以下是我的程序,定时器1可以输出500us的pwm信号,但定时器0却无法工作,无法实现LED的亮灭,请问是什么问题呢?求帮忙··············
#include #define uchar unsigned char #define uint unsigned int ***it pwm = P2^7; ***it LED=P1^1; uint t,i,j,t1,t2,num; uchar flag1,flag2; void delay(uint z) { for(i=z;i>0;i--) for(j=112;j>0;j--); } void main() { TMOD = 0x11; TH0 = (65536-1024)/256; TL0 = (65536-1024)%256; TH1 = (65536-512)/256; TL1 = (65536-512)%256; EA = 1; ET0 = 1; ET1 = 1; TR0 = 1; TR1 = 1; pwm = 1; LED=1; while(1) { flag1=1; delay(1000); flag1=0; delay(1000); flag2=1; delay(1000); flag2=0; delay(1000); } } void timer0() interrupt 1 using 0 { TH0=(65536-1024)/256; TL0=(65536-1024)%256; LED=~LED; } void timer1() interrupt 3 using 1 { TH1 = (65536-512)/256; TL1 = (65536-512)%256; if(flag1==1) { t++; if(t == 2) { pwm = 0; } if(t == 200 ) { pwm = 1; t = 0; } } if(flag2==1) { t1++; if(t1 == 3) { pwm = 0; } if(t1 == 200 ) { pwm = 1; t1 = 0; } } } |
5个回答
上面那个我说错了,我调试了一下你的T0计时器是工作的,只不过你的延时太短了,眼睛无法分辨出来。。。因为你是延时1024us那么LED闪烁的时候我们的眼睛分辨不出来。。。
#include #define uchar unsigned char #define uint unsigned int ***it pwm = P2^7; ***it LED=P1^1; uint t,i,j,t1,t2,num,aa; uchar flag1,flag2; void delay(uint z) { for(i=z;i>0;i--) for(j=112;j>0;j--); } void main() { TMOD = 0x11; TH0 = (65536-1024)/256; TL0 = (65536-1024)%256; TH1 = (65536-512)/256; TL1 = (65536-512)%256; EA = 1; ET0 = 1; ET1 = 1; TR0 = 1; TR1 = 1; pwm = 1; LED=1; while(1) { flag1=1; delay(1000); flag1=0; delay(1000); flag2=1; delay(1000); flag2=0; delay(1000); } } void timer0() interrupt 1 using 0 { TH0=(65536-50000)/256; TL0=(65536-50000)%256; aa++; if(aa==20) { aa=0; LED=~LED; } } void timer1() interrupt 3 using 1 { TH1 = (65536-512)/256; TL1 = (65536-512)%256; if(flag1==1) { t++; if(t == 2) { pwm = 0; } if(t == 200 ) { pwm = 1; t = 0; } } if(flag2==1) { t1++; if(t1 == 3) { pwm = 0; } if(t1 == 200 ) { pwm = 1; t1 = 0; } } } |
明白了,谢谢 |
你这个代码是为了实现什么功能?这样子写会出问题的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
995 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-通用文件I/O模型之close
1020 浏览 0 评论
《DNK210使用指南 -CanMV版 V1.0》第十五章 按键中断实验
982 浏览 0 评论
《DNK210使用指南 -CanMV版 V1.0》第十一章 FPIOA管理器实验
1071 浏览 0 评论
846 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11462 浏览 31 评论
GMT+8, 2024-10-14 22:41 , Processed in 0.663380 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
