, node_mem_map 9f8be000 Normal zone: 1024 pages used for memmap Normal zone: 0 pages reserved Normal zone: 131072 pages, LIFO batch:31 CPU: All CPU(s) started in SVC mode. pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 Kernel command line: noinitrd root=/dev/mtdblock5 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200n8 rw rootwait ignore_loglevel earlyprintk mem=512M PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 516652K/524288K available (1851K kernel code, 153K rwdata, 600K rodata, 127K init, 205K bss, 7636K reserved) Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xffe00000 (2048 kB) vmalloc : 0xa0800000 - 0xff000000 (1512 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) modules : 0x7f000000 - 0x80000000 ( 16 MB) .text : 0x80008000 - 0x8026cf64 (2452 kB) .init : 0x8026d000 - 0x8028cfc4 ( 128 kB) .data : 0x8028e000 - 0x802b46c0 ( 154 kB) .bss : 0x802b46c0 - 0x802e7db4 ( 206 kB) SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Preemptible hierarchical RCU implementation. NR_IRQS:16 nr_irqs:16 16 VIC @a0800000: id 0x00041192, vendor 0x41 VIC @a0802000: id 0x00041192, vendor 0x41 VIC @a0804000: id 0x00041192, vendor 0x41 VIC @a0806000: id 0x00041192, vendor 0x41 S5PV210 clocks: mout_apll = 0, mout_mpll = 0 mout_epll = 0, mout_vpll = 0 Kernel panic - not syncing: failed to get timers clock for timer CPU: 0 PID: 0 Comm: swapper Not tainted 3.17.2 #17 [<800126c8>] (unwind_backtrace) from [<800108fc>] (show_stack+0x10/0x14) [<800108fc>] (show_stack) from [<801bc53c>] (panic+0x8c/0x1ec) [<801bc53c>] (panic) from [<80281e54>] (samsung_pwm_alloc+0x104/0x12c) [<80281e54>] (samsung_pwm_alloc) from [<80281a8c>] (clocksource_of_init+0x48/0x8c) [<80281a8c>] (clocksource_of_init) from [<8026da1c>] (start_kernel+0x214/0x37c) [<8026da1c>] (start_kernel) from [<30008070>] (0x30008070) ---[ end Kernel panic - not syncing: failed to get timers clock for timer 如打印信息所示,时钟没有获取成功,请问有朋友遇到类似的问题吗 |
1个回答
请排版之后重新发帖
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于米尔MYC-LR3576开发板的实时视频识别系统设计与实现
220 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的深入学习之阻塞I/O与非阻塞I/O
453 浏览 0 评论
大神们,想知道你们都用什么ide编程调试器? Arduino IDE?还是 e2studio ?还有其他吗?哪个好用呢
555 浏览 0 评论
854 浏览 0 评论
825 浏览 0 评论
/9
GMT+8, 2025-12-2 22:22 , Processed in 0.682839 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3754
