数码管60计数的程序:
module clock(clk_50m,rstc,sm_seg_out,sm_bit_out); input clk_50m; input rstc; output [7:0] sm_seg_out; output [7:0] sm_bit_out; reg [7:0] sm_seg_out; reg [7:0] sm_bit_out; reg [4:0] dis_dat; reg [2:0] dis_loca; reg [3:0] sec11; reg [2:0] sec12; parameter width = 15; reg flags,flag1ms; reg [width:0] cntms; reg [24:0] cnt; wire clk_s; parameter fre = 2499_9999; /////////////////DivFrequen////////////////// always @(posedge clk_50m or negedge rstc) begin if(!rstc) cnt<=1'b0; else if(cnt == fre) begin cnt <= 1'b0; flags <= ~flags; end else cnt <= cnt + 1'b1; end assign clk_s = flags; /*******************1ms*****************************/ always @(posedge clk_50m or negedge rstc) begin if(!rstc) cntms<=16'd0; else begin if(cntms == 16'd49999) cntms <= 16'd0; else cntms <= cntms + 1'b1; end end /*******************second*****************************/ always @(posedge clk_s or negedge rstc) begin if(!rstc) begin sec11 <= 1'b0; sec12 <= 1'b0; end else begin if((sec11 == 4'b1001)&&(sec12 ==3'b101)) begin sec11 <= 1'b0; sec12 <= 1'b0; end else begin if(sec11 == 4'b1001) begin sec11 <= 1'b0; sec12 <= sec12 + 1'b1; end else begin sec12 <= sec12; sec11 <= sec11 + 1'b1; end end end end //////////////display///////////////// always @(posedge clk_50m or negedge rstc) begin if(!rstc) dis_loca <= 3'd0; else begin if(cntms == 49999) dis_loca <= dis_loca + 1'b1; else dis_loca <= dis_loca; end end always @(dis_loca) case(dis_loca) 3'b000 : sm_bit_out = 8'b1111_1110; //第一位数码管 3'b001 : sm_bit_out = 8'b1111_1101; //第一位数码管 3'b010 : sm_bit_out = 8'b1111_1011; 3'b011 : sm_bit_out = 8'b1111_0111; 3'b100 : sm_bit_out = 8'b1110_1111; 3'b101 : sm_bit_out = 8'b1101_1111; 3'b110 : sm_bit_out = 8'b1011_1111; 3'b111 : sm_bit_out = 8'b0111_1111; //第8位 default : sm_bit_out = 8'b1111_1111; endcase always @(sm_bit_out or sec11 or sec12) case(sm_bit_out) 8'b1111_1110 : dis_dat = sec11; 8'b1111_1101 : dis_dat = sec12; 8'b1111_1011 : dis_dat = 4'b1010; 8'b1111_0111 : dis_dat = sec11; 8'b1110_1111 : dis_dat = sec12; 8'b1101_1111 : dis_dat = 4'b1010; 8'b1011_1111 : dis_dat = sec11; // 问题行 8'b0111_1111 : dis_dat = sec12; default : dis_dat = 4'b1011; endcase always @(dis_dat) case(dis_dat) 4'b0000 : sm_seg_out = 8'hc0; //0 4'b0001 : sm_seg_out = 8'hf9; //1 4'b0010 : sm_seg_out = 8'ha4; //2 4'b0011 : sm_seg_out = 8'hb0; //3 4'b0100 : sm_seg_out = 8'h99; //4 4'b0101 : sm_seg_out = 8'h92; //5 4'b0110 : sm_seg_out = 8'h82; //6 4'b0111 : sm_seg_out = 8'hf8; //7 4'b1000 : sm_seg_out = 8'h80; //8 4'b1001 : sm_seg_out = 8'h90; //9 4'b1010 : sm_seg_out = 8'hbf; //- 4'b1011 : sm_seg_out = 8'hff; //消除残影 default : sm_seg_out = 8'hff; //消除残影 endcase endmodule 为毛第7位总是不显示,图传了半天喘不上来,而下面中的数码动态显示管例程第7位却可以显示,代码如下: module scan_led (sys_clk , sys_rstn , sm_seg , sm_bit ); //??/???? input sys_clk ; input sys_rstn ; output [7:0] sm_seg ; output [7:0] sm_bit ; //????? reg [7:0] sm_seg ; reg [7:0] sm_bit ; reg [4:0] dataout_buf ; reg [2:0] disp_dat ; reg [15:0] delay_cnt ; //???? always@(posedge sys_clk or negedge sys_rstn) begin if(!sys_rstn) delay_cnt<=16'd0; else begin if(delay_cnt==16'd49999) delay_cnt<=16'd0; else delay_cnt<=delay_cnt+1'b1; end end always@(posedge sys_clk or negedge sys_rstn) begin if(!sys_rstn) disp_dat<=4'd0; else begin if(delay_cnt==16'd49999) disp_dat<=disp_dat+1'b1; else disp_dat<=disp_dat; end end always @(disp_dat) begin case(disp_dat) 3'b000 : sm_bit = 8'b1111_1110; 3'b001 : sm_bit = 8'b1111_1101; 3'b010 : sm_bit = 8'b1111_1011; 3'b011 : sm_bit = 8'b1111_0111; 3'b100 : sm_bit = 8'b1110_1111; 3'b101 : sm_bit = 8'b1101_1111; 3'b110 : sm_bit = 8'b1011_1111; 3'b111 : sm_bit = 8'b0111_1111; default : sm_bit = 8'b1111_1110; endcase end always@(sm_bit) begin case(sm_bit) 8'b1111_1110: dataout_buf=0; 8'b1111_1101: dataout_buf=1; 8'b1111_1011: dataout_buf=2; 8'b1111_0111: dataout_buf=3; 8'b1110_1111: dataout_buf=4; 8'b1101_1111: dataout_buf=5; 8'b1011_1111: dataout_buf=6; 8'b0111_1111: dataout_buf=7; default: dataout_buf=8; endcase end always@(dataout_buf) begin case(dataout_buf) 4'h0 : sm_seg = 8'hc0; // "0" 4'h1 : sm_seg = 8'hf9; // "1" 4'h2 : sm_seg = 8'ha4; // "2" 4'h3 : sm_seg = 8'hb0; // "3" 4'h4 : sm_seg = 8'h99; // "4" 4'h5 : sm_seg = 8'h92; // "5" 4'h6 : sm_seg = 8'h82; // "6" 4'h7 : sm_seg = 8'hf8; // "7" 4'h8 : sm_seg = 8'h80; // "8" 4'h9 : sm_seg = 8'h90; // "9" 4'ha : sm_seg = 8'h88; // "a" 4'hb : sm_seg = 8'h83; // "b" 4'hc : sm_seg = 8'hc6; // "c" 4'hd : sm_seg = 8'ha1; // "d" 4'he : sm_seg = 8'h86; // "e" 4'hf : sm_seg = 8'h8e; // "f" default : sm_seg = 8'hc0; // "0" endcase end endmodule 这是为嘛?感觉两个差不多啊,确定引脚配置没有问题,求指教 |
2个回答
你将always @(sm_bit_out or sec11 or sec12)这个的敏感参量改为always@(dis_loca),,然后相应修改下面的扫描看看?
不过我看你的程序好像都挺正常的,应该不会有问题才对?我也是初学者
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1287 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1036 浏览 0 评论
2359 浏览 1 评论
2067 浏览 0 评论
矩阵4x4个按键,如何把识别结果按编号01-16(十进制)显示在两个七段数码管上?
2325 浏览 0 评论
1864 浏览 49 评论
6006 浏览 113 评论
GMT+8, 2024-12-21 09:28 , Processed in 0.545635 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
