单片机是PIC18F6722,之前版本的编译器编译没有问题,升级换成PIcc18的 V9.80后,在编译出现了大量【WARING】
Executing: "E:MicrochipHI-TECH SoftwarePICC-189.80binpicc18.exe" --pass1 E:MicrochipProjectsPIC-823function.c -q --chip=18F6722 -IE:MicrochipProjectsPIC-823Common -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s" Warning [1385] E:MicrochipProjectsPIC-823function.c; 119.13 variable "TRMT" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6991) Warning [1385] E:MicrochipProjectsPIC-823function.c; 120.7 variable "TRMT" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6991) Warning [1385] E:MicrochipProjectsPIC-823function.c; 141.13 variable "TRMT" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6991) Warning [1385] E:MicrochipProjectsPIC-823function.c; 142.7 variable "TRMT" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6991) Warning [1385] E:MicrochipProjectsPIC-823function.c; 186.6 variable "RB6" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6391) Warning [1385] E:MicrochipProjectsPIC-823function.c; 189.6 variable "RB6" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6391) Warning [1385] E:MicrochipProjectsPIC-823function.c; 225.5 variable "WR" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:7099) Warning [1385] E:MicrochipProjectsPIC-823function.c; 234.5 variable "WR" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:7099) Warning [1385] E:MicrochipProjectsPIC-823function.c; 248.5 variable "RD" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6457) Warning [1385] E:MicrochipProjectsPIC-823function.c; 256.6 variable "RG0" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6513) Warning [1385] E:MicrochipProjectsPIC-823function.c; 257.6 variable "RG0" is deprecated (declared at E:MicrochipHI-TECH SoftwarePICC-189.80includepic18f6722.h:6513) 实在是找不出来是什么原因,大神帮忙解答一下吧?? 编译成功了,但是烧写进去,功能不能实现了。 Memory Summary: Program space used F34h ( 3892) of 20000h bytes ( 3.0%) Data space used 35Dh ( 861) of F60h bytes ( 21.9%) Configuration bits used 7h ( 7) of 7h words (100.0%) EEPROM space used 0h ( 0) of 400h bytes ( 0.0%) ID Location space used 0h ( 0) of 8h nibbles ( 0.0%) Loaded E:MicrochipProjectsPIC-823PIC18f6722.cof. ********** Build successful! ********** |
完全看不懂!!!!!!!!!!!
只有小组成员才能发言,加入小组>>
求解外围电路实现的是4脚给持续低电平复位并正常工作,高电平不工作的原因
2042 浏览 1 评论
3218 浏览 3 评论
PIC1946程序有一个变量在运行过程中恢复初始值其他变量保持不变
2281 浏览 2 评论
2711 浏览 0 评论
PIC16F1825的RC5引脚,在主程序中操作无效,在中断中可以改变是为什么?
3940 浏览 5 评论
868浏览 0评论
用XC8编译PIC18F25K80时提示下面Error,求怎么解决这个问题
6276浏览 0评论
GMT+8, 2024-10-6 13:23 , Processed in 0.572022 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
