扫一扫,分享给好友
#include
#include #include #include #define uchar unsigned char #define uint unsigned int #define BUSY 0x80 //常量定义 #define DATAPORT P0 ***it ADCS=P3^5; ***it ADDI=P3^7; ***it ADDO=P3^7; ***it ADCLK=P3^6; ***it LCM_RS=P2^0; ***it LCM_RW=P2^1; ***it LCM_EN=P2^2; uint x1,y1,z1=0,w1,j,temp1; uchar ad_data,k,n,m,e,num,s; //采样值存储 ***it speaker=P3^0; char press_data; //标度变换存储单元 unsigned char ad_alarm; //报警值存储单元 unsigned char press_ge=0; //显示值百位 unsigned char press_shifen=0; //显示值十位 unsigned char press_baifen=0; //显示值个位 unsigned char press_qianfen=0; //显示值十分位 uchar code str0[]={"Weight: Kg"}; uchar code str2[]={"Price: "}; uchar code str3[]={"Total: "}; uchar code table2[]={0x37,0x38,0x39,0x34,0x35,0x36,0x31,0x32,0x33,0x3d,0x30,0x2e};//键盘码 void delay(uint); void lcd_wait(void); void delay_LCM(uint); //LCD延时子程序 void initLCM(void); //LCD初始化子程序 void lcd_wait(void); //LCD检测忙子程序 void WriteCommandLCM(uchar WCLCM,uchar BusyC);//写指令到ICM子函数 void WriteData LCM(uchar WDLCM); //写数据到LCM子函数 void DisplayOneChar(uchar X,uchar Y,uchar DData);//显示指定坐标的一个字符子函数 void DisplayListChar(uchar X,uchar Y,uchar code *DData);//显示指定坐标的一串字符子函数 void weishu(uint m); void weishu1(uint m); void display(void); uchar Adc0832(unsigned char channel); void alarm(void); void data_pro(void); /**********主程序***********/ void main(main) { delay(500); //系统延时500ms启动 //ad_data=0; //采样值存储单元初始化为0 initLCM(); WriteCommandLCM(0x01,1); //清显示屏 DisplayListChar(0,0,str0); DisplayListChar(0,1,str2); while(1) { ad_data=Adc0832(0); //采样值存储单元初始化为0 alarm(); data_pro(); display(); if(k==1) { DisplayOneChar((s+7),1,table2[num-1]); x1=m; y1=n; y1=y1*10+x1; } if(k==`*`) { data_pro(); WriteCommandLCM(0x01,1); weishu(z1); k=0; } if(k==`=`) { z1=z1*temp1; WriteCommandLCM(0x01,1); DisplayListChar(0,1,str3); s=0; weishu1(temp1*n); k=0; j=temp1; } if(k==``) { WriteCommandLCM(0x80+0x40,1); WriteCommandLCM(0x01,1); z1=0; s=0; //防止清零时指针后移动 } } } /*********延时程序K*1ms,12.000mhz**********/ void delay(uint k) { uint i,j; for(i=0;i /***********写指令到ICM子函数*************/ void WriteCommandLCM(uchar WCLCM,uchar BusyC) { if(BusyC) lcd_wait(); DATAPORT=WCLCM; LCM_RS=0; //选中指令寄存器 LCM_RW=0; LCM_RW=0; //写模式 LCM_EN=1; _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); LCM_EN=0; } /***********写数据到LCM子函数*************/ void WriteData LCM(uchar WDLCM) { lcd_wait(); //检测忙信号 DATAPORT=WDLCM; LCM_RS=1; //选中数据寄存器 LCM_RW=0; //写模式 LCM_EN=1; _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); LCM_EN=0; } /***********LCM内部等待函数*************/ void lcd_wait(void) { DATAPORT=0xff; //读LCD前若单片机输出低电平,而读出LCD为高电平, 则冲突,proteus仿真会有显示逻辑黄色 LCM_EN=1; LCM_RS=0; LCM_RW=0; LCM_RW=1; _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); while(DATAPORT&BUSY) { LCM_EN=0; _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); LCM_EN=1; _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); } LCM_EN=0; } /***********LCM初始化子函数*************/ void initLCM() { LCM_EN=0; DATAPORT=0; delay(15); WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号 delay(5); WriteCommandLCM(0x38,0); delay(5); WriteCommandLCM(0x38,0); delay(5); WriteCommandLCM(0x38,1);//8bit数据传送,两行显示,5*7字型,检测忙信号 WriteCommandLCM(0x08,1);//关闭显示,检测忙信号 WriteCommandLCM(0x01,1);//清屏,检测忙信号 WriteCommandLCM(0x06,1);//显示光标右移设置,检测忙信号 WriteCommandLCM(0x0c,1);//显示屏打开,光标不显示,不闪烁,检测忙信号 TMOD=Ox11; EA=1; ET1=1; TR1=1; k=0; x1=0; y1=0; z1=0; } /***********显示指定坐标的一个字符子函数*************/ void DisplayOneChar(uchar X,uchar Y,uchar DData); { Y&=0X01; X&=0x0f; if(Y) X|=0x40; //若y为1(显示第二行),地址码+0x40 X|=0x80; //指令码为地址码+0x80 WriteCommandLCM(X,1); WriteDataLCM(DData); } /***********显示指定坐标的一串字符子函数*************/ void DisplayListChar(uchar X,uchar Y,uchar code*DData) { uchar Listlength=0; Y&=0X01; X&=0x0f; while(X<16) { DisplayOneChar(X,Y,DData[Listlength]); Listlength++; X++; } } /***********系统显示子函数*************/ void display(void) { WriteCommandLCM(0x0c,1); //显示屏打开,光标不显示,不闪烁,检测忙信号 DisplayListChar(0,0,str0); // DisplayListChar(0,1,str2); DisplayOneChar(8,0,press_ge+0x30); DisplayOneChar(10,0,press_shifen+0x30); DisplayOneChar(11,0,press_baifen+0x30); DisplayOneChar(12,0,press_qianfen+0x30); delay(1000); //稳定显示 } /***********读ADC0832*************/ //采样并返回 uchar Adc0832(unsigned char channel) //AD转换,返回结果 { uchar i=0; uchar j; uint dat=0; uchar ndat=0; if(channel==0)channel=2; if(channel==1)channel=3; ADDI=1; _nop_(); _nop_(); ADCS=0; //拉低CS端 _nop_(); _nop_(); ADCLK=1; //拉高CLK端 _nop_(); _nop_(); ADCLK=0; //拉低CLK端,形成下降沿1 _nop_(); _nop_(); ADCLK=1;//拉高CLK端 ADDI=channel&0x1; _nop_(); _nop_(); ADCLK=0;//拉低CLK端,形成下降沿2 _nop_(); _nop_(); ADCLK=1;//拉高CLK端 ADDI=(channel>>1)&0x1; _nop_(); _nop_(); ADCLK=0;//拉低CLK端,形成下降沿3 ADDI=1;//控制命令结束 _nop_(); _nop_(); dat=0; for(i=0;i<8;i++) { dat|=ADDO;//收数据 ADCLK=1; _nop_(); _nop_(); ADCLK=0;//形成一次时钟脉冲 _nop_(); _nop_(); dat<<=1; if(i==7)dat|=ADDO; } for(i=0;i<8;i++) { j=0 j=j|ADDO;//收数据 ADCLK=1; _nop_(); _nop_(); ADCLK=0;//形成一次时钟脉冲 _nop_(); _nop_(); j=j<<7; ndat=ndat|j; if(i<7)ndat>>=1; } ADCS=1;//拉低CS端 ADCLK=0;//拉低CLK端 ADDO=1; dat<<=8; dat|=ndat; return(dat); //return ad k } void data_pro(void) { unsigned int; float press; if(0 int vary=ad_data; press=(0.012*vary); temp1=(int)(press*1000);//放大1000倍,便于后面的计算 press_ge=temp1/1000; //取压力值百位 press_shifen=(temp1%1000)/100;//取压力值十位 press_baifen=((temp1%1000)%100)/10;//取压力值个位 press_ge=((temp1%1000)%100)%10;//取压力值十分位 } } /***********报警子函数****************/ void alarm(void) { if(ad_data>223) speaker=0;//则启动报警 else speaker=1; } void weishu(uint m) { uchar wei4,wei3,wei2,wei1,wei0; wei4=m/10000; wei3=m%10000/1000; wei2=m%1000/100; wei1=m%100/10; wei0=m%10; DisplayOneChar(7,1,0x30+wei4); DisplayOneChar(8,1,0x30+wei3); DisplayOneChar(10,1,0x30+wei2); //DisplayOneChar(10,1,`.`); DisplayOneChar(11,1,0x30+wei1); DisplayOneChar(12,1,0x30+wei0); } void weishu1(uint m) { uchar wei5,wei4,wei3,wei2,wei1,wei0; wei5=m/100000; wei4=m%100000/10000; wei3=m%10000/1000; wei2=m%1000/100; wei1=m%100/10; wei0=m%10; DisplayOneChar(7,1,0x30+wei4); DisplayOneChar(8,1,0x30+wei3); DisplayOneChar(9,1,`.`); DisplayOneChar(10,1,0x30+wei2); //DisplayOneChar(10,1,`.`); DisplayOneChar(11,1,0x30+wei1); DisplayOneChar(12,1,0x30+wei0 } /***********键盘扫描子程序*************/ void temer1()interrupt3 { uchar temp; EX1=0; P1=0xfe; temp=P1; temp=temp&0xf0; if(temp!=0xf0) { delay(5); temp=P1; temp=temp&0xf0; while(temp!=0xf0) { temp=P1; switch(temp) { case 0xee:num=1;n=7;k=1;s++;break; case 0xde:num=2;n=8;k=1;s++;break; case 0xbe:num=3;n=9;k=1;s++;break; case 0x7e:num=4;k=`/`;s++;break; } while(temp!=0xf0) { temp=P1; temp=temp&0xf0; } //DisplayOneChar((s+6),1,table2[num-1]); } } P1=0xfd; temp=P1; temp=temp&0xf0; if(temp!=0xf0) { delay(5); temp=P1; temp=temp&0xf0; while(temp!=0xf0) { temp=P1; switch(temp) { case 0xed:num=5;n=4;k=1;s++;break; case 0xdd:num=6;n=5;k=1;s++;break; case 0xbd:num=7;n=6;k=1;s++;break; case 0x7d:num=8;k=`*`;s++;break; } while(temp!=0xf0) { temp=P1; temp=temp&0xf0; } //DisplayOneChar((k+6),1,table2[num-1]); } } P1=0xfb; temp=P1; temp=temp&0xf0; if(temp!=0xf0) { delay(5); temp=P1; temp=temp&0xf0; while(temp!=0xf0) { temp=P1; switch(temp) { case 0xeb:num=9;n=1;k=1;s++;break; case 0xdb:num=10;n=2;k=1;s++;break; case 0xbb:num=11;n=3;k=1;s++;break; case 0x7b:num=12;k=`-`;s++;break; } while(temp!=0xf0) { temp=P1; temp=temp&0xf0; } //DisplayOneChar((k+6),1,table2[num-1]); } } P1=0xf7; temp=P1; temp=temp&0xf0; if(temp!=0xf0) { delay(5); temp=P1; temp=temp&0xf0; while(temp!=0xf0) { temp=P1; switch(temp) { case 0xe7:num=13;;k=``;break; case 0xd7:num=14;n=0;k=1;s++;break; case 0xb7:num=15;;k=`=`;s++;break; case 0x77:num=16;k=`+`;s++;break; } while(temp!=0xf0) { temp=P1; temp=temp&0xf0; } //DisplayOneChar((k+6),1,table2[num-1]); } } EX1=1; } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
GMT+8, 2024-12-30 20:41 , Processed in 0.753141 second(s), Total 79, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
