使用XDS100v2仿真器向DSP5509a烧写程序时出错,debug时,出现的提示信息如下:
[Start] Execute the command: %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:UsersADMINI~1AppDataLocal.ti520282722 0 BrdDattestBoard.dat -----[Print the reset-command software log-file]----------------------------- This utility has selected a 100- or 510-class product. This utility will load the adapter 'jioserdesu***.dll'. An error occurred while soft opening the controller. -----[An error has occurred and this utility has aborted]-------------------- This error is generated by TI's USCIF driver or utilities. The value is '-600' (0xfffffda8). The title is 'SC_ERR_LIB_ANY_LOCATE'. The explanation is: A required dynamic library could not be located. The library isn't on the search path. [End] 请问我的错误可能出在哪里,应该怎么修改。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于 DSP5509 进行数字图像处理中 Sobel 算子边缘检测的硬件连接电路图
3280 浏览 0 评论
800 浏览 0 评论
普中科技F28335开发板中,如何使用aic23播放由代码生成的正弦波
3715 浏览 0 评论
4469 浏览 1 评论
1386 浏览 1 评论
GMT+8, 2024-12-24 11:13 , Processed in 0.385625 second(s), Total 41, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
