扫一扫,分享给好友
我最近在用STM32驱动一个nRF905无线模块,但死活都读不出来数据,连时钟信号都读不出,发送端的时序没什么问题,可接收端是什么都测不出来,望大神们指点指点,能上传一份测试过的程序就感激不尽了。调了好多天了都找不到问题出在哪里!!急用!!!非常感谢!!!!!
接收端程序如下 void SPI_RF905_Config(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; //时钟配置 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); /*!< Configure SPI_FLASH_SPI pins: SCK ,MOSI */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽式输出 GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); /*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //TRX_CE->PA1,TXEN->PA0 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); SPI_CS_H(); SPI_Cmd(SPI1, DISABLE); //配置模式之前必须禁止SPI /* SPI1 configuration */ SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode =SPI_Mode_Master; //SPI_Mode_Slave; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 0; SPI_Init(SPI1, &SPI_InitStructure); SPI_Cmd(SPI1, ENABLE); spi_readwriteByte(0xff); } //--------------------nRF905初始化函数--------------------------------\ void nRF905_Init(void) { SPI_CS_H(); //置高CS SPI_SCK_L();//置低SPI时钟 DR_H(); AM_H(); CD_H(); PWR_H(); TRX_CE_L(); TXEN_L(); } //----------------------寄存器配置函数------------------------------------\ void SPI_RFCofig(void) { SPI_CS_L(); SPI_SendByte(0x00); SPI_SendByte(0x4C); //第0个字节开始写截止到第九个字节 SPI_SendByte(0x0C); SPI_SendByte(0x44); SPI_SendByte(0x04); SPI_SendByte(0x04); SPI_SendByte(0xE7); SPI_SendByte(0xE7); SPI_SendByte(0xE7); SPI_SendByte(0xE7); SPI_SendByte(0x58); //允许8位校验,8MHz,没有外部时钟,输出频率为1MHz SPI_CS_H(); } //------------------nRF905接收模式配置--------------------------------\ void set_nRF905_RX(void) { TXEN_L(); TRX_CE_H(); delay_10us(650); //延时650us } //----------------------------------------RxPacket()-----------------------------------------// void RxPacket(void) { u8 i; delay_10us(700); TRX_CE_L(); delay_10us(700); SPI_CS_L(); delay_10us(10); SPI_SendByte(RRP); //写入读指令 for(i=0;i<2;i++) //读出数据给buff { buff[i]=SPI_ReadByte(); } delay_10us(10); SPI_CS_H(); delay_10us(10); TRX_CE_H(); //允许数据读取 delay_10us(650); TRX_CE_L(); //禁止数据读取 } //------------------------Rx_shuju(void)--------------------\ void Rx_shuju(void) { u8 i; set_nRF905_RX(); while(CheckDR()==0); RxPacket(); delay_10us(5); for(i=0;i<2;i++) { printf("%cn",buff[i]); } delay_10us(50); } //---------------------SPI_RF905_SendByte()--------------------// void SPI_SendByte(u8 byte) { u8 i=0; while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) { i++; if(i>100) break; } SPI_I2S_SendData(SPI1, byte); } //--------------------------------SPI_RF905_ReadByte()---------------------\ u8 SPI_ReadByte(void) { u8 i=0; while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) { i++; if(i>100) return 0; } return SPI_I2S_ReceiveData(SPI1); } //-----------------------读写程序-------------------------------------------------\ u8 spi_readwriteByte(u8 Txdata) { u8 i=0; while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) { i++; if(i>200) return 0; } SPI_I2S_SendData(SPI1, Txdata); i=0; while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) { i++; if(i>200) return 0; } return SPI_I2S_ReceiveData(SPI1); } //-------------------------CheckDR()--------------------------// u8 CheckDR(void) //检查是否有新数据传入 Data Ready { if (GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_0)&&GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0)&&GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_1)) { return 1; } else return 0; } |
3个回答
那个延时函数时1us的延时
对STM不怎么了解
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
FM17580是否能够只配置一次启动自动寻卡功能,之后就直接通过中断引脚IRQ传递给MCU,完成插拔卡的检测
13437 浏览 0 评论
5490 浏览 0 评论
ADL5801ACPZ混频器调试遇到了个问题:1.现象:混频器转换增益很差
5856 浏览 1 评论
11662 浏览 0 评论
10436 浏览 1 评论
/9
GMT+8, 2025-12-2 23:12 , Processed in 0.590609 second(s), Total 80, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5645
