- static struct class *spi_class;
- static struct cdev spicdev;
- dev_t devno;
- volatile unsigned long *spi_gpecon=NULL;
- volatile unsigned long *spi_gpedat=NULL;
- volatile unsigned long *spi_gpeup=NULL;
- volatile unsigned long *spi_gpgcon=NULL;
- volatile unsigned long *spi_gpgdat=NULL;
- volatile unsigned long *spi_gpgup=NULL;
- volatile unsigned long *s3c2440_clkcon;
- volatile unsigned long *spi_spcon0;
- volatile unsigned long *spi_spsta0;
- volatile unsigned long *spi_sppin0;
- volatile unsigned long *spi_sppre0;
- volatile unsigned long *spi_sptdat0;
- volatile unsigned long *spi_sprdat0;
- #define SPI_TXRX_READY (((*spi_spsta0)&0x1) == 0x1)
- #define SPI_CS (((*spi_gpgdat)&0x4)==0x01)
- /***********nSS_SPI GPG2 SPICLK GPE13 -26
- SPIMOSI GPE12-25 SPIMISO GPE11-24************/
- static int spi_open(struct inode *inode,struct file *filp)
- *s3c2440_clkcon |=0x40000;//使能SPI
- *spi_gpecon &=0xF03FFFF;//配置SPI
- *spi_gpecon |=0xA800000;//
- // *spi_gpeup &=0xc7ff;//使能上拉电阻
- *spi_gpgcon|=(3<<4);//配置nSS0
- //*spi_gpgup &= 0xFB;
- *spi_sppre0=0x06; // > 5M
- *spi_spcon0=(0<<6)|(0<<5)|(0<<4)|(0<<3)|(1<<2)|(1<<1)|(1<<0);
- printk("spi_spcon0=%02Xn",(unsigned int)*spi_spcon0);
- *spi_sppin0=(0<<2)|(0<<0);
- printk("spi_sppin0=%02Xn",(unsigned int)*spi_sppin0);
- return 0;
- static ssize_t spi_read(struct file *filp,char __user *buf,size_t count,loff_t *f_ops)
- char ch;
- while(!SPI_TXRX_READY);
- ch= (char)*spi_sprdat0;
- copy_to_user(buf,&ch,1);
- return 1;
- static int spi_release(struct inode *inode,struct file *filp)
- printk("<1>releasen");
- return 0;
- static ssize_t spi_write(struct file *filp,const char __user *buf,size_t count,loff_t *f_ops)
- return 0;
- static ssize_t spi_ioctl(struct inode *inode,struct file *filp,unsigned int cmd,unsigned long data)
- return 0;
- static struct file_operations spi_drv_fops = {
- .owner=THIS_MODULE,
- .open=spi_open,
- .read=spi_read,
- .ioctl=spi_ioctl,
- .release=spi_release,
- .write=spi_write,
- static int __init spi_init(void)
- int result;
- result = alloc_chrdev_region(&devno, 0, 1, "spi_drv");
- if (result < 0)
- return result;
- cdev_init(&spicdev, &spi_drv_fops);
- spicdev.owner = THIS_MODULE;
- spicdev.ops = &spi_drv_fops;
- cdev_add(&spicdev, devno, 1);
- spi_class = class_create(THIS_MODULE, "spi_drv");
- device_create(spi_class, NULL, devno, NULL, "S3C2440_SPI"); /* /dev/S3C2440_SPI */
- s3c2440_clkcon = (volatile unsigned long *)ioremap(0x4C00000c,3);
- spi_gpgcon = (volatile unsigned long *)ioremap (0x56000060,4);
- spi_gpgdat = (volatile unsigned long *)ioremap (0x56000064,2);
- spi_gpgup = (volatile unsigned long *)ioremap (0x56000068,2);
- spi_gpecon = (volatile unsigned long *)ioremap (0x56000040,2);
- spi_gpedat = (volatile unsigned long *)ioremap (0x56000044,1);
- spi_gpeup = (volatile unsigned long *)ioremap (0x56000048,1);
- spi_spcon0 = (volatile unsigned long *)ioremap(0x59000000,1);
- spi_spsta0 = (volatile unsigned long *)ioremap(0x59000004,1);
- spi_sppin0 = (volatile unsigned long *)ioremap(0x59000008,1);
- spi_sppre0 = (volatile unsigned long *)ioremap(0x5900000c,1);
- spi_sptdat0 = (volatile unsigned long *)ioremap(0x59000010,1);
- spi_sprdat0 = (volatile unsigned long *)ioremap(0x59000014,1);
- printk("Init spi success!n");
- return result;
- static void __exit spi_exit(void)
- cdev_del(&spicdev);
- unregister_chrdev_region(devno, 1);
- device_destroy(spi_class,devno);
- class_destroy(spi_class);
- iounmap(s3c2440_clkcon);
- iounmap(spi_gpgcon);
- iounmap(spi_gpgdat);
- iounmap(spi_gpgup);
- iounmap(spi_gpecon);
- iounmap(spi_gpedat);
- iounmap(spi_gpeup);
- iounmap(spi_spcon0);
- iounmap(spi_spsta0);
- iounmap(spi_sppin0);
- iounmap(spi_sppre0);
- iounmap(spi_sptdat0);
- iounmap(spi_sprdat0);
- printk("<1>spi_exit!n");
- module_init(spi_init);
- module_exit(spi_exit);
复制代码
3个回答
