扫一扫,分享给好友
请教论坛里热心的朋友,有没有碰到过类似的问题,有什么好的解决思路? 编译结果正确: Building configuration: Test - Debug Updating build tree... Configuration is up-to-date. 开始下载: 点击 download and debug 后 出现如下图所示问题 log显示为: Tue Nov 12, 2013 17:21:22: Loaded macro file: D:Program Files (x86)IAR SystemsEmbedded Workbench 6.0armconfigflashloaderFreescaleFlashK60Xxxx.mac Tue Nov 12, 2013 17:21:23: JLINK command: ProjectFile = F:armk60myprojectIAR-ucosiiisettingsTest_Debug.jlink, return = 0 Tue Nov 12, 2013 17:21:23: Device "K60DN512Z" selected (512 KB flash, 32 KB RAM). Tue Nov 12, 2013 17:21:23: JLINK command: device = MK60DN512Zxxx10, return = 0 Tue Nov 12, 2013 17:21:23: DLL version: V4.36f, compiled Oct 22 2011 15:21:42 Tue Nov 12, 2013 17:21:23: Firmware: J-Link ARM V8 compiled Sep 22 2011 16:23:23 Tue Nov 12, 2013 17:21:23: JTAG speed is initially set to: 32 kHz Tue Nov 12, 2013 17:21:23: TotalIRLen = 4, IRPrint = 0x01 Tue Nov 12, 2013 17:21:23: Found Cortex-M4 r0p0, Little endian. Tue Nov 12, 2013 17:21:24: TPIU fitted. Tue Nov 12, 2013 17:21:24: ETM fitted. Tue Nov 12, 2013 17:21:24: ETB present. Tue Nov 12, 2013 17:21:24: CSTF present. Tue Nov 12, 2013 17:21:24: FPUnit: 6 code (BP) slots and 2 literal slots Tue Nov 12, 2013 17:21:24: Hardware reset with strategy 0 was performed Tue Nov 12, 2013 17:21:24: Initial reset was performed Tue Nov 12, 2013 17:21:24: Found 1 JTAG device, Total IRLen = 4: Tue Nov 12, 2013 17:21:24: #0 Id: 0x4BA00477, IRLen: 4, IRPrint: 0x1 CoreSight JTAG-DP Tue Nov 12, 2013 17:21:25: ----- Prepare hardware for Flashloader ----- Tue Nov 12, 2013 17:21:25: 1280 bytes downloaded (8.93 Kbytes/sec) Tue Nov 12, 2013 17:21:25: Loaded debugee: D:Program Files (x86)IAR SystemsEmbedded Workbench 6.0armconfigflashloaderFreescaleFlashK60Xxxx.out Tue Nov 12, 2013 17:21:25: Target reset Tue Nov 12, 2013 17:21:25: The flash loader program reported an error. |
8个回答
期待朋友的帮忙
问题解决了,原来是芯片被锁上了,可是之前还好好的可以下载的,下载一个操作系统之后芯片就被锁住了,奇怪???
解决问题:首先Jlink文件夹里要有erase_all_pin.jlk。。。然后:运行->cmd->输入“cd 你的JlinK安装路径” ->Jlink.exe erase_all_pin.jlk |
哈哈 是的 谢谢您的帮助。请问您开始移植了吗? 我出现新的问题了,先说一下操作系统是ucosiii 。出现的问题是寄存器不能压入堆栈。 |
{:20:}{:20:}{:20:}{:20:}
没有,我才开始学习操作系统UCOS2,现在还搞不清楚,初学中 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
非科班也能玩转Android应用,体验QT跨平台能力-迅为RK3568开发板
414 浏览 0 评论
飞凌嵌入式-ELFBOARD-ELF 2硬件分享之最小系统原理
658 浏览 0 评论
1676 浏览 0 评论
Cortex-A55 处理器到底什么来头?创龙教仪一文带您了解
969 浏览 0 评论
RK3568 + OpenCV 会碰撞出什么火花?案例详解:2-1 基于OpenCV的画线实验
743 浏览 0 评论
GMT+8, 2024-12-12 08:39 , Processed in 0.947942 second(s), Total 87, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
