#include
#include ***it RS = P2^4; //定义端口 ***it RW = P2^5; ***it EN = P2^6; #define RS_CLR RS=0 #define RS_SET RS=1 #define RW_CLR RW=0 #define RW_SET RW=1 #define EN_CLR EN=0 #define EN_SET EN=1 #define uchar unsigned char #define DataPort P1 /*------------------------------------------------ mS延时函数 ------------------------------------------------*/ void DelayUs2x(unsigned char t) { while(--t); } void DelayMs(unsigned char t) { while(t--) { //大致延时1mS DelayUs2x(245); DelayUs2x(245); } } /*------------------------------------------------ 判忙函数 ------------------------------------------------*/ bit LCD_Check_Busy(void) { DataPort= 0xFF; RS_CLR; RW_SET; EN_CLR; _nop_(); EN_SET; return (bit)(DataPort & 0x80); } /*------------------------------------------------ 写入命令函数 ------------------------------------------------*/ void LCD_Write_Com(unsigned char com) { // while(LCD_Check_Busy()); //忙则等待 DelayMs(5); RS_CLR; RW_CLR; EN_SET; DataPort= com; _nop_(); EN_CLR; } /*------------------------------------------------ 写入数据函数 ------------------------------------------------*/ void LCD_Write_Data(unsigned char Data) { //while(LCD_Check_Busy()); //忙则等待 DelayMs(5); RS_SET; RW_CLR; EN_SET; DataPort= Data; _nop_(); EN_CLR; } /*------------------------------------------------ 清屏函数 ------------------------------------------------*/ void LCD_Clear(void) { LCD_Write_Com(0x01); DelayMs(5); } /*------------------------------------------------ 写入字符串函数 ------------------------------------------------*/ void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s) { if (y == 0) { LCD_Write_Com(0x80 + x); //表示第一行 } else { LCD_Write_Com(0xC0 + x); //表示第二行 } while (*s) { LCD_Write_Data( *s); s ++; } } /*------------------------------------------------ 写入字符函数 ------------------------------------------------*/ void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data) { if (y == 0) { LCD_Write_Com(0x80 + x); } else { LCD_Write_Com(0xC0 + x); } LCD_Write_Data( Data); } /*------------------------------------------------ 初始化函数 ------------------------------------------------*/ void LCD_Init(void) { LCD_Write_Com(0x38); /*显示模式设置*/ DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); LCD_Write_Com(0x08); /*显示关闭*/ LCD_Write_Com(0x01); /*显示清屏*/ LCD_Write_Com(0x06); /*显示光标移动设置*/ DelayMs(5); LCD_Write_Com(0x0C); /*显示开及光标设置*/ } #define uint unsigned int ***it P27=P2^7; ***it EOC=P2^3; ***it ST=P3^0; ***it OE=P3^1; uchar getdata = 0; uchar code table[]="0123456789";//定义显示的数组 uchar q,b,s,g; void adc0809(void) { uchar i; float temp=0.0; ST=0;//ADC0809初始化 ST=1; _nop_(); _nop_(); ST=0; for(i=0;i<20;i++) while(EOC==0)//等待转换完成 { OE=1; getdata=P0;//p2选择为ADC的数据口 OE=0; } temp=(float)getdata*5.0/256;//数据处理 temp=temp/100.0; temp=temp*100000.0; q=(int)temp/1000; b=(int)temp%1000/100; s=(int)temp%1000%100/10; g=(int)temp%10; } void main(void) { LCD_Init(); OE=0; while (1) { LCD_Write_String(0,0,"current value:"); adc0809(); LCD_Write_Com(0x80+0x40);//1602显示处理好的数据 { LCD_Write_Data(table[q]); DelayMs(20); LCD_Write_Data(table[b]); DelayMs(20); LCD_Write_Data(table[s]); DelayMs(20); LCD_Write_Data(table[g]); DelayMs(20); } } 应该如何修改呢?? |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
《DNESP32S3使用指南-IDF版_V1.6》第三十五章 摄像头实验
757 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第三十章 DHT11数字温湿度传感器
728 浏览 0 评论
826 浏览 0 评论
【敏矽微ME32G070开发板免费体验】之原厂2812测试例程解析
1459 浏览 0 评论
1208 浏览 2 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
12057 浏览 31 评论
GMT+8, 2024-12-29 05:57 , Processed in 0.588137 second(s), Total 69, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
