最近用W78E516B做一个实验板,要用串口写LDROM程序和APROM程序,我有上位机程序,由于不是C编的,我不太能看懂上位机程序,不知道怎么写下位机程序,求知道的大神们做一些解释,最好能帮我编个C语言下位机程序。小妹在这里谢谢大家了。
interface uses Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs, StdCtrls, OleCtrls, ExtCtrls, MSCommLib_TLB, ComCtrls; type TForm1 = class(TForm) OpenDialog1: TOpenDialog; Button1: TButton; Label3: TLabel; Label4: TLabel; Label1: TLabel; Edit1: TEdit; Label2: TLabel; Edit2: TEdit; ProgressBar1: TProgressBar; Button2: TButton; Memo1: TMemo; MSComm1: TMSComm; procedure Button1Click(Sender: TObject); procedure MSComm1Comm(Sender: TObject); procedure FormClose(Sender: TObject; var Action: TCloseAction); procedure FormCreate(Sender: TObject); procedure writecomm(buf :array of byte); procedure trans_hex(); procedure error(); function crc16(***uf: array of byte ;len : integer) : word; procedure Button2Click(Sender: TObject); private { Private declarations } public { Public declarations } end; var Form1: TForm1; send_times,receive_times:integer; status : integer; FromF: file; textf: textfile; NumRead, NumWritten,i,crcdata: Integer; Buf: array[1..63] of byte; Bufout: variant; write_buf : array[0..65535] of byte; buf_size : integer; const crc_ta : array[0..255] of integer =( $0000, $1021, $2042, $3063, $4084, $50a5, $60c6, $70e7, $8108, $9129, $a14a, $b16b, $c18c, $d1ad, $e1ce, $f1ef, $1231, $0210, $3273, $2252, $52b5, $4294, $72f7, $62d6, $9339, $8318, $b37b, $a35a, $d3bd, $c39c, $f3ff, $e3de, $2462, $3443, $0420, $1401, $64e6, $74c7, $44a4, $5485, $a56a, $b54b, $8528, $9509, $e5ee, $f5cf, $c5ac, $d58d, $3653, $2672, $1611, $0630, $76d7, $66f6, $5695, $46b4, $b75b, $a77a, $9719, $8738, $f7df, $e7fe, $d79d, $c7bc, $48c4, $58e5, $6886, $78a7, $0840, $1861, $2802, $3823, $c9cc, $d9ed, $e98e, $f9af, $8948, $9969, $a90a, $b92b, $5af5, $4ad4, $7ab7, $6a96, $1a71, $0a50, $3a33, $2a12, $dbfd, $cbdc, $fbbf, $eb9e, $9b79, $8b58, $bb3b, $ab1a, $6ca6, $7c87, $4ce4, $5cc5, $2c22, $3c03, $0c60, $1c41, $edae, $fd8f, $cdec, $ddcd, $ad2a, $bd0b, $8d68, $9d49, $7e97, $6eb6, $5ed5, $4ef4, $3e13, $2e32, $1e51, $0e70, $ff9f, $efbe, $dfdd, $cffc, $bf1b, $af3a, $9f59, $8f78, $9188, $81a9, $b1ca, $a1eb, $d10c, $c12d, $f14e, $e16f, $1080, $00a1, $30c2, $20e3, $5004, $4025, $7046, $6067, $83b9, $9398, $a3fb, $b3da, $c33d, $d31c, $e37f, $f35e, $02b1, $1290, $22f3, $32d2, $4235, $5214, $6277, $7256, $b5ea, $a5cb, $95a8, $8589, $f56e, $e54f, $d52c, $c50d, $34e2, $24c3, $14a0, $0481, $7466, $6447, $5424, $4405, $a7db, $b7fa, $8799, $97b8, $e75f, $f77e, $c71d, $d73c, $26d3, $36f2, $0691, $16b0, $6657, $7676, $4615, $5634, $d94c, $c96d, $f90e, $e92f, $99c8, $89e9, $b98a, $a9ab, $5844, $4865, $7806, $6827, $18c0, $08e1, $3882, $28a3, $cb7d, $db5c, $eb3f, $fb1e, $8bf9, $9bd8, $abbb, $bb9a, $4a75, $5a54, $6a37, $7a16, $0af1, $1ad0, $2ab3, $3a92, $fd2e, $ed0f, $dd6c, $cd4d, $bdaa, $ad8b, $9de8, $8dc9, $7c26, $6c07, $5c64, $4c45, $3ca2, $2c83, $1ce0, $0cc1, $ef1f, $ff3e, $cf5d, $df7c, $af9b, $bfba, $8fd9, $9ff8, $6e17, $7e36, $4e55, $5e74, $2e93, $3eb2, $0ed1, $1ef0 ) ; const testbuf : array[1..8] of byte =(0,0,0,0,6,$d,$d2,$e3); const char_biao : array[0..15] of string = ('0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'); implementation {$R *.DFM} procedure TForm1.Button1Click(Sender: TObject); begin if OpenDialog1.Execute then { Display Open dialog box } begin receive_times := 0; send_times := 0; status :=0; // button1.Enabled := false; memo1.Lines.Add('文件读取中。。。。'); trans_hex(); end; end; procedure TForm1.error(); var i : integer; begin mscomm1.PortOpen := false; i := 0; end; procedure TForm1.trans_hex(); var i,j,k : integer; s,ds : string; aa : array[0..300] of byte; tmpa,tmpb : integer; maxadr : integer; begin if opendialog1.FilterIndex = 1 then begin buf_size := 0; maxadr := 0; for i:=0 to 65535 do write_buf := $ff; assignfile(textf,opendialog1.filename); reset(textf); try while not eof(textf) do begin readln(textf,s); i := -1; repeat i := i + 1; until (i = (sizeof(s)-1)) or (s = ':'); j := 0; ds := ''; while (i <= (length(s)-1)) do begin i := i + 1; for k:=0 to 15 do if char_biao[k] = s then tmpa := k ; i := i + 1; for k:=0 to 15 do if char_biao[k] = s then tmpb := k ; aa[j] := (tmpa shl 4 ) + tmpb; ds := ds + inttohex(aa[j],2); j := j+ 1; end; tmpa := (aa[1] shl 8) + aa[2]; if (tmpa > maxadr ) then begin maxadr := tmpa; buf_size := maxadr + aa[0]; end; for i:=0 to aa[0]-1 do begin write_buf[tmpa + i] := aa[i+4]; end; // memo1.Lines.Add(ds); end finally closefile(textf); end; // for i:=0 to buf_size-1 do // memo1.Lines.Add(inttohex(write_buf,2) + ' '); end else begin AssignFile(FromF, OpenDialog1.FileName); Reset(FromF, 1); form1.Caption := opendialog1.FileName ; BlockRead(FromF, write_buf, SizeOf(write_buf), buf_size); end; edit1.text := inttostr(buf_size); progres***ar1.Max := buf_size; memo1.Lines.Add('连接中。。。。'); end ; function TForm1.crc16(***uf: array of byte;len : integer) : word; var i,j,tmp:word; begin tmp := 0; for i:= 0 to len-1 do begin j := $80; repeat if ((tmp and $8000)<> $0) then begin tmp := tmp shl 1; tmp := tmp xor $1021; end else tmp := tmp shl 1; if (***uf and j)<> 0 then tmp := tmp xor $1021; j := j shr 1; until (j = 0) end; crc16 := tmp; end; procedure TForm1.MSComm1Comm(Sender: TObject); var receive : variant; buf1 : array[0..0] of byte; i : integer; k ,j: integer; begin if mscomm1.CommEvent = comevreceive then begin j := mscomm1.InBufferCount; receive := mscomm1.Input; for k:= 0 to j-1 do begin case receive[k] of $11: //同步数据 begin buf1[0] := $11; writecomm(buf1); send_times := 0; if (status <> 1) then begin memo1.Lines.Add('芯片擦除中。。。。。。'); status := 1; end end; $22: begin buf1[0] := $22; writecomm(buf1); if (status <> 2) then begin memo1.Lines.Add('擦除完成!'); memo1.Lines.Add('检查芯片是否为空。。。。。'); status := 2; end end; $AA: begin buf1[0] := $aa; writecomm(buf1); if (status <> 3) then begin memo1.Lines.Add('空片检测成功!'); status := 3; end end; $44: begin if (status <> 4) then begin memo1.Lines.Add('芯片检测失败!'); status := 4; end end; $55: //数据写入正确,接着发送 begin if (status <> 5) then begin memo1.Lines.Add('开始写入程序。。。。。'); status := 5; end; if (send_times < buf_size ) then begin if (send_times +60 < buf_size) then NumRead := 60 else NumRead := buf_size - send_times; end else NumRead := 0; if (NumRead <>0) then begin bufout:= VarArrayCreate([0,NumRead],varByte); bufout[0] := NumRead; for i:=1 to NumRead do begin bufout := write_buf[send_times]; send_times := send_times + 1 ; end; mscomm1.Output := bufout; edit2.Text := inttostr(send_times); progres***ar1.Position := send_times; end else begin buf1[0] := $0; writecomm(buf1); end end; $66: begin if (status <> 6) then begin memo1.Lines.Add('芯片写入失败!'); status := 6; end end; $77: begin if (status <> 7) then begin memo1.Lines.Add('芯片写入完成!'); status := 7; end end; end; end; end; end; procedure TForm1.writecomm(buf :array of byte); var V:Variant; i:Integer; begin V:= VarArrayCreate([Low(Buf), High(Buf)],varByte); for i:=Low(Buf) to High(Buf) do V:=Buf; mscomm1.output := V; end; procedure TForm1.FormClose(Sender: TObject; var Action: TCloseAction); begin // timer1.Enabled := false; if mscomm1.PortOpen = true then mscomm1.PortOpen := false; end; procedure TForm1.FormCreate(Sender: TObject); begin status := 0; mscomm1.PortOpen := true; end; procedure TForm1.Button2Click(Sender: TObject); begin application.Terminate ; end; end. |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16900 浏览 31 评论
/9
GMT+8, 2025-12-1 23:55 , Processed in 0.474432 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1066
