扫一扫,分享给好友
2个回答
#include #include #define uchar unsigned char #define uint unsigned int #include //延时子程序 void DelayMS(uint x) { uchar i; while (x--) for (i =0;i<120;i++); } ***it RS = P2^0; //定义端口 ***it RW = P2^1; ***it EN = P2^2; #define RS_CLR RS=0 #define RS_SET RS=1 #define RW_CLR RW=0 #define RW_SET RW=1 #define EN_CLR EN=0 #define EN_SET EN=1 #define DataPort P0 /*------------------------------------------------ uS延时函数,含有输入参数 unsigned char t,无返回值 unsigned char 是定义无符号字符变量,其值的范围是 0~255 这里使用晶振12M,精确延时请使用汇编,大致延时 长度如下 T=tx2+5 uS ------------------------------------------------*/ /*------------------------------------------------ 判忙函数 ------------------------------------------------*/ bit LCD_Check_Busy(void) { DataPort= 0xFF; RS_CLR; RW_SET; EN_CLR; _nop_(); EN_SET; return (bit)(DataPort & 0x80); } /*----------------------------------------------- 写入命令函数 ------------------------------------------------*/ void LCD_Write_Com(unsigned char com) { //while(LCD_Check_Busy()); //忙则等待 RS_CLR; RW_CLR; EN_SET; DataPort= com; _nop_(); EN_CLR; } /*------------------------------------------------ 写入数据函数 ------------------------------------------------*/ void LCD_Write_Data(unsigned char Data) { while(LCD_Check_Busy()); //忙则等待 RS_SET; RW_CLR; EN_SET; DataPort=Data; _nop_(); EN_CLR; } /*------------------------------------------------ 清屏函数 ------------------------------------------------*/ void LCD_Clear(void) { LCD_Write_Com(0x01); DelayMS(5); } /*------------------------------------------------ 写入字符串函数 ------------------------------------------------*/ void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s) { if (y == 0) { LCD_Write_Com(0x80 + x); //表示第一行 } else { LCD_Write_Com(0xC0 + x); //表示第二行 } while (*s) { LCD_Write_Data( *s); s ++; } } /*------------------------------------------------ 写入字符函数 ------------------------------------------------*/ void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data) { if (y == 0) { LCD_Write_Com(0x80 + x); } else { LCD_Write_Com(0xC0 + x); } LCD_Write_Data( Data); } /*------------------------------------------------ 初始化函数 ------------------------------------------------*/ void LCD_Init(void) { LCD_Write_Com(0x38); /*显示模式设置*/ DelayMS(5); LCD_Write_Com(0x38); DelayMS(5); LCD_Write_Com(0x38); DelayMS(5); LCD_Write_Com(0x38); LCD_Write_Com(0x08); /*显示关闭*/ LCD_Write_Com(0x01); /*显示清屏*/ LCD_Write_Com(0x06); /*显示光标移动设置*/ DelayMS(5); LCD_Write_Com(0x0C); /*显示开及光标设置*/ } //24c04 IIC读写程序 #define Delay4us(); {_nop_();_nop_(); _nop_();_nop_();} ***it SCL =P3^2; //串行时钟 ***it SDA =P3^3; //串行数据 void Start () //起始 { SDA = 1; SCL =1;Delay4us(); SDA=0;Delay4us();SCL=0; } void Stop () //停止 { SDA=0 ;SCL=1;Delay4us();SDA=1;Delay4us();SCL=0; } void IIC_24C04_Init()//IIC总线初始 { SCL =0; Stop (); } void ACK() //发送应答信号 { SDA=0;SCL=1;Delay4us();SCL=0;SDA=1; } void NO_ACK() // 发送非应答信号 { SDA=1;SCL=1;Delay4us();SCL=0;SDA=0; } uchar RecByte() //从芯片读取1字节 { uchar i,rd; rd =0x00; SDA=1; for(i=0; i<8;i++) { SCL=1;rd<<=1;rd |=SDA; Delay4us();SCL=0; Delay4us(); } SCL=0; Delay4us(); return rd; } uchar SendByte(uchar wd) //向芯片发送一字节 { uchar i; bit ack0; for(i=0;i<8;i++) //循环移入8位 { SDA =(bit)(wd & 0x80); _nop_(); _nop_(); SCL=1; Delay4us(); SCL=0; wd<<=1; } Delay4us(); SDA=1;//释放总线并准备读取应答 SCL=1; Delay4us(); ack0= !SDA; //0表示无应答 SCL=0; Delay4us(); return ack0; //返回应答 } //发送多字节数据 uchar SendString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N) { uchar i; Start(); if (!SendByte(Slave)) return 0; //发送器件地址 if (!SendByte(Subaddr)) return 0; //器件子地址 for(i=0;i if (!SendByte(Buffer[i])) return 0;//发送数据 } Stop(); return 1 ; } //接受多字节数据 uchar RecString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N) { uchar i; Start(); if (!SendByte(Slave)) return 0; //发送器件地址 if (!SendByte(Subaddr)) return 0; //器件子地址 Start(); if (!SendByte(Slave +1)) return 0; //器件地址,读操作 for (i=0; i Buffer[i]=RecByte();//接受数据 ACK();//发送应答位 } Buffer[N-1]= RecByte();//接受最后一位 NO_ACK(); //发送非应答 Stop(); return 1; } void DelayMS(uint x); //键盘矩阵扫描程序 uchar Keys_Scan() { uchar Tmp,KeyNo =0; P1 =0xF0; DelayMS(1); //按键后00001111将会变成0000xxxx,x中1个为0,3个为1 //下面的异或操作会把3个1变成0,唯一的0变成1 Tmp =P1 ^ 0x0F; //判断按键发生于0到3列中的哪一列 switch (Tmp) { case 1:KeyNo =0;break; case 2:KeyNo =1;break; case 4:KeyNo =2;break; case 8:KeyNo =3;break; default : KeyNo =16;//无键盘按下 } //低四位置0,放入四列 P1 =0xF0; DelayMS(1); //按键后00001111将会变成0000xxxx,x中1个为0,3个为1 //下面的表达式会将高四位移至底四位,并将其中唯一的0变成1,其余为0 Tmp =P1>> 4 ^ 0x0f; //对0到3行分别附加起始值0,4,8,12 switch (Tmp) { case 1:KeyNo +=0;break; case 2:KeyNo +=4;break; case 4:KeyNo +=8;break; case 8:KeyNo +=12; } return KeyNo; } void LCD_Init(); //初始化液晶 void Display_String(uchar *str, uchar LineNo); //在液晶的指定行显示 void Beep(); //IIC和蜂鸣器的初始化 void IIC_24C04_Init(); uchar RecString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N); uchar SendString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N); uchar Keys_Scan(); //扫描键盘返回 ***it LED_OPEN = P2^7; //开锁灯 ***it LED_WARN = P2^4; //警示灯 ***it BEEP = P3^7; //蜂鸣器 uchar Pre_KeyNo=16, KeyNo=16; uchar code Title_Text[] = "Your Password... "; //上电液晶显示标题 uchar DSY_BUFFER[10] = "";//显示缓存 uchar UserPassword[10] = "";//用户输入的密码 //蜂鸣器子程序 void Beep() { uchar i; for (i =0;i<100;i++) { DelayMS(1); BEEP = ~BEEP; } BEEP = 1; } //清除密码 void Clear_Password() { UserPassword[0] = ' |
淘帖
1801
