扫一扫,分享给好友
具体的错误是
+ make ARCH=arm CROSS_COMPILE= HOSTCC=ccache /usr/bin/gcc -B/usr/bin/ oldconfig scripts/kconfig/conf --oldconfig Kconfig # # configuration written to .config # + [ -f /home/znzx/Desktop/ltib/config/platform/imx/imx6_defconfig.dev ] + diff -q ./.config /home/znzx/Desktop/ltib/config/platform/imx/imx6_defconfig.dev + [ -n ] + grep -q VERSION = 2 Makefile + [ %{kernel_series} = 2.4 ] + make ARCH=arm CROSS_COMPILE= HOSTCC=ccache /usr/bin/gcc -B/usr/bin/ uImage scripts/kconfig/conf --silentoldconfig Kconfig CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CC kernel/bounds.s arm-linux-gnueabihf-gcc: error: -mfloat-abi=soft and -mfloat-abi=hard may not be used together make[1]: *** [kernel/bounds.s] Error 1 make: *** [prepare0] Error 2 make: *** Waiting for unfinished jobs.... CC scripts/mod/empty.o arm-linux-gnueabihf-gcc: error: -mfloat-abi=soft and -mfloat-abi=hard may not be used together make[2]: *** [scripts/mod/empty.o] Error 1 make[1]: *** [scripts/mod] Error 2 make[1]: *** Waiting for unfinished jobs.... make: *** [scripts] Error 2 error: Bad exit status from /home/znzx/Desktop/ltib/tmp/rpm-tmp.39089 (%build) RPM build errors: Bad exit status from /home/znzx/Desktop/ltib/tmp/rpm-tmp.39089 (%build) Build time for kernel-3.0.35: 10 seconds Failed building kernel-3.0.35 f_buildrpms() returned an error, exiting traceback: main:572 Started: Fri Apr 17 14:54:31 2015 Ended: Fri Apr 17 14:55:25 2015 Elapsed: 54 seconds These packages failed to build: kernel-3.0.35 Build Failed |
当我不编译uboot和kernel时,执行./ltib -c,报错是
+ [ -n ] + [ -f /home/znzx/Desktop/ltib/config/.config ] + cat /home/znzx/Desktop/ltib/config/.config + perl -ne print if m,^CONFIG_(?!PCF), + [ ! -f config/platform/imx/.config -a -f config/platform/imx/defconfig ] + [ -n ] + cd config/platform/imx + mconf main.lkc .config *** End of configuration. *** Check the top-level Makefile for additional configuration options. + cp .config defconfig.dev Processing platform: Freescale iMX6x Based Boards =================================================== using config/platform/imx/.config Processing: fake-provides =========================== Processing: skell =================== Processing: base_libs ======================= sudo /opt/freescale/ltib/usr/bin/rpm --root /home/znzx/Desktop/ltib/rootfs --dbpath /var/lib/rpm -e --allmatches --nodeps --define '_tmppath /tmp/ltib' base_libs 2>/dev/null sudo /opt/freescale/ltib/usr/bin/rpm --root /home/znzx/Desktop/ltib/rootfs --dbpath /var/lib/rpm --prefix / --ignorearch -ivh --force --excludedocs --define '_tmppath /tmp/ltib' /home/znzx/Desktop/ltib/rpm/RPMS/arm/base_libs-1.2-1.arm.rpm error: failed dependencies: ld-linux.so.3(GLIBC_2.4) is needed by base_libs-1.2-1 f_buildrpms() returned an error, exiting traceback: main:572 Started: Fri Apr 17 14:56:45 2015 Ended: Fri Apr 17 14:56:59 2015 Elapsed: 14 seconds |
我也遇到该问题, error: failed dependencies: ld-linux.so.3(GLIBC_2.4) is needed by base_libs-1.2-1 请问最后怎么解决的? |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
999 浏览 0 评论
2781 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9368 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2895 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2300 浏览 1 评论
/9
GMT+8, 2025-12-1 20:36 , Processed in 0.610339 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1318
