电子发烧友论坛|
#include #include "config.h" #include "def.h" #include /*********** RC alias *****************/ enum rc { ROLL, PITCH, YAW, THROTTLE, AUX1, AUX2, AUX3, AUX4 }; enum pid { PIDROLL, PIDPITCH, PIDYAW, PIDALT, PIDPOS, PIDPOSR, PIDNAVR, PIDLEVEL, PIDMAG, PIDVEL, // not used currently PIDITEMS }; const char pidnames[] PROGMEM = "ROLL;" "PITCH;" "YAW;" "ALT;" "Pos;" "PosR;" "NavR;" "LEVEL;" "MAG;" "VEL;" ; enum box { BOXARM, #if ACC BOXANGLE, BOXHORIZON, #endif #if BARO && (!defined(SUPPRESS_BARO_ALTHOLD)) BOXBARO, #endif #ifdef VARIOMETER BOXVARIO, #endif #if MAG BOXMAG, BOXHEADFREE, BOXHEADADJ, // acquire heading for HEADFREE mode #endif #if defined(SERVO_tiLT) || defined(GIMBAL) || defined(SERVO_MIX_TILT) BOXCAMSTAB, #endif #if defined(CAMTRIG) BOXCAMTRIG, #endif #if GPS BOXGPSHOME, BOXGPSHOLD, #endif #if defined(FIXEDWING) || defined(HELICOPTER) BOXPASSTHRU, #endif #if defined(BUZZER) BOXBEEPERON, #endif #if defined(LED_FLASHER) BOXLEDMAX, // we want maximum illumination BOXLEDLOW, // low/no lights #endif #if defined(LANDING_LIGHTS_DDR) BOXLLIGHTS, // enable landing lights at any altitude #endif #ifdef INFLIGHT_ACC_CALIBRATION BOXCALIB, #endif #ifdef GOVERNOR_P BOXGOV, #endif #ifdef OSD_SWITCH BOXOSD, #endif CHECKBOXITEMS }; const char boxnames[] PROGMEM = // names for dynamic generation of config GUI "ARM;" #if ACC "ANGLE;" "HORIZON;" #endif #if BARO && (!defined(SUPPRESS_BARO_ALTHOLD)) "BARO;" #endif #ifdef VARIOMETER "VARIO;" #endif #if MAG "MAG;" "HEADFREE;" "HEADADJ;" #endif #if defined(SERVO_TILT) || defined(GIMBAL)|| defined(SERVO_MIX_TILT) "CAMSTAB;" #endif #if defined(CAMTRIG) "CAMTRIG;" #endif #if GPS "GPS HOME;" "GPS HOLD;" #endif #if defined(FIXEDWING) || defined(HELICOPTER) "PASSTHRU;" #endif #if defined(BUZZER) "BEEPER;" #endif #if defined(LED_FLASHER) "LEDMAX;" "LEDLOW;" #endif #if defined(LANDING_LIGHTS_DDR) "LLIGHTS;" #endif #ifdef INFLIGHT_ACC_CALIBRATION "CALIB;" #endif #ifdef GOVERNOR_P "GOVERNOR;" #endif #ifdef OSD_SWITCH "OSD SW;" #endif ; const uint8_t boxids[] PROGMEM = {// permanent IDs associated to boxes. This way, you can rely on an ID number to identify a BOX function. 0, //"ARM;" #if ACC 1, //"ANGLE;" 2, //"HORIZON;" #endif #if BARO && (!defined(SUPPRESS_BARO_ALTHOLD)) 3, //"BARO;" #endif #ifdef VARIOMETER 4, //"VARIO;" #endif #if MAG 5, //"MAG;" 6, //"HEADFREE;" 7, //"HEADADJ;" #endif #if defined(SERVO_TILT) || defined(GIMBAL)|| defined(SERVO_MIX_TILT) 8, //"CAMSTAB;" #endif #if defined(CAMTRIG) 9, //"CAMTRIG;" #endif #if GPS 10, //"GPS HOME;" 11, //"GPS HOLD;" #endif #if defined(FIXEDWING) || defined(HELICOPTER) 12, //"PASSTHRU;" #endif #if defined(BUZZER) 13, //"BEEPER;" #endif #if defined(LED_FLASHER) 14, //"LEDMAX;" 15, //"LEDLOW;" #endif #if defined(LANDING_LIGHTS_DDR) 16, //"LLIGHTS;" #endif #ifdef INFLIGHT_ACC_CALIBRATION 17, //"CALIB;" #endif #ifdef GOVERNOR_P 18, //"GOVERNOR;" #endif #ifdef OSD_SWITCH 19, //"OSD_SWITCH;" #endif }; static uint32_t currentTime = 0; static uint16_t previousTime = 0; static uint16_t cycleTime = 0; // this is the number in micro second to achieve a full loop, it can differ a little and is taken into account in the PID loop static uint16_t calibratingA = 0; // the calibration is done in the main loop. Calibrating decreases at each cycle down to 0, then we enter in a normal mode. static uint16_t calibratingB = 0; // baro calibration = get new ground pressure value static uint16_t calibratingG; static uint16_t acc_1G; // this is the 1G measured acceleration static uint16_t acc_25deg; static int16_t gyroADC[3],accADC[3],accSmooth[3],magADC[3]; static int16_t heading,magHold,headFreeModeHold; // [-180;+180] static uint8_t vbat; // battery voltage in 0.1V steps static uint8_t vbatMin = VBATNOMINAL; // lowest battery voltage in 0.1V steps static uint8_t rcOptions[CHECKBOXITEMS]; static int32_t BaroAlt,EstAlt,AltHold; // in cm static int16_t BaroPID = 0; static int16_t errorAltitudeI = 0; static int16_t vario = 0; // variometer in cm/s #if defined(ARMEDTIMEWARNING) static uint32_t ArmedTimeWarningMicroSeconds = 0; #endif static int16_t debug[4]; static int16_t sonarAlt; //to think about the unit struct flags_struct { uint8_t OK_TO_ARM :1 ; uint8_t ARMED :1 ; uint8_t I2C_INIT_DONE :1 ; // For i2c gps we have to now when i2c init is done, so we can update parameters to the i2cgps from eeprom (at startup it is done in setup()) uint8_t ACC_CALIBRATED :1 ; uint8_t NUNCHUKDATA :1 ; uint8_t ANGLE_MODE :1 ; uint8_t HORIZON_MODE :1 ; uint8_t MAG_MODE :1 ; uint8_t BARO_MODE :1 ; uint8_t GPS_HOME_MODE :1 ; uint8_t GPS_HOLD_MODE :1 ; uint8_t HEADFREE_MODE :1 ; uint8_t PASSTHRU_MODE :1 ; uint8_t GPS_FIX :1 ; uint8_t GPS_FIX_HOME :1 ; uint8_t SMALL_ANGLES_25 :1 ; uint8_t CALIBRATE_MAG :1 ; uint8_t VARIO_MODE :1; } f; //for log #if defined(LOG_VALUES) || defined(LCD_TELEMETRY) static uint16_t cycleTimeMax = 0; // highest ever cycle timen static uint16_t cycleTimeMin = 65535; // lowest ever cycle timen static uint16_t powerMax = 0; // highest ever current; static int32_t BAROaltMax; // maximum value #endif #if defined(LOG_VALUES) || defined(LCD_TELEMETRY) || defined(ARMEDTIMEWARNING) || defined(LOG_PERMANENT) static uint32_t armedTime = 0; #endif static int16_t i2c_errors_count = 0; static int16_t annex650_overrun_count = 0; // ********************** //Automatic ACC Offset Calibration // ********************** #if defined(INFLIGHT_ACC_CALIBRATION) static uint16_t InflightcalibratingA = 0; static int16_t AccInflightCalibrationArmed; static uint16_t AccInflightCalibrationMeasurementDone = 0; static uint16_t AccInflightCalibrationSavetoEEProm = 0; static uint16_t AccInflightCalibrationActive = 0; #endif // ********************** // power meter // ********************** #if defined(POWERMETER) #define PMOTOR_SUM 8 // index into pMeter[] for sum static uint32_t pMeter[PMOTOR_SUM + 1]; // we use [0:7] for eight motors,one extra for sum static uint8_t pMeterV; // dummy to satisfy the paramStruct logic in ConfigurationLoop() static uint32_t pAlarm; // we scale the eeprom value from [0:255] to this value we can directly compare to the sum in pMeter[6] static uint16_t powerValue = 0; // last known current #endif static uint16_t intPowerMeterSum, intPowerTrigger1; // ********************** // telemetry // ********************** #if defined(LCD_TELEMETRY) static uint8_t telemetry = 0; static uint8_t telemetry_auto = 0; #endif #ifdef LCD_TELEMETRY_STEP static char telemetryStepSequence [] = LCD_TELEMETRY_STEP; static uint8_t telemetryStepIndex = 0; #endif // ****************** // rc functions // ****************** #define MINCHECK 1100 #define MAXCHECK 1900 #define ROL_LO (1<<(2*ROLL)) #define ROL_CE (3<<(2*ROLL)) #define ROL_HI (2<<(2*ROLL)) #define PIT_LO (1<<(2*PITCH)) #define PIT_CE (3<<(2*PITCH)) #define PIT_HI (2<<(2*PITCH)) #define YAW_LO (1<<(2*YAW)) #define YAW_CE (3<<(2*YAW)) #define YAW_HI (2<<(2*YAW)) #define THR_LO (1<<(2*THROTTLE)) #define THR_CE (3<<(2*THROTTLE)) #define THR_HI (2<<(2*THROTTLE)) static int16_t failsafeEvents = 0; volatile int16_t failsafeCnt = 0; static int16_t rcData[RC_CHANS]; // interval [1000;2000] static int16_t rcCommand[4]; // interval [1000;2000] for THROTTLE and [-500;+500] for ROLL/PITCH/YAW static int16_t lookupPitchRollRC[6];// lookup table for expo & RC rate PITCH+ROLL static int16_t lookupThrottleRC[11];// lookup table for expo & mid THROTTLE static uint16_t rssi; // range: [0;1023] #if defined(SPEKTRUM) volatile uint8_t spekFrameFlags; volatile uint32_t spekTimeLast; #endif #if defined(OPENLRSv2MULTI) static uint8_t pot_P,pot_I; // OpenLRS onboard potentiometers for P and I trim or other usages #endif // ************** // gyro+acc IMU // ************** static int16_t gyroData[3] = {0,0,0}; static int16_t gyroZero[3] = {0,0,0}; static int16_t angle[2] = {0,0}; // absolute angle inclination in multiple of 0.1 degree 180 deg = 1800 // ************************* // motor and servo functions // ************************* static int16_t axisPID[3]; static int16_t motor[NUMBER_MOTOR]; #if defined(SERVO) static int16_t servo[8] = {1500,1500,1500,1500,1500,1500,1500,1500}; #endif // ************************ // EEPROM Layout definition // ************************ static uint8_t dynP8[3], dynD8[3]; static struct { uint8_t currentSet; int16_t accZero[3]; int16_t magZero[3]; uint8_t checksum; // MUST BE ON LAST POSITION OF STRUCTURE ! } global_conf; static struct { uint8_t checkNewConf; uint8_t P8[PIDITEMS], I8[PIDITEMS], D8[PIDITEMS]; uint8_t rcRate8; uint8_t rcExpo8; uint8_t rollPitchRate; uint8_t yawRate; uint8_t dynThrPID; uint8_t thrMid8; uint8_t thrExpo8; int16_t angleTrim[2]; uint16_t activate[CHECKBOXITEMS]; uint8_t powerTrigger1; #ifdef FLYING_WING uint16_t wing_left_mid; uint16_t wing_right_mid; #endif #ifdef TRI uint16_t tri_yaw_middle; #endif #if defined HELICOPTER || defined(AIRPLANE)|| defined(SINGLECOPTER)|| defined(DUALCOPTER) int16_t servoTrim[8]; #endif #if defined(GYRO_SMOOTHING) uint8_t Smoothing[3]; #endif #if defined (FAILSAFE) int16_t failsafe_throttle; #endif #ifdef VBAT uint8_t vbatscale; uint8_t vbatlevel_warn1; uint8_t vbatlevel_warn2; uint8_t vbatlevel_crit; uint8_t no_vbat; #endif #ifdef POWERMETER uint16_t psensornull; uint16_t pleveldivsoft; uint16_t pleveldiv; uint8_t pint2ma; #endif #ifdef CYCLETIME_FIXATED uint16_t cycletime_fixated; #endif #ifdef MMGYRO uint8_t mmgyro; #endif #ifdef ARMEDTIMEWARNING uint16_t armedtimewarning; #endif int16_t minthrottle; #ifdef GOVERNOR_P int16_t governorP; int16_t governorD; int8_t governorR; #endif uint8_t checksum; // MUST BE ON LAST POSITION OF CONF STRUCTURE ! } conf; #ifdef LOG_PERMANENT static struct { uint16_t arm; // #arm events uint16_t disarm; // #disarm events uint16_t start; // #powercycle/reset/initialize events uint32_t armed_time ; // copy of armedTime @ disarm uint32_t lifetime; // sum (armed) lifetime in seconds uint16_t failsafe; // #failsafe state @ disarm uint16_t i2c; // #i2c errs state @ disarm uint8_t running; // toggle on arm & disarm to monitor for clean shutdown vs. powercut uint8_t checksum; // MUST BE ON LAST POSITION OF CONF STRUCTURE ! } plog; #endif // ********************** // GPS common variables // ********************** static int32_t GPS_coord[2]; static int32_t GPS_home[2]; static int32_t GPS_hold[2]; static uint8_t GPS_numSat; static uint16_t GPS_distanceToHome; // distance to home - unit: meter static int16_t GPS_directionToHome; // direction to home - unit: degree static uint16_t GPS_altitude; // GPS altitude - unit: meter static uint16_t GPS_speed; // GPS speed - unit: cm/s static uint8_t GPS_update = 0; // a binary toogle to distinct a GPS position update static int16_t GPS_angle[2] = { 0, 0}; // the angles that must be applied for GPS correction static uint16_t GPS_ground_course = 0; // - unit: degree*10 static uint8_t GPS_Present = 0; // Checksum from Gps serial static uint8_t GPS_Enable = 0; #define LAT 0 #define LON 1 // The desired bank towards North (Positive) or South (Negative) : latitude // The desired bank towards East (Positive) or West (Negative) : longitude static int16_t nav[2]; static int16_t nav_rated[2]; //Adding a rate controller to the navigation to make it smoother // default POSHOLD control gains #define POSHOLD_P .11 #define POSHOLD_I 0.0 #define POSHOLD_IMAX 20 // degrees #define POSHOLD_RATE_P 2.0 #define POSHOLD_RATE_I 0.08 // Wind control #define POSHOLD_RATE_D 0.045 // try 2 or 3 for POSHOLD_RATE 1 #define POSHOLD_RATE_IMAX 20 // degrees // default Navigation PID gains #define NAV_P 1.4 #define NAV_I 0.20 // Wind control #define NAV_D 0.08 // #define NAV_IMAX 20 // degrees ///////////////////////////////////////////////////////////////////////////////////////////////////////////// // Serial GPS only variables //navigation mode #define NAV_MODE_NONE 0 #define NAV_MODE_POSHOLD 1 #define NAV_MODE_WP 2 static uint8_t nav_mode = NAV_MODE_NONE; // Navigation mode static uint8_t alarmArray[16]; // array #if BARO static int32_t baroPressure; static int32_t baroTemperature; static int32_t baroPressureSum; #endif void annexCode() { // this code is excetuted at each loop and won't interfere with control loop if it lasts less than 650 microseconds static uint32_t calibratedAccTime; uint16_t tmp,tmp2; uint8_t axis,prop1,prop2; #define BREAKPOINT 1500 // PITCH & ROLL only dynamic PID adjustemnt, depending on throttle value if (rcData[THROTTLE] } else { if (rcData[THROTTLE]<2000) { prop2 = 100 - (uint16_t)conf.dynThrPID*(rcData[THROTTLE]-BREAKPOINT)/(2000-BREAKPOINT); } else { prop2 = 100 - conf.dynThrPID; } } for(axis=0;axis<3;axis++) { tmp = min(abs(rcData[axis]-MIDRC),500); #if defined(DEADBAND) if (tmp>DEADBAND) { tmp -= DEADBAND; } else { tmp=0; } #endif if(axis!=2) { //ROLL & PITCH tmp2 = tmp/100; rcCommand[axis] = lookupPitchRollRC[tmp2] + (tmp-tmp2*100) * (lookupPitchRollRC[tmp2+1]-lookupPitchRollRC[tmp2]) / 100; prop1 = 100-(uint16_t)conf.rollPitchRate*tmp/500; prop1 = (uint16_t)prop1*prop2/100; } else { // YAW rcCommand[axis] = tmp; prop1 = 100-(uint16_t)conf.yawRate*tmp/500; } dynP8[axis] = (uint16_t)conf.P8[axis]*prop1/100; dynD8[axis] = (uint16_t)conf.D8[axis]*prop1/100; if (rcData[axis] tmp = constrain(rcData[THROTTLE],MINCHECK,2000); tmp = (uint32_t)(tmp-MINCHECK)*1000/(2000-MINCHECK); // [MINCHECK;2000] -> [0;1000] tmp2 = tmp/100; rcCommand[THROTTLE] = lookupThrottleRC[tmp2] + (tmp-tmp2*100) * (lookupThrottleRC[tmp2+1]-lookupThrottleRC[tmp2]) / 100; // [0;1000] -> expo -> [conf.minthrottle;MAXTHROTTLE] if(f.HEADFREE_MODE) { //to optimize float radDiff = (heading - headFreeModeHold) * 0.0174533f; // where PI/180 ~= 0.0174533 float cosDiff = cos(radDiff); float sinDiff = sin(radDiff); int16_t rcCommand_PITCH = rcCommand[PITCH]*cosDiff + rcCommand[ROLL]*sinDiff; rcCommand[ROLL] = rcCommand[ROLL]*cosDiff - rcCommand[PITCH]*sinDiff; rcCommand[PITCH] = rcCommand_PITCH; } #if defined(POWERMETER_HARD) uint16_t pMeterRaw; // used for current reading static uint16_t psensorTimer = 0; if (! (++psensorTimer % PSENSORFREQ)) { pMeterRaw = analogRead(PSENSORPIN); //lcdprint_int16(pMeterRaw); LCDcrlf(); powerValue = ( conf.psensornull > pMeterRaw ? conf.psensornull - pMeterRaw : pMeterRaw - conf.psensornull); // do not use abs(), it would induce implicit cast to uint and overrun if ( powerValue < 333) { // only accept reasonable values. 333 is empirical #ifdef LCD_TELEMETRY if (powerValue > powerMax) powerMax = powerValue; #endif } else { powerValue = 333; } pMeter[PMOTOR_SUM] += (uint32_t) powerValue; } #endif #if defined(BUZZER) #if defined(VBAT) static uint8_t vbatTimer = 0; static uint8_t ind = 0; uint16_t vbatRaw = 0; static uint16_t vbatRawArray[8]; if (! (++vbatTimer % VBATFREQ)) { vbatRawArray[(ind++)%8] = analogRead(V_BATPIN); for (uint8_t i=0;i<8;i++) vbatRaw += vbatRawArray; vbat = (vbatRaw*2) / conf.vbatscale; // result is Vbatt in 0.1V steps } #endif alarmHandler(); // external buzzer routine that handles buzzer events globally now #endif #if defined(RX_RSSI) static uint8_t sig = 0; uint16_t rssiRaw = 0; static uint16_t rssiRawArray[8]; rssiRawArray[(sig++)%8] = analogRead(RX_RSSI_PIN); for (uint8_t i=0;i<8;i++) rssiRaw += rssiRawArray; rssi = rssiRaw / 8; #endif if ( (calibratingA>0 && ACC ) || (calibratingG>0) ) { // Calibration phasis LEDPIN_TOGGLE; } else { if (f.ACC_CALIBRATED) {LEDPIN_OFF;} if (f.ARMED) {LEDPIN_ON;} } #if defined(LED_RING) static uint32_t LEDTime; if ( currentTime > LEDTime ) { LEDTime = currentTime + 50000; i2CLedRingState(); } #endif #if defined(LED_FLASHER) auto_switch_led_flasher(); #endif if ( currentTime > calibratedAccTime ) { if (! f.SMALL_ANGLES_25) { // the multi uses ACC and is not calibrated or is too much inclinated f.ACC_CALIBRATED = 0; LEDPIN_TOGGLE; calibratedAccTime = currentTime + 100000; } else { f.ACC_CALIBRATED = 1; } } /* #if !(defined(SPEKTRUM) && defined(PROMINI)) //Only one serial port on ProMini. Skip serial com if Spektrum Sat in use. Note: Spek code will auto-call serialCom if GUI data detected on serial0. #if defined(GPS_PROMINI) if(GPS_Enable == 0) {serialCom();} #else serialCom(); #endif #endif */ #if defined(POWERMETER) intPowerMeterSum = (pMeter[PMOTOR_SUM]/conf.pleveldiv); intPowerTrigger1 = conf.powerTrigger1 * PLEVELSCALE; #endif #ifdef LCD_TELEMETRY_AUTO static char telemetryAutoSequence [] = LCD_TELEMETRY_AUTO; static uint8_t telemetryAutoIndex = 0; static uint16_t telemetryAutoTimer = 0; if ( (telemetry_auto) && (! (++telemetryAutoTimer % LCD_TELEMETRY_AUTO_FREQ) ) ){ telemetry = telemetryAutoSequence[++telemetryAutoIndex % strlen(telemetryAutoSequence)]; LCDclear(); // make sure to clear away remnants } #endif #ifdef LCD_TELEMETRY static uint16_t telemetryTimer = 0; if (! (++telemetryTimer % LCD_TELEMETRY_FREQ)) { #if (LCD_TELEMETRY_DEBUG+0 > 0) telemetry = LCD_TELEMETRY_DEBUG; #endif if (telemetry) lcd_telemetry(); } #endif #if GPS & defined(GPS_LED_INDICATOR) // modified by MIS to use STABLEPIN LED for number of sattelites indication static uint32_t GPSLEDTime; // - No GPS FIX -> LED blink at speed of incoming GPS frames static uint8_t blcnt; // - Fix and sat no. bellow 5 -> LED off if(currentTime > GPSLEDTime) { // - Fix and sat no. >= 5 -> LED blinks, one blink for 5 sat, two blinks for 6 sat, three for 7 ... if(f.GPS_FIX && GPS_numSat >= 5) { if(++blcnt > 2*GPS_numSat) blcnt = 0; GPSLEDTime = currentTime + 150000; if(blcnt >= 10 && ((blcnt%2) == 0)) {STABLEPIN_ON;} else {STABLEPIN_OFF;} }else{ if((GPS_update == 1) && !f.GPS_FIX) {STABLEPIN_ON;} else {STABLEPIN_OFF;} blcnt = 0; } } #endif #if defined(LOG_VALUES) && (LOG_VALUES >= 2) if (cycleTime > cycleTimeMax) cycleTimeMax = cycleTime; // remember highscore if (cycleTime < cycleTimeMin) cycleTimeMin = cycleTime; // remember lowscore #endif if (f.ARMED) { #if defined(LCD_TELEMETRY) || defined(ARMEDTIMEWARNING) || defined(LOG_PERMANENT) armedTime += (uint32_t)cycleTime; #endif #if defined(VBAT) if ( (vbat > conf.no_vbat) && (vbat < vbatMin) ) vbatMin = vbat; #endif #ifdef LCD_TELEMETRY #if BARO if ( (BaroAlt > BAROaltMax) ) BAROaltMax = BaroAlt; #endif #endif } } void setup() { /* #if !defined(GPS_PROMINI) SerialOpen(0,SERIAL0_COM_SPEED); #if defined(PROMICRO) SerialOpen(1,SERIAL1_COM_SPEED); #endif #if defined(MEGA) SerialOpen(1,SERIAL1_COM_SPEED); SerialOpen(2,SERIAL2_COM_SPEED); SerialOpen(3,SERIAL3_COM_SPEED); #endif #endif */ Serial.begin(38400); /* LEDPIN_PINMODE; POWERPIN_PINMODE; BUZZERPIN_PINMODE; STABLEPIN_PINMODE; POWERPIN_OFF; */ initOutput(); /* #ifdef MULTIPLE_CONFIGURATION_PROFILES for(global_conf.currentSet=0; global_conf.currentSet<3; global_conf.currentSet++) { // check all settings integrity readEEPROM(); } #else global_conf.currentSet=0; readEEPROM(); #endif readGlobalSet(); readEEPROM(); // load current setting data blinkLED(2,40,global_conf.currentSet+1); */ configureReceiver(); /* #if defined (PILOTLAMP) //航行灯 PL_INIT; #endif #if defined(OPENLRSv2MULTI) //串行通信协议 initOpenLRS(); #endif */ initSensors(); /* #if defined(I2C_GPS) || defined(GPS_SERIAL) || defined(GPS_FROM_OSD) GPS_set_pids(); #endif */ previousTime = micros(); #if defined(GIMBAL) calibratingA = 512; //A---Acceletation #endif calibratingG = 512; // G---gyroscope //calibratingB = 200; // B---barometer 10 seconds init_delay + 200 * 25 ms = 15 seconds before ground pressure settles /* #if defined(POWERMETER) for(uint8_t i=0;i<=PMOTOR_SUM;i++) pMeter=0; #endif /************************************/ /* #if defined(GPS_SERIAL) GPS_SerialInit(); for(uint8_t i=0;i<=5;i++){ GPS_NewData(); LEDPIN_ON delay(20); LEDPIN_OFF delay(80); } if(!GPS_Present){ SerialEnd(GPS_SERIAL); SerialOpen(0,SERIAL0_COM_SPEED); } #if !defined(GPS_PROMINI) GPS_Present = 1; #endif GPS_Enable = GPS_Present; #endif */ /************************************/ /* #if defined(I2C_GPS) || defined(TINY_GPS) || defined(GPS_FROM_OSD) GPS_Enable = 1; #endif #if defined(LCD_ETPP) || defined(LCD_LCD03) || defined(OLED_I2C_128x64) || defined(LCD_TELEMETRY_STEP) initLCD(); #endif #ifdef LCD_TELEMETRY_DEBUG telemetry_auto = 1; #endif #ifdef LCD_CONF_DEBUG configurationLoop(); #endif #ifdef LANDING_LIGHTS_DDR init_landing_lights(); #endif ADCSRA |= _BV(ADPS2) ; ADCSRA &= ~_BV(ADPS1); ADCSRA &= ~_BV(ADPS0); // this speeds up analogRead without loosing(损耗) too much resolution(分辨率): http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1208715493/11 #if defined(LED_FLASHER) init_led_flasher(); led_flasher_set_sequence(LED_FLASHER_SEQUENCE); #endif f.SMALL_ANGLES_25=1; // important for gyro only conf #ifdef LOG_PERMANENT // read last stored set readPLog(); plog.lifetime += plog.armed_time / 1000000; plog.start++; // #powercycle/reset/initialize events // dump plog data to terminal #ifdef LOG_PERMANENT_SHOW_AT_STARTUP dumpPLog(0); #endif plog.armed_time = 0; // lifetime in seconds //plog.running = 0; // toggle on arm & disarm to monitor for clean shutdown vs. powercut #endif debugmsg_append_str("initialization completedn"); */ } /* void go_arm() { if(calibratingG == 0 && f.ACC_CALIBRATED #if defined(FAILSAFE) && failsafeCnt < 2 #endif ) { if(!f.ARMED) { // arm now! f.ARMED = 1; headFreeModeHold = heading; #if defined(VBAT) if (vbat > conf.no_vbat) vbatMin = vbat; #endif #ifdef LCD_TELEMETRY // reset some values when arming #if BARO BAROaltMax = BaroAlt; #endif #endif #ifdef LOG_PERMANENT plog.arm++; // #arm events plog.running = 1; // toggle on arm & disarm to monitor for clean shutdown vs. powercut // write now. writePLog(); #endif } } else if(!f.ARMED) { blinkLED(2,255,1); alarmArray[8] = 1; } } void go_disarm() { if (f.ARMED) { f.ARMED = 0; #ifdef LOG_PERMANENT plog.disarm++; // #disarm events plog.armed_time = armedTime ; // lifetime in seconds if (failsafeEvents) plog.failsafe++; // #acitve failsafe @ disarm if (i2c_errors_count > 10) plog.i2c++; // #i2c errs @ disarm plog.running = 0; // toggle @ arm & disarm to monitor for clean shutdown vs. powercut // write now. writePLog(); #endif } } void servos2Neutral() { #ifdef TRI servo[5] = 1500; // we center the yaw servo in conf mode writeServos(); #endif #ifdef FLYING_WING servo[0] = conf.wing_left_mid; servo[1] = conf.wing_right_mid; writeServos(); #endif #ifdef AIRPLANE for(uint8_t i = 4; i<7 ;i++) servo = 1500; writeServos(); #endif #ifdef HELICOPTER servo[5] = YAW_CENTER; servo[3] = servo[4] = servo[6] = 1500; writeServos(); #endif } */ // ******** Main Loop ********* void loop () { static uint8_t rcDelayCommand; // this indicates the number of time (multiple of RC measurement at 50Hz) the sticks must be maintained to run or switch off motors static uint8_t rcSticks; // this hold sticks position for command combos uint8_t axis,i; int16_t error,errorAngle; int16_t delta,deltaSum; int16_t PTerm,ITerm,DTerm; int16_t PTermACC = 0 , ITermACC = 0 , PTermGYRO = 0 , ITermGYRO = 0; static int16_t lastGyro[3] = {0,0,0}; static int16_t delta1[3],delta2[3]; static int16_t errorGyroI[3] = {0,0,0}; static int16_t errorAngleI[2] = {0,0}; static uint32_t rcTime = 0; static int16_t initialThrottleHold; static uint32_t timestamp_fixated = 0; /* #if defined(SPEKTRUM) if (spekFrameFlags == 0x01) readSpektrum(); #endif #if defined(OPENLRSv2MULTI) Read_OpenLRS_RC(); #endif */ if (currentTime > rcTime ) { // 50Hz rcTime = currentTime + 20000; computeRC(); /* // Failsafe routine - added by MIS #if defined(FAILSAFE) if ( failsafeCnt > (5*FAILSAFE_DELAY) && f.ARMED) { // Stabilize, and set Throttle to specified level for(i=0; i<3; i++) rcData = MIDRC; // after specified guard time after RC signal is lost (in 0.1sec) rcData[THROTTLE] = conf.failsafe_throttle; if (failsafeCnt > 5*(FAILSAFE_DELAY+FAILSAFE_OFF_DELAY)) { // Turn OFF motors after specified Time (in 0.1sec) go_disarm(); // This will prevent the copter to automatically rearm if failsafe shuts it down and prevents f.OK_TO_ARM = 0; // to restart accidentely by just reconnect to the tx - you will have to switch off first to rearm } failsafeEvents++; } if ( failsafeCnt > (5*FAILSAFE_DELAY) && !f.ARMED) { //Turn of "Ok To arm to prevent the motors from spinning after repowering the RX with low throttle and aux to arm go_disarm(); // This will prevent the copter to automatically rearm if failsafe shuts it down and prevents f.OK_TO_ARM = 0; // to restart accidentely by just reconnect to the tx - you will have to switch off first to rearm } failsafeCnt++; #endif // end of failsafe routine - next change is made with RcOptions setting */ /* // ------------------ STICKS COMMAND HANDLER -------------------- // checking sticks positions uint8_t stTmp = 0; for(i=0;i<4;i++) { stTmp >>= 2; if(rcData > MINCHECK) stTmp |= 0x80; // check for MIN if(rcData < MAXCHECK) stTmp |= 0x40; // check for MAX } if(stTmp == rcSticks) { if(rcDelayCommand<250) rcDelayCommand++; } else rcDelayCommand = 0; rcSticks = stTmp; // perform actions if (rcData[THROTTLE] <= MINCHECK) { // THROTTLE at minimum errorGyroI[ROLL] = 0; errorGyroI[PITCH] = 0; errorGyroI[YAW] = 0; errorAngleI[ROLL] = 0; errorAngleI[PITCH] = 0; if (conf.activate[BOXARM] > 0) { // Arming/Disarming via ARM BOX if ( rcOptions[BOXARM] && f.OK_TO_ARM ) go_arm(); else if (f.ARMED) go_disarm(); } } if(rcDelayCommand == 20) { if(f.ARMED) { // actions during armed #ifdef ALLOW_ARM_DISARM_VIA_TX_YAW if (conf.activate[BOXARM] == 0 && rcSticks == THR_LO + YAW_LO + PIT_CE + ROL_CE) go_disarm(); // Disarm via YAW #endif #ifdef ALLOW_ARM_DISARM_VIA_TX_ROLL if (conf.activate[BOXARM] == 0 && rcSticks == THR_LO + YAW_CE + PIT_CE + ROL_LO) go_disarm(); // Disarm via ROLL #endif } else { // actions during not armed i=0; if (rcSticks == THR_LO + YAW_LO + PIT_LO + ROL_CE) { // GYRO calibration calibratingG=512; #if GPS GPS_reset_home_position(); #endif #if BARO calibratingB=10; // calibrate baro to new ground level (10 * 25 ms = ~250 ms non blocking) #endif } #if defined(INFLIGHT_ACC_CALIBRATION) else if (rcSticks == THR_LO + YAW_LO + PIT_HI + ROL_HI) { // Inflight ACC calibration START/STOP if (AccInflightCalibrationMeasurementDone){ // trigger saving into eeprom after landing AccInflightCalibrationMeasurementDone = 0; AccInflightCalibrationSavetoEEProm = 1; }else{ AccInflightCalibrationArmed = !AccInflightCalibrationArmed; #if defined(BUZZER) if (AccInflightCalibrationArmed) alarmArray[0]=2; else alarmArray[0]=3; #endif } } #endif #ifdef MULTIPLE_CONFIGURATION_PROFILES if (rcSticks == THR_LO + YAW_LO + PIT_CE + ROL_LO) i=1; // ROLL left -> Profile 1 else if (rcSticks == THR_LO + YAW_LO + PIT_HI + ROL_CE) i=2; // PITCH up -> Profile 2 else if (rcSticks == THR_LO + YAW_LO + PIT_CE + ROL_HI) i=3; // ROLL right -> Profile 3 if(i) { global_conf.currentSet = i-1; writeGlobalSet(0); readEEPROM(); blinkLED(2,40,i); alarmArray[0] = i; } #endif if (rcSticks == THR_LO + YAW_HI + PIT_HI + ROL_CE) { // Enter LCD config #if defined(LCD_CONF) configurationLoop(); // beginning LCD configuration #endif previousTime = micros(); } #ifdef ALLOW_ARM_DISARM_VIA_TX_YAW else if (conf.activate[BOXARM] == 0 && rcSticks == THR_LO + YAW_HI + PIT_CE + ROL_CE) go_arm(); // Arm via YAW #endif #ifdef ALLOW_ARM_DISARM_VIA_TX_ROLL else if (conf.activate[BOXARM] == 0 && rcSticks == THR_LO + YAW_CE + PIT_CE + ROL_HI) go_arm(); // Arm via ROLL #endif #ifdef LCD_TELEMETRY_AUTO else if (rcSticks == THR_LO + YAW_CE + PIT_HI + ROL_LO) { // Auto telemetry ON/OFF if (telemetry_auto) { telemetry_auto = 0; telemetry = 0; } else telemetry_auto = 1; } #endif #ifdef LCD_TELEMETRY_STEP else if (rcSticks == THR_LO + YAW_CE + PIT_HI + ROL_HI) { // Telemetry next step telemetry = telemetryStepSequence[++telemetryStepIndex % strlen(telemetryStepSequence)]; #ifdef OLED_I2C_128x64 if (telemetry != 0) i2c_OLED_init(); #endif LCDclear(); } #endif else if (rcSticks == THR_HI + YAW_LO + PIT_LO + ROL_CE) calibratingA=512; // throttle=max, yaw=left, pitch=min else if (rcSticks == THR_HI + YAW_HI + PIT_LO + ROL_CE) f.CALIBRATE_MAG = 1; // throttle=max, yaw=right, pitch=min i=0; if (rcSticks == THR_HI + YAW_CE + PIT_HI + ROL_CE) {conf.angleTrim[PITCH]+=2; i=1;} else if (rcSticks == THR_HI + YAW_CE + PIT_LO + ROL_CE) {conf.angleTrim[PITCH]-=2; i=1;} else if (rcSticks == THR_HI + YAW_CE + PIT_CE + ROL_HI) {conf.angleTrim[ROLL] +=2; i=1;} else if (rcSticks == THR_HI + YAW_CE + PIT_CE + ROL_LO) {conf.angleTrim[ROLL] -=2; i=1;} if (i) { writeParams(1); rcDelayCommand = 0; // allow autorepetition #if defined(LED_RING) blinkLedRing(); #endif } } } #if defined(LED_FLASHER) led_flasher_autoselect_sequence(); #endif #if defined(INFLIGHT_ACC_CALIBRATION) if (AccInflightCalibrationArmed && f.ARMED && rcData[THROTTLE] > MINCHECK && !rcOptions[BOXARM] ){ // Copter is airborne and you are turning it off via boxarm : start measurement InflightcalibratingA = 50; AccInflightCalibrationArmed = 0; } if (rcOptions[BOXCALIB]) { // Use the Calib Option to activate : Calib = TRUE Meausrement started, Land and Calib = 0 measurement stored if (!AccInflightCalibrationActive && !AccInflightCalibrationMeasurementDone){ InflightcalibratingA = 50; } }else if(AccInflightCalibrationMeasurementDone && !f.ARMED){ AccInflightCalibrationMeasurementDone = 0; AccInflightCalibrationSavetoEEProm = 1; } #endif uint16_t auxState = 0; for(i=0;i<4;i++) auxState |= (rcData[AUX1+i]<1300)<<(3*i) | (1300 for(i=0;i // note: if FAILSAFE is disable, failsafeCnt > 5*FAILSAFE_DELAY is always false #if ACC if ( rcOptions[BOXANGLE] || (failsafeCnt > 5*FAILSAFE_DELAY) ) { // bumpless transfer to Level mode if (!f.ANGLE_MODE) { errorAngleI[ROLL] = 0; errorAngleI[PITCH] = 0; f.ANGLE_MODE = 1; } } else { // failsafe support f.ANGLE_MODE = 0; } if ( rcOptions[BOXHORIZON] ) { f.ANGLE_MODE = 0; if (!f.HORIZON_MODE) { errorAngleI[ROLL] = 0; errorAngleI[PITCH] = 0; f.HORIZON_MODE = 1; } } else { f.HORIZON_MODE = 0; } #endif if (rcOptions[BOXARM] == 0) f.OK_TO_ARM = 1; #if !defined(GPS_LED_INDICATOR) if (f.ANGLE_MODE || f.HORIZON_MODE) {STABLEPIN_ON;} else {STABLEPIN_OFF;} #endif #if BARO #if (!defined(SUPPRESS_BARO_ALTHOLD)) if (rcOptions[BOXBARO]) { if (!f.BARO_MODE) { f.BARO_MODE = 1; AltHold = EstAlt; initialThrottleHold = rcCommand[THROTTLE]; errorAltitudeI = 0; BaroPID=0; } } else { f.BARO_MODE = 0; } #endif #ifdef VARIOMETER if (rcOptions[BOXVARIO]) { if (!f.VARIO_MODE) { f.VARIO_MODE = 1; } } else { f.VARIO_MODE = 0; } #endif #endif #if MAG if (rcOptions[BOXMAG]) { if (!f.MAG_MODE) { f.MAG_MODE = 1; magHold = heading; } } else { f.MAG_MODE = 0; } if (rcOptions[BOXHEADFREE]) { if (!f.HEADFREE_MODE) { f.HEADFREE_MODE = 1; } } else { f.HEADFREE_MODE = 0; } if (rcOptions[BOXHEADADJ]) { headFreeModeHold = heading; // acquire new heading } #endif #if GPS static uint8_t GPSNavReset = 1; if (f.GPS_FIX && GPS_numSat >= 5 ) { if (rcOptions[BOXGPSHOME]) { // if both GPS_HOME & GPS_HOLD are checked => GPS_HOME is the priority if (!f.GPS_HOME_MODE) { f.GPS_HOME_MODE = 1; f.GPS_HOLD_MODE = 0; GPSNavReset = 0; #if defined(I2C_GPS) GPS_I2C_command(I2C_GPS_COMMAND_START_NAV,0); //waypoint zero #else // SERIAL GPS_set_next_wp(&GPS_home[LAT],&GPS_home[LON]); nav_mode = NAV_MODE_WP; #endif } } else { f.GPS_HOME_MODE = 0; if (rcOptions[BOXGPSHOLD] && abs(rcCommand[ROLL])< AP_MODE && abs(rcCommand[PITCH]) < AP_MODE) { if (!f.GPS_HOLD_MODE) { f.GPS_HOLD_MODE = 1; GPSNavReset = 0; #if defined(I2C_GPS) GPS_I2C_command(I2C_GPS_COMMAND_POSHOLD,0); #else GPS_hold[LAT] = GPS_coord[LAT]; GPS_hold[LON] = GPS_coord[LON]; GPS_set_next_wp(&GPS_hold[LAT],&GPS_hold[LON]); nav_mode = NAV_MODE_POSHOLD; #endif } } else { f.GPS_HOLD_MODE = 0; // both boxes are unselected here, nav is reset if not already done if (GPSNavReset == 0 ) { GPSNavReset = 1; GPS_reset_nav(); } } } } else { f.GPS_HOME_MODE = 0; f.GPS_HOLD_MODE = 0; #if !defined(I2C_GPS) nav_mode = NAV_MODE_NONE; #endif } #endif #if defined(FIXEDWING) || defined(HELICOPTER) if (rcOptions[BOXPASSTHRU]) {f.PASSTHRU_MODE = 1;} else {f.PASSTHRU_MODE = 0;} #endif } else { // not in rc loop static uint8_t taskOrder=0; // never call all functions in the same loop, to avoid high delay spikes if(taskOrder>4) taskOrder-=5; switch (taskOrder) { case 0: taskOrder++; #if MAG if (Mag_getADC()) break; // max 350 ?s (HMC5883) // only break when we actually did something #endif case 1: taskOrder++; #if BARO if (Baro_update() != 0 ) break; #endif case 2: taskOrder++; #if BARO if (getEstimatedAltitude() !=0) break; #endif case 3: taskOrder++; #if GPS if(GPS_Enable) GPS_NewData(); break; #endif case 4: taskOrder++; #if SONAR Sonar_update();debug[2] = sonarAlt; #endif #ifdef LANDING_LIGHTS_DDR auto_switch_landing_lights(); #endif #ifdef VARIOMETER if (f.VARIO_MODE) vario_signaling(); #endif break; } */ } //computeIMU(); // Measure loop rate just afer reading the sensors currentTime = micros(); cycleTime = currentTime - previousTime; previousTime = currentTime; #ifdef CYCLETIME_FIXATED if (conf.cycletime_fixated) { if ((micros()-timestamp_fixated)>conf.cycletime_fixated) { } else { while((micros()-timestamp_fixated) timestamp_fixated=micros(); } #endif //*********************************** //**** Experimental FlightModes ***** //*********************************** #if defined(ACROTRAINER_MODE) if(f.ANGLE_MODE){ if (abs(rcCommand[ROLL]) + abs(rcCommand[PITCH]) >= ACROTRAINER_MODE ) { f.ANGLE_MODE=0; f.HORIZON_MODE=0; f.MAG_MODE=0; f.BARO_MODE=0; f.GPS_HOME_MODE=0; f.GPS_HOLD_MODE=0; } } #endif //*********************************** /* #if MAG if (abs(rcCommand[YAW]) <70 && f.MAG_MODE) { int16_t dif = heading - magHold; if (dif <= - 180) dif += 360; if (dif >= + 180) dif -= 360; if ( f.SMALL_ANGLES_25 ) rcCommand[YAW] -= dif*conf.P8[PIDMAG]>>5; } else magHold = heading; #endif #if BARO && (!defined(SUPPRESS_BARO_ALTHOLD)) if (f.BARO_MODE) { static uint8_t isAltHoldChanged = 0; #if defined(ALTHOLD_FAST_THROTTLE_CHANGE) if (abs(rcCommand[THROTTLE]-initialThrottleHold) > ALT_HOLD_THROTTLE_NEUTRAL_ZONE) { errorAltitudeI = 0; isAltHoldChanged = 1; rcCommand[THROTTLE] += (rcCommand[THROTTLE] > initialThrottleHold) ? -ALT_HOLD_THROTTLE_NEUTRAL_ZONE : ALT_HOLD_THROTTLE_NEUTRAL_ZONE; } else { if (isAltHoldChanged) { AltHold = EstAlt; isAltHoldChanged = 0; } rcCommand[THROTTLE] = initialThrottleHold + BaroPID; } #else static int16_t AltHoldCorr = 0; if (abs(rcCommand[THROTTLE]-initialThrottleHold)>ALT_HOLD_THROTTLE_NEUTRAL_ZONE) { // Slowly increase/decrease AltHold proportional to stick movement ( +100 throttle gives ~ +50 cm in 1 second with cycle time about 3-4ms) AltHoldCorr+= rcCommand[THROTTLE] - initialThrottleHold; if(abs(AltHoldCorr) > 500) { AltHold += AltHoldCorr/500; AltHoldCorr %= 500; } errorAltitudeI = 0; isAltHoldChanged = 1; } else if (isAltHoldChanged) { AltHold = EstAlt; isAltHoldChanged = 0; } rcCommand[THROTTLE] = initialThrottleHold + BaroPID; #endif } #endif #if GPS if ( (f.GPS_HOME_MODE || f.GPS_HOLD_MODE) && f.GPS_FIX_HOME ) { float sin_yaw_y = sin(heading*0.0174532925f); float cos_yaw_x = cos(heading*0.0174532925f); #if defined(NAV_SLEW_RATE) nav_rated[LON] += constrain(wrap_18000(nav[LON]-nav_rated[LON]),-NAV_SLEW_RATE,NAV_SLEW_RATE); nav_rated[LAT] += constrain(wrap_18000(nav[LAT]-nav_rated[LAT]),-NAV_SLEW_RATE,NAV_SLEW_RATE); GPS_angle[ROLL] = (nav_rated[LON]*cos_yaw_x - nav_rated[LAT]*sin_yaw_y) /10; GPS_angle[PITCH] = (nav_rated[LON]*sin_yaw_y + nav_rated[LAT]*cos_yaw_x) /10; #else GPS_angle[ROLL] = (nav[LON]*cos_yaw_x - nav[LAT]*sin_yaw_y) /10; GPS_angle[PITCH] = (nav[LON]*sin_yaw_y + nav[LAT]*cos_yaw_x) /10; #endif } else { GPS_angle[ROLL] = 0; GPS_angle[PITCH] = 0; } #endif */ //**** PITCH & ROLL & YAW PID **** int16_t prop; prop = min(max(abs(rcCommand[PITCH]),abs(rcCommand[ROLL])),500); // range [0;500] for(axis=0;axis<3;axis++) { if ((f.ANGLE_MODE || f.HORIZON_MODE) && axis<2 ) { // MODE relying on ACC // 50 degrees max inclination errorAngle = constrain((rcCommand[axis]<<1) + GPS_angle[axis],-500,+500) - angle[axis] + conf.angleTrim[axis]; //16 bits is ok here PTermACC = ((int32_t)errorAngle*conf.P8[PIDLEVEL])>>7; // 32 bits is needed for calculation: errorAngle*P8[PIDLEVEL] could exceed 32768 16 bits is ok for result PTermACC = constrain(PTermACC,-conf.D8[PIDLEVEL]*5,+conf.D8[PIDLEVEL]*5); errorAngleI[axis] = constrain(errorAngleI[axis]+errorAngle,-10000,+10000); // WindUp //16 bits is ok here ITermACC = ((int32_t)errorAngleI[axis]*conf.I8[PIDLEVEL])>>12; // 32 bits is needed for calculation:10000*I8 could exceed 32768 16 bits is ok for result } if ( !f.ANGLE_MODE || f.HORIZON_MODE || axis == 2 ) { // MODE relying on GYRO or YAW axis if (abs(rcCommand[axis])<500) error = (rcCommand[axis]<<6)/conf.P8[axis] ; // 16 bits is needed for calculation: 500*64 = 32000 16 bits is ok for result if P8>5 (P>0.5) else error = ((int32_t)rcCommand[axis]<<6)/conf.P8[axis] ; // 32 bits is needed for calculation error -= gyroData[axis]; PTermGYRO = rcCommand[axis]; errorGyroI[axis] = constrain(errorGyroI[axis]+error,-16000,+16000); // WindUp 16 bits is ok here if (abs(gyroData[axis])>640) errorGyroI[axis] = 0; ITermGYRO = ((errorGyroI[axis]>>7)*conf.I8[axis])>>6; // 16 bits is ok here 16000/125 = 128 ; 128*250 = 32000 } if ( f.HORIZON_MODE && axis<2) { PTerm = ((int32_t)PTermACC*(512-prop) + (int32_t)PTermGYRO*prop)>>9; // the real factor should be 500, but 512 is ok ITerm = ((int32_t)ITermACC*(512-prop) + (int32_t)ITermGYRO*prop)>>9; } else { if ( f.ANGLE_MODE && axis<2) { PTerm = PTermACC; ITerm = ITermACC; } else { PTerm = PTermGYRO; ITerm = ITermGYRO; } } PTerm -= ((int32_t)gyroData[axis]*dynP8[axis])>>6; // 32 bits is needed for calculation delta = gyroData[axis] - lastGyro[axis]; // 16 bits is ok here, the dif between 2 consecutive gyro reads is limited to 800 lastGyro[axis] = gyroData[axis]; deltaSum = delta1[axis]+delta2[axis]+delta; delta2[axis] = delta1[axis]; delta1[axis] = delta; DTerm = ((int32_t)deltaSum*dynD8[axis])>>5; // 32 bits is needed for calculation axisPID[axis] = PTerm + ITerm - DTerm; } // mixTable(); // writeServos(); //writeMotors(); //print values // rcValue[0];rcData[RC_CHANS] Serial.print("Roll 1: "); Serial.print(rcData[ROLL]); Serial.print(" "); Serial.print("Pitch 2: "); Serial.print( rcData[PITCH]); Serial.print(" "); Serial.print("Throttle 3: "); Serial.print( rcData[THROTTLE]); Serial.print(" "); Serial.print("Yaw 4: "); Serial.println( rcData[YAW]); // */ ROLL, PITCH,YAW, THROTTLE, } |
只有小组成员才能发言,加入小组>>
请问一个迭代法图形二值化的程序代码把宽改成240之后整个屏幕不显示是什么原因?
2944 浏览 0 评论
2937 浏览 1 评论
2157 浏览 1 评论
2306 浏览 2 评论
2921 浏览 2 评论
/9
GMT+8, 2025-12-2 04:43 , Processed in 0.862463 second(s), Total 65, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
