目前使用的quartus版本为12.1 FPGA为cyclone5系列 5CEBA4U15C8N FRAM为 Cypress: FM21LD16-60(2Mbit) 附上FRAM datasheet的部分和我设计的测试部分 烧进板子后用nios执行得到的就是“Verify failed between address xx and oo(fram地址部分)”的错误。对于FRAM的接口设计和使用不是很有把握,可能会有很多低级错误还望指教。 另附上FRAM的tcl代码 # TCL File Generated by Component Editor 12.1sp1 # Mon Dec 15 20:44:28 JST 2014 # DO NOT MODIFY # # SRAM "IS61WV51216" v1.0 # me 2014.12.15.20:44:28 # 16bit SRAM Interface # # # request TCL package from ACDS 11.0 # package require -exact sopc 11.0 # # module SRAM # set_module_property DESCRIPtiON "16bit SRAM Interface" set_module_property NAME SRAM set_module_property VERSION 1.0 set_module_property INTERNAL false set_module_property OPAQUE_ADDRESS_MAP true set_module_property GROUP SRAM set_module_property AUTHOR me set_module_property ICON_PATH output_files/ set_module_property DISPLAY_NAME IS61WV51216 set_module_property TOP_LEVEL_HDL_FILE output_files/ set_module_property INSTANTIATE_IN_SYSTEM_MODULE false set_module_property EDITABLE true set_module_property ANALYZE_HDL AUTO set_module_property FIX_110_VIP_PATH false set_module_property REPORT_TO_TALKBACK false set_module_property ALLOW_GREYBOX_GENERATION false # # files # # # file sets # # # parameters # # # display items # # # connection point avalon_tristate_slave # add_interface avalon_tristate_slave avalon_tristate end set_interface_property avalon_tristate_slave activeCSThroughReadLatency false set_interface_property avalon_tristate_slave associatedClock "" set_interface_property avalon_tristate_slave explicitAddressSpan 262144 set_interface_property avalon_tristate_slave holdTime 1 set_interface_property avalon_tristate_slave isMemoryDevice true set_interface_property avalon_tristate_slave isNonVolatileStorage false set_interface_property avalon_tristate_slave maximumPendingReadTransactions 0 set_interface_property avalon_tristate_slave printableDevice false set_interface_property avalon_tristate_slave readLatency 0 set_interface_property avalon_tristate_slave readWaitTime 1 set_interface_property avalon_tristate_slave setupTime 0 set_interface_property avalon_tristate_slave timingUnits Cycles set_interface_property avalon_tristate_slave writeWaitStates 1 set_interface_property avalon_tristate_slave writeWaitTime 1 set_interface_property avalon_tristate_slave ENABLED true add_interface_port avalon_tristate_slave addr address Input 17 add_interface_port avalon_tristate_slave data data Bidir 16 add_interface_port avalon_tristate_slave ncs chipselect_n Input 1 add_interface_port avalon_tristate_slave wrn write_n Input 1 add_interface_port avalon_tristate_slave rdn read_n Input 1 add_interface_port avalon_tristate_slave ben byteenable_n Input 2 set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isFlash 0 set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isMemoryDevice 1 set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isNonVolatileStorage 0 set_interface_assignment avalon_tristate_slave embeddedsw.configuration.isPrintableDevice 0 |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1586 浏览 1 评论
1351 浏览 0 评论
矩阵4x4个按键,如何把识别结果按编号01-16(十进制)显示在两个七段数码管上?
1563 浏览 0 评论
930 浏览 0 评论
2361 浏览 0 评论
1474 浏览 37 评论
5683 浏览 113 评论
GMT+8, 2024-11-27 00:08 , Processed in 0.454718 second(s), Total 40, Slave 31 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
