`描述及特性 It is a two phase Synchronous Buck converter to provide high current with low ripple and fast dynamic response for high speed processor core applications. Same approach can also be used to power Memory and Input / Output power voltages, typically 1.2V to 3.3V. The two phase interleave reduces output ripple and allows faster response to rapidly changing loads. The two phases distribute power loss to eliminate need for added heat sink hardware. The "Project File" for the TPS40422 to communicate with TI's Fusion GUI is included. Output voltage and current limit can be adjusted and monitored thru the GUI. Additional settings can be accessed thru the same GUI. Test Report includes thermal images to show load capability, both with and without fan cooling. Testing done at 12Vin, where voltage stresses, losses and output ripple greatest. Design will work also at 5Vin with same high speed control loop, due to Input Voltage Feed Forward in the TPS40422.
PMP8999 Schematic.pdf
(165.52 KB, 下载次数: 2
PMP8999 Test Results.pdf
(629.03 KB, 下载次数: 2
PMP8999 BOM.pdf
(113.2 KB, 下载次数: 2
PMP8999 PCB.pdf
(830.86 KB, 下载次数: 2
只有小组成员才能发言,加入小组>>
47838 浏览 1 评论
2456 浏览 2 评论
6876 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
77430 浏览 2 评论
60703 浏览 0 评论
2461浏览 2评论
77511浏览 2评论
113024浏览 1评论
3627浏览 1评论
4888浏览 1评论
GMT+8, 2024-9-29 05:58 , Processed in 3.024323 second(s), Total 66, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
