现在写毕业论文,有锁相环的程序,不太确定它的准确性,也不知道怎么运该软件运行,求大神指教% File: c6_nltvde.m
w2b=0; w2c=0; % initialize integrators yd=0; y=0; % initialize differential equation tfinal = 50; % simulation time fs = 100; % sampling frequency delt = 1/fs; % sampling period npts = 1+fs*tfinal; % number of samples simulated ydv = zeros(1,npts); % vector of dy/dt samples yv = zeros(1,npts); % vector of y(t) samples % % beginning of simulation loop for i=1:npts t = (i-1)*delt; % time if t<20 ydd = 4*exp(-t/2)-3*yd*abs(y)-9*y; % de for t<20 else ydd = 4*exp(-t/2)-3*yd-9*y; % de for t>=20 end w1b=ydd+w2b; % first integrator - step 1 w2b=ydd+w1b; % first integrator - step 2 yd=w1b/(2*fs); % first integrator output w1c=yd+w2c; % second integrator - step 1 w2c=yd+w1c; % second integrator - step 2 y=w1c/(2*fs); % second integrator output ydv(1,i) = yd; % build dy/dt vector yv(1,i) = y; % build y(t) vector end % end of simulation loop plot(yv,ydv) % plot phase plane xlabel('y(t)') % label x axis ylabel('dy/dt') % label y zxis % End of script file. % File: pllpost.m % kk = 0; while kk == 0 k = menu('Phase Lock Loop Postprocessor',... 'Input Frequency and VCO Frequency',... 'Input Phase and VCO Phase',... 'Frequency Error','Phase Error','Phase Plane Plot',... 'Phase Plane and Time Domain Plots','Exit Program'); if k == 1 plot(t,fin,'k',t,fvco,'k') title('Input Frequency and VCO Freqeuncy') xlabel('Time - Seconds');ylabel('Frequency - Hertz');pause elseif k ==2 pvco=phin-phierror;plot(t,phin,t,pvco) title('Input Phase and VCO Phase') xlabel('Time - Seconds');ylabel('Phase - Radians');pause elseif k == 3 plot(t,freqerror);title('Frequency Error') xlabel('Time - Seconds');ylabel('Frequency Error - Hertz');pause elseif k == 4 plot(t,phierror);title('Phase Error') xlabel('Time - Seconds');ylabel('Phase Error - Radians');pause elseif k == 5 ppplot elseif k == 6 subplot(211);phierrn = phierror/pi; plot(phierrn,freqerror,'k');grid; title('Phase Plane Plot');xlabel('Phase Error /Pi'); ylabel('Frequency Error - Hertz');subplot(212) plot(t,fin,'k',t,fvco,'k');grid title('Input Frequency and VCO Freqeuncy') xlabel('Time - Seconds');ylabel('Frequency - Hertz');subplot(111) elseif k == 7 kk = 1; end end % End of script file. % File: pllpre.m % clear all % be safe disp(' ') % insert blank line fdel = input('Enter the size of the frequency step in Hertz > '); fn = input('Enter the loop natural frequency in Hertz > '); lambda = input('Enter lambda, the relative pole offset > '); disp(' ') disp('Accept default values:') disp(' zeta = 1/sqrt(2) = 0.707,') disp(' fs = 200*fn, and') disp(' tstop = 1') dtype = input('Enter y for yes or n for no > ','s'); if dtype == 'y' zeta = 1/sqrt(2); fs = 200*fn; tstop = 1; else zeta = input('Enter zeta, the loop damping factor > '); fs = input('Enter the sampling frequency in Hertz > '); tstop = input('Enter tstop, the simulation runtime > '); end % npts = fs*tstop+1; % number of simulation points t = (0:(npts-1))/fs; % default time vector nsettle = fix(npts/10); % set nsettle time as 0.1*npts tsettle = nsettle/fs; % set tsettle % The next two lines establish the loop input frequency and phase % deviations. fin = [zeros(1,nsettle),fdel*ones(1,npts-nsettle)]; phin = [zeros(1,nsettle),2*pi*fdel*t(1:(npts-nsettle))]; disp(' ') % insert blank line % end of script file pllpre.m % File: pll2sin.m w2b=0; w2c=0; s5=0; phivco=0; %initialize twopi=2*pi; % define 2*pi twofs=2*fs; % define 2*fs G=2*pi*fn*(zeta+sqrt(zeta*zeta-lambda)); % set loop gain a=2*pi*fn/(zeta+sqrt(zeta*zeta-lambda)); % set filter parameter a1=a*(1-lambda); a2 = a*lambda; % define constants phierror = zeros(1,npts); % initialize vector fvco=zeros(1,npts); % initialize vector % beginning of simulation loop for i=1:npts s1=phin(i) - phivco; % phase error s2=sin(s1); % sinusoidal phase detector s3=G*s2; s4=a1*s3; s4a=s4-a2*s5; % loop filter integrator input w1b=s4a+w2b; % filter integrator (step 1) w2b=s4a+w1b; % filter integrator (step 2) s5=w1b/twofs; % generate fiter output s6=s3+s5; % VCO integrator input w1c=s6+w2c; % VCO integrator (step 1) w2c=s6+w1c; % VCO integrator (step 2) phivco=w1c/twofs; % generate VCO output phierror(i)=s1; % build phase error vector fvco(i)=s6/twopi; % build VCO input vector end % end of simulation loop freqerror=fin-fvco; % build frequency error vector % End of script file. function [] = pplane(x,y,nsettle) % Plots the phase plane with phase in the range (-pi,pi) ln = length(x); maxfreq = max(y); minfreq = min(y); close % Old figure discarded axis([-1 1 1.1*minfreq 1.1*maxfreq]); % Establish scale hold on % Collect info for new fig j = nsettle; while j < ln i = 1; while x(j) < pi & j < ln a(i) = x(j)/pi; b(i) = y(j); j = j+1; i = i+1; end plot(a,b,'k') a = []; b = []; x = x - 2*pi; end hold off title('Phase-Plane Plot') xlabel('Phase Error / Pi') ylabel('Frequency Error in Hertz') grid % End of script file. % File: ppplot.m % ppplot.m is the script file for plotting phase plane plots. If the % phase plane is constrained to (-pi,pi) ppplot.m calls pplane.m. kz = 0;while kz == 0 k = menu('Phase Plane Options',... 'Extended Phase Plane',... 'Phase Plane mod(2pi)',... 'Exit Phase Plane Menu'); if k == 1 phierrn = phierrn/pi; plot(phierrn,freqerror,'k') title('Phase Plane Plot') xlabel('Phase Error /Pi') ylabel('Frequency Error - Hertz') grid pause elseif k == 2 pplane(phierrn,freqerror,nsettle+1) pause elseif k == 3 kz = 1; end end % End of script file. |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
GMT+8, 2024-5-5 06:18 , Processed in 0.519367 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
