电子发烧友论坛|
如题,之前只做过51的i2c通信,现在想在msp430上做i2c通信,时钟怎么选择,波特率如何配置,以及发送、接收过程,应该注意的问题,求大神指教,如果有例程最好了,谢谢!
4个回答
你之前在51上写的那个IIC就是最好的例子!
#include "msp430g2553.h" unsigned char TXData; unsigned char TXByteCtr; void main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop WDT P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz UCB0BR1 = 0; UCB0I2CSA = 0x48; // Slave Address is 048h UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation IE2 |= UCB0TXIE; // Enable TX interrupt TXData = 0x00; // Holds TX data while (1) { TXByteCtr = 1; // Load TX byte counter while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts // Remain in LPM0 until all data // is TX'd TXData++; // Increment data byte } } //------------------------------------------------------------------------------ // The USCIAB0TX_ISR is structured such that it can be used to transmit any // number of bytes by pre-loading TXByteCtr with the byte count. //------------------------------------------------------------------------------ #pragma vector = USCIAB0TX_VECTOR __interrupt void USCIAB0TX_ISR(void) { if (TXByteCtr) // Check TX byte counter { UCB0TXBUF = TXData; // Load TX buffer TXByteCtr--; // Decrement TX byte counter } else { UCB0CTL1 |= UCTXSTP; // I2C stop condition IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag __bic_SR_register_on_exit(CPUOFF); // Exit LPM0 } } |
不错的资料,谢谢分享。。。。
只有小组成员才能发言,加入小组>>
3326个成员聚集在这个小组
加入小组9546 浏览 1 评论
10350 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
10671 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2657 浏览 1 评论
5113 浏览 1 评论
10677浏览 2评论
10355浏览 1评论
9555浏览 1评论
8214浏览 0评论
/9
GMT+8, 2025-12-1 20:56 , Processed in 0.651744 second(s), Total 80, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3825
