基于8950单片机和PCF8591转换器和LCD显示屏的实现。
想把这里面的报警部分去掉和大概功能就是通过改变电压大小再通过A/D转换器把电压信号传到单片机再传到LCD显示屏(程序部分我不太明白)求大神帮忙,再有一个星期就要答辩了!!就差程序实现! 下面是我在网上找的一个代码: include"reg51.h" include define DD P2 ***it CS=P1^0; ***it CLK=P1^1; ***it Do=P1^2; ***it Di=P1^3; ***it KEY=P1^7; ***it buzzer=P0^0; ***it Rs=P1^4; ***it Rw=P1^5; ***it E=P1^6; ***it busy_p=ACC^7; unsigned char CH=0x02,key_count=1; unsigned char HC[6]={0}; unsigned char BZ=0; void delay_1ms(unsigned char i) { unsigned char j; while(i--) for(j=0;j<125; j++); } void delay_10ns(unsigned char i) { unsigned char j; while(i--) for(j=0;j<10; j++); } void xiezhiling(unsigned char com,bit p) { if(p) delay_10ns(5); E=0; Rs=0; Rw=0; DD=com; delay_10ns(50); E=1; delay_1ms(2); E=0; delay_10ns(4); } void xieshuju(unsigned char DATA) { delay_10ns(50); E=0; Rs=1; Rw=0; DD=DATA; delay_10ns(50); E=1; 39 delay_10ns(50); E=0; delay_10ns(4); } void init(void) { delay_1ms(15); xiezhiling(0x38,0); delay_1ms(5); xiezhiling(0x38,0); delay_1ms(5); xiezhiling(0x38,0); delay_1ms(5); xiezhiling(0x38,1); xiezhiling(0x08,1); xiezhiling(0x01,1); xiezhiling(0x06,1); xiezhiling(0x0c,1); } unsigned char ADconv(void) { unsigned char i; unsigned intdata_f=0,data_c=0; Di=1; CS=1; _nop_(); CS=0; Di=1; ; CLK=1; _nop_(); _nop_(); CLK=0; _nop_(); _nop_(); CLK=1; Di=(bit)(0x02&CH); _nop_(); CLK=0; _nop_(); _nop_(); CLK=1; Di=(bit)(0x01&CH); _nop_(); _nop_(); CLK=0; Di=1; CLK=1; _nop_(); _nop_(); CLK=0; _nop_(); CLK=1; for(i=8;i>0;i--) { data_f|=Do; data_f<<=1; CLK=1; _nop_(); _nop_(); CLK=0; _nop_(); } for(i=8;i>0;i--) { data_c<<=1; data_c|=Do; _nop_(); CLK=1; _nop_(); _nop_(); CLK=0; _nop_(); } CLK=0; _nop_(); _nop_(); CLK=1; _nop_(); _nop_(); CLK=0; _nop_(); _nop_(); CLK=1; _nop_(); CS=1; _nop_(); _nop_(); return daa_f; } void xs_int(unsigned int shuju) { if(shuju < 10) BZ = 1; else if(shuju < 100) BZ =2; else if(shuju < 1000) BZ =3; else if(shuju < 10000) BZ= 4; else if(shuju < 65535) BZ= 5; switch(BZ) { case 5:HC[5] = shuju/10000; case 4:HC[3] =shuju%10000/1000; case 3:HC[2] =shuju%1000/100; case 2:HC[1] =shuju%100/10; case 1:HC[0] = shuju%10; break; default:break; } } void main(void) { unsigned int data_temp=0; init(); TMOD=0x01; TH0=(65536-50000)/256; TL0=(65536-50000)%256; ET0=1; TR0=1; while(1) { data_temp=ADconv(); if(data_temp>128) { EA=1; } else { EA=0; buzzer=0; } P3=~data_temp; xs_int(196*data_temp); if(KEY==0) { delay_1ms(10); if(KEY==0) while(!KEY); key_count++; if(key_count==3) key_count=1; xiezhiling(0x01,0); } if(key_count==1) { xiezhiling(0x80,1); xieshuju('P'); xieshuju('R); xieshuju('E'); xieshuju('S); xieshuju('S'); xieshuju('U'); xieshuju('R); xieshuju('E'); xieshuju('-'); xieshuju(HC[5]+0x30); xieshuju(HC[3]+0x30); xieshuju(HC[2]+0x30); xieshuju('.'); xieshuju(HC[1]+0x30); xieshuju('P'); xieshuju('a'); xiezhiling(0x80+0x40,1); xieshuju('A'); xieshuju('l'); xieshuju('a'); xieshuju('r'); xieshuju('m'); xieshuju(' '); xieshuju('S'); xieshuju('t'); xieshuju('a'); xieshuju('t'); xieshuju('u'); xieshuju('s'); xieshuju('-'); xieshuju('-'); xieshuju('O'); xieshuju('N'); } if(key_count==2) { xiezhiling(0x80,1); xieshuju('P'); xieshuju('r'); xieshuju('e'); xieshuju('s'); xieshuju('s'); xieshuju('u'); xieshuju('r'); xieshuju('e'); xieshuju(' '); xieshuju('i'); xieshuju('s'); xieshuju(' '); xieshuju('O'); xieshuju('K'); xieshuju(' '); xieshuju(' '); xiezhiling(0x80+0x40,1); xieshuju('m '); xieshuju('a'); xieshuju('d'); xieshuju('e'); xieshuju(' '); xieshuju('B'); xieshuju('Y'); xieshuju(' '); xieshuju('y'); xieshuju('u'); xieshuju('a'); xieshuju('n'); xieshuju('s'); xieshuju('h'); xieshuju('u'); xieshuju('o'); xieshuju(' '); } } } void timer0() interrupt 1 { TH0=(65536-50000)/256; TL0=(65536-50000)%256; buzzer=!buzzer;} |
1个回答
PCF8591是用来AD采集还有一路DA。你又加了显示模块,你的毕业设计具体做什么的。PCF591小弟我N年前就用烂了
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
135 浏览 0 评论
1160 浏览 0 评论
2050 浏览 0 评论
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
1014 浏览 0 评论
3371 浏览 2 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
7086 浏览 31 评论
GMT+8, 2024-5-21 12:08 , Processed in 0.705394 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
