` 本帖最后由 836689111 于 2013-6-3 20:34 编辑 请问收发代码有没有错误,接收到的是一个问号。请教如何修改 /* -------------无线发射----------*/ #include #include ***it led1=P2^0; ***it led2=P2^1; ***it led3=P2^2; ***it led4=P2^3; void delay(void) //误差 0us { unsigned char a,b; for(b=71;b>0;b--) for(a=2;a>0;a--); } unsigned char code ***[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40}; unsigned long LedOut[5],LedNumVal; unsigned char ha=0; unsigned char hb=1; unsigned char hc=2; unsigned char hd=3; unsigned char a=0; /*void shumaguan() { P0=0x00; P2=0xff; P0=***[a%10000/1000]; led4=0; delay(1); led4=1; P0=***[a%1000/100]; led3=0; delay(1); led3=1; P0=***[a%100/10]; led2=0; delay(1); led2=1; P0=***[a%10]; led1=0; delay(1); led1=1; }*/ ***it DQ=P3^7;//ds18b20与单片机连接口 unsigned int tvalue;//温度值 unsigned char tflag; /***DS18B20延时***/ void delay_18B20(unsigned int i) { while(i--); } void ds1820rst() //初始化 { unsigned char x=0; DQ=1; delay_18B20(4); DQ=0; delay_18B20(100); DQ=1; delay_18B20(40); } unsigned char ds1820rd()//读数据 { unsigned char i=0; unsigned char dat=0; for(i=8;i>0;i--) { DQ=0; dat>>=1; DQ=1; if(DQ) dat|=0x80; delay_18B20(10); } return(dat); } void ds1820wr(unsigned char wdata)//写数据 { unsigned char i=0; for(i=8;i>0;i--) { DQ=0; DQ=wdata&0x01; delay_18B20(10); DQ=1; wdata>>=1; } } void red_temp(void) { unsigned char a,b; ds1820rst(); ds1820wr(0xcc); ds1820wr(0x44); ds1820rst(); ds1820wr(0xcc); ds1820wr(0xbe); a=ds1820rd(); b=ds1820rd(); tvalue=b; tvalue<<=8; tvalue=tvalue|a; if(tvalue<0x0fff) tflag=0; else { tvalue=~tvalue+1; tflag=1; } tvalue=tvalue*(0.625); //return(tvalue); } typedef unsigned char uchar; typedef unsigned char uint; //****************************************IO端口定义*************************************** ***it MISO =P1^1; ***it MOSI =P1^2; ***it SCK =P1^3; ***it CE =P1^5; ***it CSN =P1^4; ***it IRQ =P1^0; //***********************************数码管0-9编码******************************************* uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码 uchar TxBuf[32]= { 0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08, 0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16, 0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24, 0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32, }; // //*********************************************NRF24L01************************************* #define TX_ADR_WIDTH 5 // 5 uints TX address width #define RX_ADR_WIDTH 5 // 5 uints RX address width #define TX_PLOAD_WIDTH 32 // 20 uints TX payload #define RX_PLOAD_WIDTH 32 // 20 uints TX payload uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址 uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址 //***************************************NRF24L01寄存器指令******************************************************* #define READ_REG 0x00 // 读寄存器指令 #define WRITE_REG 0x20 // 写寄存器指令 #define RD_RX_PLOAD 0x61 // 读取接收数据指令 #define WR_TX_PLOAD 0xA0 // 写待发数据指令 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令 #define NOP 0xFF // 保留 //*************************************SPI(nRF24L01)寄存器地址**************************************************** #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 #define EN_AA 0x01 // 自动应答功能设置 #define EN_RXADDR 0x02 // 可用信道设置 #define SETUP_AW 0x03 // 收发地址宽度设置 #define SETUP_RETR 0x04 // 自动重发功能设置 #define RF_CH 0x05 // 工作频率设置 #define RF_SETUP 0x06 // 发射速率、功耗功能设置 #define STATUS 0x07 // 状态寄存器 #define OBSERVE_TX 0x08 // 发送监测功能 #define CD 0x09 // 地址检测 #define RX_ADDR_P0 0x0A // 频道0接收数据地址 #define RX_ADDR_P1 0x0B // 频道1接收数据地址 #define RX_ADDR_P2 0x0C // 频道2接收数据地址 #define RX_ADDR_P3 0x0D // 频道3接收数据地址 #define RX_ADDR_P4 0x0E // 频道4接收数据地址 #define RX_ADDR_P5 0x0F // 频道5接收数据地址 #define TX_ADDR 0x10 // 发送地址寄存器 #define RX_PW_P0 0x11 // 接收频道0接收数据长度 #define RX_PW_P1 0x12 // 接收频道0接收数据长度 #define RX_PW_P2 0x13 // 接收频道0接收数据长度 #define RX_PW_P3 0x14 // 接收频道0接收数据长度 #define RX_PW_P4 0x15 // 接收频道0接收数据长度 #define RX_PW_P5 0x16 // 接收频道0接收数据长度 #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置 //************************************************************************************** void Delay(unsigned int s); void inerDelay_us(unsigned char n); void init_NRF24L01(void); uint SPI_RW(uint uchar); uchar SPI_Read(uchar reg); void SetRX_Mode(void); uint SPI_RW_Reg(uchar reg, uchar value); uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars); uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); //*****************************************长延时***************************************** void Delay(unsigned int s) { unsigned int i; for(i=0; i //****************************************************************************************** uint bdata sta; //状态标志 ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /****************************************************************************************** /*延时函数 /******************************************************************************************/ void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } //**************************************************************************************** /*NRF24L01初始化 //***************************************************************************************/ void init_NRF24L01(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // Spi clock line init high SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 } /**************************************************************************************************** /*函数:uint SPI_RW(uint uchar) /*功能:NRF24L01的SPI写时序 /****************************************************************************************************/ uint SPI_RW(uint uchar) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI uchar = (uchar << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. uchar |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(uchar); // return read uchar } /**************************************************************************************************** /*函数:uchar SPI_Read(uchar reg) /*功能:NRF24L01的SPI时序 /****************************************************************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /****************************************************************************************************/ /*功能:NRF24L01读写寄存器函数 /****************************************************************************************************/ uint SPI_RW_Reg(uchar reg, uchar value) { uint status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status uchar } /****************************************************************************************************/ /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数 /****************************************************************************************************/ uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status uchar for(uchar_ctr=0;uchar_ctr CSN = 1; return(status); // return nRF24L01 status uchar } /********************************************************************************************************* /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数 /*********************************************************************************************************/ uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; //SPI使能 status = SPI_RW(reg); for(uchar_ctr=0; uchar_ctr CSN = 1; //关闭SPI return(status); // } /****************************************************************************************************/ /*函数:void SetRX_Mode(void) /*功能:数据接收配置 /****************************************************************************************************/ void SetRX_Mode(void) { CE=0; SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /******************************************************************************************************/ /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) /*功能:数据读取后放如rx_buf接收缓冲区中 /******************************************************************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 if(RX_DR) // 判断是否接收到数据 { CE = 0; //SPI使能 SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志 return revale; } /*********************************************************************************************************** /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf) /*功能:发送 tx_buf中数据 /**********************************************************************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 // SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 CE=1; //置高CE,激发数据发送 inerDelay_us(10); } unsigned char code Disp_Tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40}; unsigned long LedOut[5],LedNumVal; unsigned char ab,ac,ad,ae; float aa; void shumaguan(int k) { P0=0x00; P2=0xff; if(tflag==0) { P0=Disp_Tab[k/1000]; led4=0; delay(); led4=1; } else { P0=0x40; led4=0; delay(); led4=1; } P0=Disp_Tab[k%1000/100]; led3=0; delay(); led3=1; P0=Disp_Tab[k%100/10]|0x80; led2=0; delay(); led2=1; P0=Disp_Tab[k%10]; led1=0; delay(); led1=1; } unsigned int Temperature; void main() { unsigned char i; //system_Ini(); // 系统初始化 // ini_lcd1602(); // 1602初始化 ds1820rst(); init_NRF24L01() ; while(1) { //TemperatuerResult(); // GetTemp(); red_temp(); Temperature=tvalue; /********以下将读18b20的数据送到LED数码管显示*************/ LedOut[0]=Temperature%10000/1000+0x30; LedOut[1]=Temperature%1000/100+0x30; LedOut[2]=Temperature%100/10+0x30; //十位 LedOut[3]=Temperature%10+0x30; //个位 aa=Temperature; ab=Temperature%10000/1000+0x30; ac=Temperature%1000/100+0x30; ad=Temperature%100/10+0x30; ae=Temperature%10+0x30; // TxBuf[0]=LedOut[0]; // tflag=1; if(tflag==0) { TxBuf[0]=LedOut[0]; } else { TxBuf[0]=1; } TxBuf[1]=LedOut[1]; TxBuf[2]=LedOut[2]; TxBuf[3]=LedOut[3]; // write_lcd1602(0x80,0); // for(i=0;i<=3;i++) // write_lcd1602(LedOut,1); nRF24L01_TxPacket(TxBuf); shumaguan(aa); SPI_RW_Reg(WRITE_REG+STATUS,0XFF); /* xianshi(0,1,TxBuf[0]); xianshi(1,1,TxBuf[1]); xianshi(2,1,TxBuf[2]); xianshi(3,1,TxBuf[3]); ShowString(0,0,a); xianshi(4,1,0xdf); xianshi(5,1,'C'); */ } } /*----------无线接收---------*/ #include ***it RS = P2^6; ***it RW = P2^5; ***it EN = P2^7; //控制引脚定义 //延时函数 void Delayms(unsigned int ms) { unsigned char i; while(ms--) { for(i=0;i<120;i++); } } //忙标志检查 unsigned char Busy_Check() { unsigned char LCD_Status; RS = 0; RW = 1; EN = 1; Delayms(1); LCD_Status = P0; EN = 0; return LCD_Status; } //写1602的控制命令 void Write_LCD_Command(unsigned char cmd) { while((Busy_Check()&0x80)==0x80); RS = 0; RW = 0; EN = 0; P0 = cmd; EN = 1; Delayms(1); EN = 0; } //写1602的数据 void Write_LCD_Data(unsigned char dat) { while((Busy_Check()&0x80)==0x80); RS = 1; RW = 0; EN = 0; P0 = dat; EN = 1; Delayms(1); EN = 0; } //初始化1602液晶 void Initialize_LCD() { Write_LCD_Command(0x38); Delayms(1); Write_LCD_Command(0x01); Delayms(1); Write_LCD_Command(0x06); Delayms(1); Write_LCD_Command(0x0c); Delayms(1); } //显示字符串 void ShowString(unsigned char x,unsigned char y,unsigned char *str) { unsigned char i = 0; if(y == 0) Write_LCD_Command(0x80 | x); if(y == 1) Write_LCD_Command(0xc0 | x); for(i=0;i<16;i++) { Write_LCD_Data(str); } } void xianshi(unsigned char x,unsigned char y,unsigned char z) { if(y == 0) Write_LCD_Command(0x80 | x); if(y == 1) Write_LCD_Command(0xc0 | x); Write_LCD_Data(z); } #include typedef unsigned char uchar; typedef unsigned char uint; //****************************************IO端口定义*************************************** ***it MISO =P1^1; ***it MOSI =P1^2; ***it SCK =P1^3; ***it CE =P1^5; ***it CSN =P1^4; ***it IRQ =P1^0; //***********************************数码管0-9编码******************************************* uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码 //************************************按键********************************************** ***it KEY1=P3^6; ***it KEY2=P3^7; //***********************************数码管位选************************************************** ***it led1=P2^1; ***it led0=P2^0; ***it led2=P2^2; ***it led3=P2^3;//*********************************************NRF24L01************************************* #define TX_ADR_WIDTH 5 // 5 uints TX address width #define RX_ADR_WIDTH 5 // 5 uints RX address width #define TX_PLOAD_WIDTH 32 // 20 uints TX payload #define RX_PLOAD_WIDTH 32 // 20 uints TX payload uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址 uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址 //***************************************NRF24L01寄存器指令******************************************************* #define READ_REG 0x00 // 读寄存器指令 #define WRITE_REG 0x20 // 写寄存器指令 #define RD_RX_PLOAD 0x61 // 读取接收数据指令 #define WR_TX_PLOAD 0xA0 // 写待发数据指令 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令 #define NOP 0xFF // 保留 //*************************************SPI(nRF24L01)寄存器地址**************************************************** #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 #define EN_AA 0x01 // 自动应答功能设置 #define EN_RXADDR 0x02 // 可用信道设置 #define SETUP_AW 0x03 // 收发地址宽度设置 #define SETUP_RETR 0x04 // 自动重发功能设置 #define RF_CH 0x05 // 工作频率设置 #define RF_SETUP 0x06 // 发射速率、功耗功能设置 #define STATUS 0x07 // 状态寄存器 #define OBSERVE_TX 0x08 // 发送监测功能 #define CD 0x09 // 地址检测 #define RX_ADDR_P0 0x0A // 频道0接收数据地址 #define RX_ADDR_P1 0x0B // 频道1接收数据地址 #define RX_ADDR_P2 0x0C // 频道2接收数据地址 #define RX_ADDR_P3 0x0D // 频道3接收数据地址 #define RX_ADDR_P4 0x0E // 频道4接收数据地址 #define RX_ADDR_P5 0x0F // 频道5接收数据地址 #define TX_ADDR 0x10 // 发送地址寄存器 #define RX_PW_P0 0x11 // 接收频道0接收数据长度 #define RX_PW_P1 0x12 // 接收频道0接收数据长度 #define RX_PW_P2 0x13 // 接收频道0接收数据长度 #define RX_PW_P3 0x14 // 接收频道0接收数据长度 #define RX_PW_P4 0x15 // 接收频道0接收数据长度 #define RX_PW_P5 0x16 // 接收频道0接收数据长度 #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置 //************************************************************************************** //void Delay(unsigned int s); void inerDelay_us(unsigned char n); void init_NRF24L01(void); uint SPI_RW(uint uchar); uchar SPI_Read(uchar reg); void SetRX_Mode(void); uint SPI_RW_Reg(uchar reg, uchar value); uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars); uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); //*****************************************长延时***************************************** /*void Delay(unsigned int s) { unsigned int i; for(i=0; i //****************************************************************************************** uint bdata sta; //状态标志 ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /****************************************************************************************** /*延时函数 /******************************************************************************************/ void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } //**************************************************************************************** /*NRF24L01初始化 //***************************************************************************************/ void init_NRF24L01(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // Spi clock line init high SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 } /**************************************************************************************************** /*函数:uint SPI_RW(uint uchar) /*功能:NRF24L01的SPI写时序 /****************************************************************************************************/ uint SPI_RW(uint uchar) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (uchar & 0x80); // output 'uchar', MSB to MOSI uchar = (uchar << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. uchar |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(uchar); // return read uchar } /**************************************************************************************************** /*函数:uchar SPI_Read(uchar reg) /*功能:NRF24L01的SPI时序 /****************************************************************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /****************************************************************************************************/ /*功能:NRF24L01读写寄存器函数 /****************************************************************************************************/ uint SPI_RW_Reg(uchar reg, uchar value) { uint status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status uchar } /****************************************************************************************************/ /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数 /****************************************************************************************************/ uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status uchar for(uchar_ctr=0;uchar_ctr CSN = 1; return(status); // return nRF24L01 status uchar } /********************************************************************************************************* /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数 /*********************************************************************************************************/ uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; //SPI使能 status = SPI_RW(reg); for(uchar_ctr=0; uchar_ctr CSN = 1; //关闭SPI return(status); // } /****************************************************************************************************/ /*函数:void SetRX_Mode(void) /*功能:数据接收配置 /****************************************************************************************************/ void SetRX_Mode(void) { CE=0; // SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收 CE = 1; inerDelay_us(130); } /******************************************************************************************************/ /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) /*功能:数据读取后放如rx_buf接收缓冲区中 /******************************************************************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 if(RX_DR) // 判断是否接收到数据 { CE = 0; //SPI使能 SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志 return revale; } /*********************************************************************************************************** /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf) /*功能:发送 tx_buf中数据 /**********************************************************************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据 SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 CE=1; //置高CE,激发数据发送 inerDelay_us(10); } void delay(void) //误差 0us { unsigned char a,b,c; for(c=19;c>0;c--) for(b=20;b>0;b--) for(a=130;a>0;a--); } unsigned char code b[]=" Receive Temp : "; void main() { uchar RxBuf[32]; Initialize_LCD(); init_NRF24L01(); while(1) { SetRX_Mode(); if(nRF24L01_RxPacket(RxBuf)) { if(RxBuf[0]==1) { xianshi(5,1,'-'); xianshi(4,1,' '); } else { xianshi(5,1,RxBuf[0]); xianshi(4,1,'+'); } xianshi(6,1,RxBuf[1]); xianshi(7,1,RxBuf[2]); xianshi(8,1,'.'); xianshi(9,1,RxBuf[3]); } // delay(); ShowString(0,0,b); xianshi(10,1,0xdf); xianshi(11,1,'C'); } }
6个回答
帮你顶一个吧,希望有人看到
我相信没人能帮你,要学会自己找的错误,自己学会调试
成功了没有?我也想知道。你发送部分对不对?
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
140 浏览 0 评论
483 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
815 浏览 0 评论
1346 浏览 2 评论
804 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16903 浏览 31 评论
/9
GMT+8, 2025-12-2 14:42 , Processed in 0.924875 second(s), Total 83, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1441
