扫一扫,分享给好友
#include
#include #define uchar unsigned char #define uint unsigned int ***it open = P2^0; ***it close=P2^1; ***it swap=P2^2; ***it sub_speed=P2^4; ***it add_speed=P2^3; ***it warning=P2^0; ***it PWM1=P2^1; ***it PWM2=P2^2; /********L298接口定义control******/ ***it MOTOR_A_2=P2^1; ***it MOTOR_A_1=P2^2; ***it EN_MOTOR_A=P2^3; ***it k1=P1^0; ***it k2=P1^1; ***it k3=P1^2; ***it k4=P1^3; uchar T=0; uchar W=0; uchar A=0; uchar k=10; uchar table1[]={ 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; uchar table2[]={0xfe,0xfb,0xfd,0xf7} /********液晶显示control******/ ***it E=P2^7; ***it RW=P2^6; ***it RS=P2^5; ***it test=P1^7; int time=0; int high=20; int period=30; int change=0; int flag=0; int num_medium=0; int num_display=0; int count_speed=0; /************ t0中断******pwm产生****/ void time0_int(void) interrupt 1 { time++; TH0=0Xec; TL0=0x78; if (change==0) { PWM2=1; if( time==high) PWM1=0; else if (time==period) { PWM1=1; time=0; } } else { PWM1=1; if( time == high) PWM2=0; else if (time==period) { PWM2=1; time=0; } } } /**************control**********/ void motor_control() { if(open==1) EA=1; if(close==1) EA=0; if(swap==1) { change=~change; while(swap!=0) { } } if(sub_speed==1) { high++; if(high==30) EA=0; while(sub_speed != 0) { } } if(add_speed==1) { high--; if(high==5) high=5; while(add_speed !=0) { } } } /************延时************/ void delay(uchar t) { uint i; while(t) { for(i=0;i<125;i++); t--; } } /*******ding li jun ****/ void wc51r(uchar j) { RS=0; RW=0; P1=j; E=1; E=0; delay(3); } void wc51ddr(uchar j) { RS = 1; RW = 0; P1 = j; E = 1; E = 0; delay(2); } /*****初始化LCD*****/ void init() { wc51r(0x01); //清屏 wc51r(0x38); //使用8位数据,显示两行,使用5*7的字型 wc51r(0x0c); //显示器件,光标开,字符不闪烁 wc51r(0x06); //字符不动,光标自动右移一格 } /********t1中断**********单位时间方波个数********/ void time1_int(void) interrupt 3 { count_speed++; if(count_speed==20) { count_speed=0; num_display=num_medium; num_medium=0; } } /**********速度显示的数据处理********************/ void datamade() { wc51r(0xc3); wc51ddr('V'); wc51ddr('='); wc51ddr(0x3a); if(open==1) { wc51ddr('o'); wc51ddr('p'); wc51ddr('e'); wc51ddr('n'); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); } if(swap==1) { wc51ddr('b'); wc51ddr('i') ; wc51ddr('a'); wc51ddr('n'); wc51ddr(' '); wc51ddr('x'); wc51ddr('i'); wc51ddr('a'); wc51ddr('n'); wc51ddr('g'); } if(sub_speed==1) { wc51ddr('v'); wc51ddr('-'); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); } if(add_speed==1) { wc51ddr('v'); wc51ddr('+'); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); } if (close==1) { wc51ddr('c'); wc51ddr('l'); wc51ddr('o'); wc51ddr('s'); wc51ddr('e'); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); wc51ddr(' '); } } /*************** 告警程序**********/ void warning_speed() { if(zhuan>100) { warning=1; } if(zhuan<=100) { warning=0; } } void main() { P2=0x00; ET0=1; ET1=1; TMOD=0X11; TH0=0Xec; TL0=0X78; TH1=0X3C; TL1=0Xb0; TR0=1; TR1=1; init(); //lcdcsh while(1) { wc51r(0x80); wc51ddr('d'); wc51ddr('g'); wc51ddr('u'); wc51ddr('t'); wc51ddr(' '); wc51ddr('l'); wc51ddr('i'); wc51ddr('j'); wc51ddr('u'); wc51ddr('n'); wc51ddr(' '); wc51ddr(' '); wc51ddr('b'); wc51ddr('y'); wc51ddr('s'); wc51ddr('j'); if(test==0) num_medium++; datamade(); motor_control(); } } 错误:Build target 'Target 1' assembling STARTUP.A51... compiling LCD.c... LCD.c(38): error C141: syntax error near '***it' LCD.c(38): error C247: non-address/-constant initializer LCD.c(247): error C202: 'zhuan': undefined identifier LCD.c(251): error C202: 'zhuan': undefined identifier Target not created 求大神指导 |
1个回答
基本的语法错误,先学简单的吧,不要搞那么复杂的程序。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
《DNK210使用指南 -CanMV版 V1.0》第十七章 machine.WDT类实验
347 浏览 0 评论
1023 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-通用文件I/O模型之close
1123 浏览 0 评论
《DNK210使用指南 -CanMV版 V1.0》第十五章 按键中断实验
1014 浏览 0 评论
《DNK210使用指南 -CanMV版 V1.0》第十一章 FPIOA管理器实验
1238 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11468 浏览 31 评论
GMT+8, 2024-10-16 13:46 , Processed in 0.618873 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
