在天嵌的TQ210开发板上按照天嵌提供的说明书把uboot,内核,文件系统都做好后,今天尝试写一个led的驱动, 1、看电路图,找到led连接哪个引脚。由图可见,开发板上的两个led分别连接在GPC0_3和GPC0_4的两个引脚上。 2、打开s5pv210的芯片手册,搜索一下GPC0CON[4]在2-48页找到GPC0CON的地址为 :Address = 0xE020_0060,下面还有GPC0DAT的地址为: Address = 0xE020_0064 有图可以看出s5pv210不同于2440,s5pv210每个引脚由4位来配置,我们要把GPC0CON[4]、GPC0CON[3]这两个引脚配置成输出(Output)。 3、接下来就可以写驱动程序了: *******************led_drv.c*********************** include #include #include #include #include #include #include #include #include #include //device_create(),class_create()的头文件 #include //定义出这两寄存器 volatile unsigned long *gpc0con = NULL; volatile unsigned long *gpc0dat = NULL; //volatile struct unsigned long *gpc1con = NULL; static struct class *leddrv_class; int major; static int led_drv_open(struct inode *inode, struct file *file) { printk("liu guo feng open led_drvn"); /*配置GPC1 3 4为输出引脚*/ //寄存器清0 *gpc0con &= ~((0xf<<(3*4)) | (0xf<<(4*4))); //*gpc1con = 0x00000000; //设置为输出引脚 *gpc0con |= ((0x1<<(3*4)) | (0x1<<(4*4))); return 0; } static ssize_t led_drv_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos) { int val; //用户空间向内核空间传递数据 copy_from_user(&val, buf, count);//内核空间向用户空间传递数据copy_to_user printk("val=%dn",val); if(val == 1) { //点灯 *gpc0dat |= ((1<<3) | (1<<4)); // *gpc1dat = 0xff; printk("led onn"); } else { //灭灯 *gpc0dat &= ~((1<<3) | (1<<4)); // *gpc1dat |= ((1<<3) | (1<<4)); //*gpc1dat = 0xff; printk("led offn"); } //printk("liu guo feng write led_drvn"); return 0; } //定义了这样的一个结构 static struct file_operations led_drv_fops = { .owner = THIS_MODULE, //这是一个宏 .open = led_drv_open, .write = led_drv_write, }; //入口函数 int led_drv_init(void) { major = register_chrdev(0, "led_drv", &led_drv_fops); //在sys的目录下会创建一个leddrv目录 leddrv_class = class_create(THIS_MODULE, "leddrv"); //在leddrv目录下创建xyz,里面有主、次设备号,而mdev会动态地在创建/dev/xyz device_create(leddrv_class, NULL, MKDEV(major, 0), NULL, "led"); /* /dev/led*/ //把物理地址映射成虚拟地址 gpc0con = (volatile unsigned long *)ioremap(0xE0200060,16); //gpc0dat = (volatile unsigned long *)ioremap(0xE0200064,16); gpc0dat = gpc0con + 1; return 0; } void led_drv_exit(void) { unregister_chrdev(major, "led_drv"); //对应的卸载 device_destroy(leddrv_class,MKDEV(major, 0)); class_destroy(leddrv_class); //取消映射 iounmap(gpc0con); } module_init(led_drv_init); module_exit(led_drv_exit); MODULE_LICENSE("GPL"); ******************Makefile********************************* KERN_DIR = /opt/EmbedSky/TQ210/Kernel_2.6.35.7_TQ210_for_Linux_v1.1 all: make -C $(KERN_DIR) M=`pwd` modules clean: make -C $(KERN_DIR) M=`pwd` modules clean rm -rf modules.order obj-m += led_drv.o ********************************************************* 上面的KERN_DIR = /opt/EmbedSky/TQ210/Kernel_2.6.35.7_TQ210_for_Linux_v1.1是内核的路径 把上面两个文件复制到linux下,执行make命令就可以生成led_drv.ko的驱动文件 下面还要写一个测试文件: ***********************leddrvtest.c********************************* #include #include #include #include /* leddrvtest on leddrvtest off */ int main(int argc,char **argv) { int fd; int val = 1; fd = open("/dev/led",O_RDWR); if(fd < 0) printf("can't open!n"); //传进来的参数个数argc if(argc !=2) { printf("Usage:n"); printf("%s return 0; } if( strcmp(argv[1],"on") == 0) { val=1; } else { val = 0; } write(fd, &val, 4); return 0; } ************************************************ 把leddrvtest.c复制到linux下。 执行arm-linux-gcc -o leddrvtest leddrvtest.c 就可以生成leddrvtest的测试文件 把led_drv.ko和leddrvtest复制到开发板的根文件系统下, 我的开发板已经使用NFS挂载根文件系统。连接好后给开发板上电。 在开发板上执行insmod led_drv.ko添加驱动。 执行./leddrvtest on 灯打开了。 执行./leddrvtest off 灯关闭了。 相关产品: http://www.embedsky.com/index.php?s=/Product/show/id/47.html http://www.embedsky.com/index.php?s=/Product/show/id/80.html http://www.embedsky.com/index.php?s=/Product/show/id/43.html |
iTOP-3A5000主控板龙芯架构外加机箱就是一台电脑主机
907 浏览 0 评论
迅为RK3568开发板EMMC镜像导出打包update.img
951 浏览 0 评论
飞凌嵌入式-ELFBOARD 硬件知识分享-ELF 2电源电路讲解
1403 浏览 0 评论
2108 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-mfgtools烧录流程介绍之烧写所需镜像
1728 浏览 0 评论
GMT+8, 2024-12-30 01:41 , Processed in 0.654337 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
