`小白一枚,刚刚接触单片机,请大神多多帮助。 设计图如下, ![]() 由于已经硬件实现,设计图还是不要改了。源程序如下 //--------------------------------------- //--------------------------------------- #include "reg51.h" ***it ST_ALE=P3^0; //START and ALE both connect to P3.0 ***it EOC=P3^1; //EOC connect to P3.1 ***it OE=P3^2; //OE conect to P3.2 ***it CLK=P3^3; //CLK connect to P3.3 unsigned char CHANNEL; //AD channel variable unsigned char LED[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //common cathode LED code unsigned char CHECK[4]={0xFE,0xFD,0xFB,0xF7}; //choose LED channel void delay(unsigned char time) { unsigned char i,j; for(i=time;i>0;i--) for(j=250;j>0;j--) ; } void display() { unsigned long temp; unsigned char DATA,digit[4]; unsigned int k,l; DATA=P1; //save AD data temp=DATA; //the temporary variable temp=temp*1000/51; //AD formula:D=A*5/255 digit[0]=temp/1000; //the thousands place digit[1]=temp%1000/100; //the hundreds place digit[2]=temp%1000%100/10; //the tens place digit[3]=temp%1000%100%10; //the ones place DATA=P2; //save P2 for(k=0;k<1000;k++) { /* lighten each LED and equal the below for loop P1=LED[digit[0]]+0x80; P2_4=0; P2_4=1; P1=LED[digit[1]]; P2_5=0; P2_5=1; P1=LED[digit[2]]; P2_6=0; P2_6=1; P1=LED[digit[3]]; P2_7=0; P2_7=1; */ for(l=0;l<4;l++) { P2=P2|0x0F; //avoid LED residual P0=LED[digit[l]]+0x80*(l==0); //LED code P2=DATA&CHECK[l]; //choose LED channel } } P2=DATA; //restore P2 } void main() { ST_ALE=0; //START and ALE default OE=0; //OE default TMOD=0x02; //T0 operate in mode 2 EA=1; //all interrupt enable ET0=1; //T0 interrupt enable TR0=1; //T0 run while(1) { ST_ALE=1; //lock the AD channel address ST_ALE=0; //AD run while(EOC==0); //wait until AD over OE=1; //enable to transmit AD data display(); //view the AD result and diaplay LED } } void T1_TIME() interrupt 1 using 0 { CLK=~CLK; //CLK 500 kHz } 用proteus仿真时发现,数码管上显示的数值和滑动变阻器上数值不同,而且差别较大,所以还请大神帮忙看看到底是哪里出错了,跪求指教啊!!!!! ` |
3个回答
回帖奖励 +2 分积分 |
你试试这种算法:你试试这种算法:
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1267 浏览 3 评论
2477 浏览 0 评论
2913 浏览 0 评论
Protues中自己封装的芯片元件无Program File、Clock Frequency选项怎么解决,求求大神了!
4699 浏览 1 评论
基于51单片机的车辆倒车雷达报警系统,HC-SR04超声波测距,全套资料
1048 浏览 0 评论
GMT+8, 2024-9-11 18:10 , Processed in 0.750749 second(s), Total 86, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
