扫一扫,分享给好友
当歌曲播放完之后会出现一声一声的音调。而无法继续循环播放下面是我的程序 ,希望好心人资助一下。
#include #define uint unsigned int #define uchar unsigned char ***it beep=P1^5; uchar code tzdn[]={ //同桌的你[11] 0x56,0x56,0x32,0x42,0x52,0x76,0x66,0x56,0x52,0x22,0x32,0x46,0x16,0x26,0x04, //前奏 0x52,0x52,0x52,0x52,0x32,0x42,0x56,0x86,0x62,0x62,0x62,0x62,0x42,0x62,0x56, 0x04, //明天你是否会想起,昨天你写的日记 0x52,0x52,0x52,0x52,0x72,0x62,0x52,0x44,0x02,0x42,0x42,0x42,0x42,0x33,0x21, 0x16,0x02, //明天你是否还惦记,曾经最爱哭的你 0x82,0x82,0x82,0x82,0x52,0x32,0x86,0x82,0xA4,0x92,0x92,0x92,0x93,0x81,0x72, 0x66,0x02, //谁娶了多愁善感的你,谁看了你的日记 0x72,0x72,0x72,0x72,0x72,0x82,0x96,0x54,0x02,0x72,0x72,0x82,0x92,0x82,0x72, 0x16,0x02, //谁把你的长发盘起,谁给你做的嫁衣 0x84,0x82,0x82,0x52,0x62,0x86,0xA6,0x94,0x92,0x92,0x82,0x72,0x66,0x74,0x72, 0x72,0x72,0x82,0x96,0x56, //啦……,啦……,啦…… 0x72,0x72,0x82,0x92,0x82,0x72,0x86,0x94,0x92,0x92,0x62,0x72,0x96,0xB6,0x94, 0x92,0x92,0x82,0x72,0x66, //啦……,啦……,啦…… 0x72,0x72,0x72,0x72,0x72,0x82,0x96,0x56,0x72,0x72,0x82,0x92,0x82,0x72,0x96, 0x86,0xff //啦……,啦……,啦……,啦…… }; //----------------------------简谱音调对应的定时器初值--------------------------- //适合11.0592M的晶振 uchar code chuzhi[]={ 0xff,0xff,//占位 0xFC,0x8E,//中央C调1-7 0xFC,0xED, 0xFD,0x43, 0xFD,0x6A, 0xFD,0xB3, 0xFD,0xF3, 0xFE,0x2D, 0xFE,0x47, //高八度1-7 0xFE,0x76, 0xFE,0xA1, 0xFE,0xC7, 0xFE,0xD9, 0xFE,0xF9, 0xFF,0x16 }; void delay1ms(uint z); //延时1毫秒 void delay(uint z); //延时165毫秒,十六分音符;一拍是四分音符 =4十六分音符 void songtzdn(); uchar timeh,timel,k,temp; void main() { TMOD=0x01; //定时器0工作在方式1 TH0=0; TL0=0; ET0=1; EA=1; while(1) { songtzdn(); delay1ms(1000); } } void songtzdn() { uchar pl,i=0; while(1) { temp=tzdn[i]; pl=temp/16; //pl代表频率;取高四位 if(pl!=0) { timeh=chuzhi[pl*2]; timel=chuzhi[pl*2+1]; } if (pl==0xff) { TR0=0; beep=1; break; } delay(temp%16); //取低四位,延时节拍时长 TR0=0; beep=1; delay1ms(10); TR0=1; i++; } } void time0() interrupt 1 { TH0=timeh; TL0=timel; beep=~beep; } void delay1ms(uint z) { uchar x,y; for(x=z;x>0;x--) for(y=112;y>0;y--); } void delay(uint z) //延时165MS,即十六分音符 { uint x,y; for(x=z;x>0;x--) for(y=19000;y>0;y--); } |
2个回答
此程序的问题在于数据类型设置和计算结果考虑不周:
uchar timeh,timel,k,temp; void main() uchar pl,i=0; while(1) { temp=tzdn[i]; pl=temp/16; //pl代表频率;取高四位 . . . if (pl==0xff) { TR0=0; beep=1; break; } 数据全部定义为uchar; temp/16的结果就是右移4位,而不是算术除,所以用结束字符计算时 temp/16 的结果是15(0xF),而不是-1(0xFF),而且,任何字符的计算结果都不会是0xFF; 因此,你的音乐结束后,不会在break语句处结束,而是继续用编译后保存在tzdn[]后面的字符作为音乐编码继续播放,i计数越过255后,又会播放你的同桌的你了! |
非常感谢你的指导 ![]() |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
234 浏览 0 评论
514 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
826 浏览 0 评论
1366 浏览 2 评论
814 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16910 浏览 31 评论
/9
GMT+8, 2025-12-2 23:29 , Processed in 0.426335 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6236
