扫一扫,分享给好友
刚学单片机不就,写了一个时钟程序,在proteus仿真中运行良好,但是将程序下载到实际的硬件上时,数码管会闪烁,实在是不知道怎么回事了,特来求助
#include /*------功能位设置-----------*/ ***it dula = P2^0;/*段锁存位*/ ***it wela = P2^1;/*位锁存位*/ ***it keyHour = P2^2; ***it keyMinute = P2^3; ***it keySecond = P2^4; ***it watchStop = P2^5; /*---------------------------*/ /*------------------函数初始化-----------------------------*/ void display(unsigned char,unsigned char);/*数码管显示程序*/ void delay(unsigned int);/*延时子程序*/ void timeLogic();/*时钟运行逻辑*/ void giveTimeTableSetValue();/*给时间码表设置值*/ void initTime0();/*定时器0初始化*/ void keyCheck(); /*---------------------------------------------------------*/ /*----------相关码表-----------------*/ /*段码表*/ unsigned char code SEGCCTable [] ={ 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71 }; /*位码表*/ unsigned char code WELATable [] = { 0xFE,0xFD,0xFB,0xF7, 0xEF,0xDF,0xBF,0x7F }; unsigned char time[8]; /*-----------------------------------*/ /*--------变量的定义-----------------*/ unsigned char temp;/*用于循环计数*/ unsigned char timeCount;/*定时器计数*/ unsigned char hour=23; /*小时*/ unsigned char minute=59; /*分钟*/ unsigned char second=0; /*秒*/ /*-----------------------------------*/ /*主函数*/ main(){ initTime0();/*定时器初始化*/ while(1){ keyCheck(); } } /*显示子函数*/ void display(unsigned char duCode,unsigned char weCode){ P0 = duCode; dula = 1; dula = 0; P0 = weCode; wela = 1; wela = 0; } /*延时子函数*/ void delay(unsigned int xms){ unsigned int i,j; for(i=0;i } /*时钟逻辑程序*/ void timeLogic(){ if(timeCount == 20){ timeCount = 0; second++; if(second==60){ minute++; second = 0; } if(minute==60){ hour++; minute=0; } if(hour==24) hour = 0; } } /*给时间表赋值子程序*/ void giveTimeTableSetValue(){ time[0] = SEGCCTable[hour/10]; time[1] = SEGCCTable[hour%10]; time[2] = 0x40; time[3] = SEGCCTable[minute/10]; time[4] = SEGCCTable[minute%10]; time[5] = 0x40; time[6] = SEGCCTable[second/10]; time[7] = SEGCCTable[second%10]; } /*定时器0初始化*/ void initTime0(){ TMOD |= 0x01; //TH0 = 0x00; //TL0 = 0x00; EA = 1; /*总中断*/ ET0 = 1; /*定时器0中断打开*/ TR0 = 1; /*定时器0开关打开*/ } void time0Inturp()interrupt 1 { TH0=(65536-50000)/256; TL0=(65536-50000)%256; timeCount++; timeLogic(); giveTimeTableSetValue(); /*数码管显示逻缉(紧限时钟)*/ for(temp=0;temp<8;temp++){ display(time[temp],WELATable[temp]); delay(1); P0 = 0xFF; wela = 1; wela = 0; } } /*按键检测程序*/ void keyCheck(){ if(keyHour==0){ delay(10); if(keyHour==0){ while(keyHour==0); hour++;//小时 if(hour==24) hour=0; } } if(keyMinute==0){ delay(10); if(keyMinute==0){ while(keyMinute==0); minute++;//分钟 if(minute==60) minute=0; } } if(keySecond==0){ delay(10); if(keySecond==0){ while(keySecond==0); second++;//秒 if(second==60) second=0; } } /*这段程序可要可不要,就是让数码管不显示,对应的P2.5口的按键*/ if(watchStop==0){ delay(10); if(watchStop==0){ while(watchStop==0); TR0 = ~TR0; } } } 附上仿真图片一张。。。
12个回答
/*显示子函数*/,里面数码管扫描要短暂的延时
应该是延时函数的时间设定值太小!
这个延时我在调用这个函数的时候已经加了,就在中断程序里的那个for循环里面有个delay(1); |
1 条评论
试一下把显示函数写在主函数里面!键盘放在中断里!
像这种数码管显示 一般按键之类的尽量少用中断 主函数里面处理就可以了 中断时用在很重要的地方的 中断里面还延时 程序结构太混乱了
弱弱的说一句,我是写java的,这个程序中带有我写java的一些习惯,所以看起来会比较混乱,我想知道我写的这个程序在仿真里面行而放到真实硬件上就不行,我刚刚学不久,练习一下中断的使用,你说的很有价值,我以后会注意 |
看了一下你的按键延时用了大概30个毫秒延时 的确不适合放在中断里使用!
仿真软件是根据硬件来模拟的,不可能做到跟硬件完全一样,只能作为参考,但如果与硬件效果不一样,只能说明你的程序有问题了。 |
试试在/*显示子函数*/送段选和位选值的中间加上短暂的延时,再加上“P0=0xFF”
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16902 浏览 31 评论
/9
GMT+8, 2025-12-2 09:52 , Processed in 0.888105 second(s), Total 101, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1131
