扫一扫,分享给好友
library ieee;
use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity cymometer is port ( sysclk : in std_logic; --10MHZ频率输入 clkin : in std_logic; --待测频率信号输入 seg7:out std_logic_vector(6 downto 0); --7段显示控制信号(abcdefg) scan:out std_logic_vector(7 downto 0)); --数码管地址选择信号 end; architecture one of cymometer is signal cnt:std_logic_vector (24 downto 0); signal clk_cnt:std_logic; signal cntp1,cntp2,cntp3,cntp4,cntp5,cntp6,cntp7,cntp8:std_logic_vector (3 downto 0); signal cntq1,cntq2,cntq3,cntq4,cntq5,cntq6,cntq7,cntq8:std_logic_vector (3 downto 0); signal dat:std_logic_vector(3 downto 0); begin -------------0.5HZ分频-------------------------- process (sysclk) begin if sysclk'event and sysclk='1' then if cnt=19999999 then clk_cnt <=not clk_cnt;cnt <=(others=>'0'); else cnt<=cnt+1;end if; end if; end process; -------------1s内计数---------------------------- process (clkin) begin if clkin'event and clkin='1' then if clk_cnt='1' then if cntp1="1001" then cntp1<="0000"; if cntp2="1001" then cntp2<="0000"; if cntp3="1001" then cntp3<="0000"; if cntp4="1001" then cntp4<="0000"; if cntp5="1001" then cntp5<="0000"; if cntp6="1001" then cntp6<="0000"; if cntp7="1001" then cntp7<="0000"; if cntp8="1001" then cntp8<="0000"; else cntp8<=cntp8+1; end if; else cntp7<=cntp7+1; end if; else cntp6<=cntp6+1; end if; else cntp5<=cntp5+1; end if; else cntp4<=cntp4+1; end if; else cntp3<=cntp3+1; end if; else cntp2<=cntp2+1; end if; else cntp1<=cntp1+1; end if; else if (cntp1/="0000" or cntp2/="0000" or cntp3/="0000" or cntp4/="0000" or ---对计数值锁存 cntp5/="0000" or cntp6/="0000" or cntp7/="0000" or cntp8/="0000") then cntq1<=cntp1;cntq2<=cntp2;cntq3<=cntp3;cntq4<=cntp4; cntq5<=cntp5;cntq6<=cntp6;cntq7<=cntp7;cntq8<=cntp8; cntp1<="0000";cntp2<="0000";cntp3<="0000";cntp4<="0000"; cntp5<="0000";cntp6<="0000";cntp7<="0000";cntp8<="0000"; end if; end if; end if; end process; process(cnt(15 downto 13),cntq1,cntq2,cntq3,cntq4,cntq5,cntq6,cntq7,cntq8,dat) begin case cnt(15 downto 13) is when "000"=>scan<="00000001";dat<=cntq1; when "001"=>scan<="00000010";dat<=cntq2; when "010"=>scan<="00000100";dat<=cntq3; when "011"=>scan<="00001000";dat<=cntq4; when "100"=>scan<="00010000";dat<=cntq5; when "101"=>scan<="00100000";dat<=cntq6; when "110"=>scan<="01000000";dat<=cntq7; when "111"=>scan<="10000000";dat<=cntq8; when others =>null; end case; end process; process(dat) begin case dat is when "0000" =>seg7 <= "1111110"; when "0001" =>seg7 <= "0110000"; when "0010" =>seg7 <="1101101"; when "0011" =>seg7 <="1111001"; when "0100" =>seg7 <="0110011"; when "0101" =>seg7 <="1011011"; when "0110" =>seg7 <="1011111"; when "0111" =>seg7 <="1110000"; when "1000" =>seg7 <="1111111"; when "1001" =>seg7 <= "1111011"; when others =>null; end case; end process; end ;
3个回答
为什么是 15 downtown 13 有什么内涵没有
scan:out std_logic_vector(7 downto 0)是数码管地址控制信号
意思是不是用 7个二进制数来控制 FPGA上面的 7个数码管的使能端 ?? 好迷茫啊 |
不是移位吧 3个二进制构成8个状态 我就是不明白为什么从15到13 为什么不是24到22 或则其他 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1287 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1036 浏览 0 评论
2359 浏览 1 评论
2067 浏览 0 评论
矩阵4x4个按键,如何把识别结果按编号01-16(十进制)显示在两个七段数码管上?
2325 浏览 0 评论
1858 浏览 49 评论
6004 浏览 113 评论
GMT+8, 2024-12-20 22:16 , Processed in 0.536289 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
