扫一扫,分享给好友
函数功能 通过串口向EEPROM中写入数据然后读出数据显示到串口调试工具上,串口的收发功能已经调试验证过,但是向eeprom中写和读不知道错误在哪里。 */ #include #include #define uchar unsigned char #define con_read 0xa1 //器件地址以及读取操作,0xa1即为1010 0001B #define con_write 0xa0 //器件地址以及写入操作,0xa1即为1010 0000B #define len 8 //数据长度 ***it SDA=P2^0; //将串行数据总线SDA位定义在为P2.0引脚 ***it SCL=P2^1; //将串行时钟总线SDA位定义在为P2.1引脚 uchar inbuf[len]; //存储数据 uchar outbuf[len]; int count = 0; uchar flag = 0;//数据校验 void delay(void) //延时 { _nop_(); _nop_(); _nop_(); _nop_(); } void iic_init(void) //IIC初始化 { SCL = 1; SDA = 1; } void uart_init(void) { SCON = 0x50; //串口通信模式1 TMOD = 0x20; //定时器1,模式2 TH1 = 0xfd; //波特率9600 TL1 = 0xfd; TR1 = 1; ES = 1; EA = 1; } void iic_start(void) //开始 { SCL = 1; SDA = 1; delay(); SDA = 0; delay(); SCL = 0; } void iic_stop(void) //结束 { SCL = 1; SDA = 0; delay(); SDA = 1; delay(); } void iic_writebyte(uchar ch) //写一字节数据 { uchar i; for (i=0;i<8;i++) { SCL = 0; delay(); SDA = (bit)(ch&0x80); delay(); SCL = 1; delay(); ch <<= 1; } SCL = 0; SDA = 1; //发送完一字节数据后,将数据线电平拉高,等待应答位 delay(); } bit iic_ask(void) //应答 { int i=0; uchar ask; SCL = 1; delay(); ask = (bit)SDA; while ((ask==1)&&(i<100))i++; SCL = 0; delay(); return ask; } void iic_write(uchar add,uchar dat) //向EEPROM中写数据 { iic_start(); iic_writebyte(con_write);//con_write 写控制 iic_ask(); iic_writebyte(add);//地址 iic_ask(); iic_writebyte(dat);//数据 iic_ask(); iic_stop(); delay(); } uchar iic_readbyte(void) //读一个字节数据并发送非应答 { uchar x; int i; SCL = 0; delay(); SDA = 1; delay(); for (i=0;i<8;i++) { SCL = 1; delay(); x <<= 1; x |= (uchar)SDA; SCL = 0; delay(); } SCL = 0; SDA = 1; delay(); SCL = 1; delay(); SCL = 0; return x; } uchar iic_read(uchar add) //从EEPROM中读数据 { uchar x; iic_start(); iic_writebyte(con_write); iic_ask(); iic_writebyte(add); iic_ask(); iic_start(); iic_writebyte(con_read); iic_ask(); x = iic_readbyte(); iic_stop(); return x; } void delaynms(uchar n) //延时 { uchar i,j; for(i=0;i } void serial() interrupt 4 //串口中断 读串口发来的数据 { if (RI) { RI = 0; inbuf[count] = SBUF; count++; if (count == len) { flag = 1; count = 0; } } } void send_char(uchar ch) //向串口发送一个字节数据 { SBUF = ch; while (!ti); TI = 0; } void send_string(uchar *str) //向串口发送一串数据 { int i; for (i=0;i send_char(*(str+i)); } } void main(void) { uchar i; //EEPROM中地址 uart_init(); //串口初始化 iic_init(); //iic总线初始化 while (1) { if (flag == 1) //从串口中读取数据完毕则flag置1 { for (i=0;i iic_write(i,inbuf[i]); //将从串口接收到的数据写到EEPROM中 } delaynms(200); for (i=0;i outbuf[i] = iic_read(i); //将EEPROM中的数据读出 } send_string(outbuf); //将EEPROM中读出的数据发送到串口 delaynms(200); flag = 0; //标志位清零 } } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
140 浏览 0 评论
483 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
815 浏览 0 评论
1346 浏览 2 评论
804 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16903 浏览 31 评论
浏览过的版块 |
/9
GMT+8, 2025-12-2 15:56 , Processed in 0.603138 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1590
