#include
#define LCD_DB P0 unsigned char s1[5]; unsigned char s2[5]; ***it LCD_RS=P2^4; ***it LCD_RW=P2^5; ***it LCD_E=P2^6; ***it P2_0=P2^0; ***it moshi=P2^1; ***it INC=P2^2; ***it DEC=P2^3; ***it SPK=P2^7; /******定义函数***********/ #define uchar unsigned char #define uint unsigned int #define U8 unsigned int #define U16 unsigned int uchar count1=70; uchar count2=35; uchar moshicount=0; uchar TD=0;//定时次数 U8 U8FLAG; U8 U8count, U8temp; U8 U8T_data_H, U8T_data_L, UT_data_1, U8RH_data_H, U8RH_data_L, U8checkdata; U8 U8T_data_H_temp, U8T_data_L_temp, U8RH_data_H_temp, U8RH_data_L_temp, U8checkdata_temp; U8 U8comdata; void LCD_init(void);//初始化函数 void LCD_write_command(uchar command);//指令函数 void LCD_write_data(uchar dat); //写数据函数 void LCD_disp_char(uchar x,uchar y,uchar dat); //在某个屏幕位置显示一个字符,X (0-16),y(1-2) void delay_n40us(uint n);//延时函数 //************************ //*******液晶初始化函数************** void LCD_init(void) { LCD_write_command(0x38); //设置8位格式,2行,5x7 LCD_write_command(0x0c); //整体显示,关光标,不闪烁 LCD_write_command(0x06); //设置输入方式,增量不移位 LCD_write_command(0x03); //清除屏幕显示 delay_n40us(100); } //******************************* //******定时器初始化函数********* void timerinit() { TMOD=0x01; TH0=(65536-50000)/256; TL0=(65536-50000)%256; EA=1; ET0=1; } //******写指令函数********* void LCD_write_command(uchar dat) { LCD_DB=dat; LCD_RS=0;//指令 LCD_RW=0;//写入 LCD_E=1;//允许 delay_n40us(1); LCD_E=0; delay_n40us(1); } //************************* //****写数据函数*********** void LCD_write_data(uchar dat) { LCD_DB=dat; LCD_RS=1;//数据 LCD_RW=0;//写入 LCD_E=1;//允许 delay_n40us(1); LCD_E=0; delay_n40us(1); } //************************* //*****显示一个字符函数**** void LCD_disp_char(uchar x,uchar y,uchar dat) { uchar address; if(y == 1) { address = 0x80+x; } else { address = 0xc0+x; } LCD_write_command(address); LCD_write_data(dat); } //******************** //***延时函数********* void delay_n40us(uint n) { uint i; uchar j; for(i=n;i>0;i--) { for(j=0;j<2;j++); } } void Delay_10us(void) { U8 i; i--; i--; i--; i--; i--; i--; } void Delay(U16 j) { U8 i; for(;j>0;j--) for(i=0;i<27;i++); } //*****一字节数据传送函数********** void COM(void) { U8 i; for(i=0;i<8;i++) { U8FLAG=2; while((!P2_0)&&U8FLAG++); Delay_10us(); Delay_10us(); Delay_10us(); U8temp=0; if(P2_0)U8temp=1; U8FLAG=2; while((P2_0)&&U8FLAG++); //超时则跳出for循环 if(U8FLAG==1)break; //判断数据位是 0 还是 1 //如果高电平高过预定 0 高电平值则数据位位 1 U8comdata<<=1; U8comdata|=U8temp; } } /*******单片机与传感器通信函数***********/ void RH(void) { //主机拉低 18ms P2_0=0; Delay(200); P2_0=1; //总线由上拉电阻拉高 主机延时20us Delay_10us(); Delay_10us(); Delay_10us(); Delay_10us(); //主机设为输入 判断从机响应信号 P2_0=1; //判断从机是否有低电平响应信号 如不响应则跳出响应则向下运行 if(!P2_0) //T ! { U8FLAG=2; //判断从机是否发出 80us 的低电平响应信号是否结束 while((!P2_0)&&U8FLAG++); U8FLAG=2; //判断从机是否发出 80us的高电平,如发出则进入数据接收状态 while((P2_0)&&U8FLAG++); //数据接收状态 COM(); U8RH_data_H_temp=U8comdata; COM(); U8RH_data_L_temp=U8comdata; COM(); U8T_data_H_temp=U8comdata; COM(); U8T_data_L_temp=U8comdata; COM(); U8checkdata_temp=U8comdata; P2_0=1; //数据校验 U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp +U8RH_data_L_temp); if(U8temp==U8checkdata_temp) { U8RH_data_H=U8RH_data_H_temp; U8RH_data_L=U8RH_data_L_temp; U8T_data_H=U8T_data_H_temp; U8T_data_L=U8T_data_L_temp; U8checkdata=U8checkdata_temp; } //湿度整数部分 s1[0]=(char)(0X30+U8RH_data_H/10); s1[1]=(char)(0X30+U8RH_data_H%10); //湿度小数部分 s1[2]=(char)(0X30+U8RH_data_L/10); //温度整数部分 s2[0]=(char)(0X30+U8T_data_H/10); s2[1]=(char)(0X30+U8T_data_H%10); //温度小数部分 s2[2]=(char)(0X30+U8T_data_L/10); } } //************************ //液晶显示函数 void disp() { LCD_disp_char(0,1,'s'); LCD_disp_char(1,1,'h'); LCD_disp_char(2,1,'i'); LCD_disp_char(3,1,'d'); LCD_disp_char(4,1,'u'); LCD_disp_char(5,1,':'); LCD_disp_char(6,1,s1[0]+'0'); LCD_disp_char(7,1,s1[1]+'0'); LCD_disp_char(8,1,'.'); LCD_disp_char(9,1,s1[2]+'0'); LCD_disp_char(10,1,'%'); LCD_disp_char(11,1,'R'); LCD_disp_char(12,1,'H'); LCD_disp_char(0,2,'w'); LCD_disp_char(1,2,'e'); LCD_disp_char(2,2,'n'); LCD_disp_char(3,2,'d'); LCD_disp_char(4,2,'u'); LCD_disp_char(5,2,':'); LCD_disp_char(6,2,s2[0]+'0'); LCD_disp_char(7,2,s2[1]+'0'); LCD_disp_char(8,2,'.'); LCD_disp_char(9,2,s2[2]+'0'); LCD_disp_char(10,2,0xDF); LCD_disp_char(11,2,'C'); } //阀值设置函数 void shezhi() { //初值 s1[3]=(char)(0X30+count1/10); s1[4]=(char)(0X30+count1%10); //初值 s2[3]=(char)(0X30+count2/10); s2[4]=(char)(0X30+count2%10); moshi=1; if(moshi==0) { Delay_10us(); while(moshi==0); moshicount++; } switch(moshicount) { case 1: { INC=1;DEC=1; if(INC==0) { Delay_10us(); while(INC==0); count1++; } else if(DEC==0) { Delay_10us(); while(INC==0); count1--; } LCD_disp_char(14,1,s1[3]); LCD_disp_char(15,1,s1[4]); LCD_disp_char(14,2,s2[3]); LCD_disp_char(15,2,s2[4]); }break; case 2: { //moshicount=0; INC=1;DEC=1; if(INC==0) { Delay_10us(); while(INC==0); count2++; } else if(DEC==0) { Delay_10us(); while(DEC==0); count2--; } LCD_disp_char(14,1,s1[3]); LCD_disp_char(15,1,s1[4]); LCD_disp_char(14,2,s2[3]); LCD_disp_char(15,2,s2[4]); }break; case 3: { moshicount=0; LCD_disp_char(14,1,' '); LCD_disp_char(15,1,' '); LCD_disp_char(14,2,' '); LCD_disp_char(15,2,' '); }break; default: break; } } //蜂鸣器报警程序 void laba() { if((U8RH_data_H>=count1)||(U8T_data_H>=count2)) SPK=1; else SPK=0; } //定时器0 中断程序,每次定时 50ms timer0() interrupt 1 { TD++; if(TD>=100) { TH0=-50000/256; TL0=-50000%256; TR0=0; TD=0; } TH0=-50000/256; TL0=-50000%256; } //*********主函数************ void main(void) { LCD_init(); timerinit(); Delay(4); while(1) { RH(); disp(); laba(); TR0=1; while((TD>=1)&&(TD<=100)) { shezhi(); } } } |
3个回答
你解决了没有啊?我的是显示00啊
我用的18b20 成功了
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
《DNK210使用指南 -CanMV版 V1.0》第八章 CanMV IDE初体验
747 浏览 0 评论
过采样提高12位ADC精度在STM32主控上的实现(附电路及代码)
658 浏览 0 评论
飞凌嵌入式-ELFBOARD 解决PCB布线时无法捕捉到焊盘中心的问题
926 浏览 0 评论
Openharmony软件评估指南-米尔瑞芯微RK3568开发板
1448 浏览 0 评论
STM32CUBEMX(7)--移植雅特力AT32F403AVGT(兼容STM32F103VGT6),DAC输出电压
1243 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11114 浏览 31 评论
GMT+8, 2024-9-17 06:27 , Processed in 0.629381 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
