扫一扫,分享给好友
#include
#include "ds1302_51.h" #include "led.h" #include "onekey51.h" #define K_SET P1_0 #define K_ADD P1_1 #define K_SUB P1_2 #define K_EXIT P1_3 uchar /*dis_buf[]={0,0,0,0,0,0},*/ tmp_buf [6],pos=0,i_set,count_blk,count_500ms=0,c_rdkey=0; bit set_flag=0,blink=1,point_flag=1,f_rdkey=0; void timerInit() { TMOD&=~T0_M1_; TMOD|=T0_M0_; TH0=0xf7; TL0=0x00; ET0=1; EA=1; TR0=1; } void ISR_T0() interrupt TF0_VECTOR { TH0=0xf7; TL0=0x00; ds1302_read_time(); if(++count_500ms==200) { count_500ms=0; point_flag^=1; } if(set_flag) { if(++count_blk==100) { count_blk=0; blink^=1; } } P2=0x00; if(!set_flag) P0=led[dis_buf[pos]]; else { if(pos!=i_set||blink) P0=led[tmp_buf[pos]]; else P0=0xff; } if(!set_flag && point_flag && pos==2) { P0&=0x7f; } if(pos==4 || (set_flag && pos==2)) P0&=0x7f; P2=1< pos=0; if(++c_rdkey==4) { c_rdkey=0; f_rdkey=1; } } void TimeAdd() { uchar tmp; swich(i_set) { case 0: case 2: tmp=10; break; case 1: case 3: tmp=6; break; case 4: if(tmp_buf[5]<2) tmp=10; else tmp=4; break; case 5: if(tmp_buf[4]<4) tmp=3; else tmp=2; break; } if(++tmp_buf[i_set]==tmp) tmp_buf[i_set]=0; } void TimeSub() { uchar tmp; swich(i_set) { case 0: case 2: tmp=9; break; case 1: case 3: tmp=5; break; case 4: if(tmp_buf[5]<2) tmp=9; else tmp=3; break; case 5: if(tmp_buf[4]<4) tmp=2; else tmp=1; break; } if(tmp_buf[i_set]==0) tmp_buf[i_set]=tmp; else tmp_buf[i_set]--; } void SaveSet() { uchar h,m,s; s=(tmp_buf[1]<<4) | tmp_buf[0]; m=(tmp_buf[3]<<4) | tmp_buf[2]; h=(tmp_buf[5]<<4) | tmp_buf[4]; ds1302_set_time(h,m,s); } void main() { uchar temp,i; TimerInit(); DS1302Init(); while(1) { if(f_rdkey) { f_rdkey=0; if(!set_flag && Read1Key(0,K_SET)) { i_set=5; count_blk=0; for(i=0;i<6;i++) tmp_buf[i]=dis_buf[i]; set_flag=1; } if(set_flag) { if(Read1Key(0,K_SET)) { if(i_set--==0) i_set=5; } if(Read1Key(1,K_ADD)) { TimeAdd(); } if(Read1Key(2,K_SUB)) TimeSub(); } if(temp==Read1Key(3,K_EXIT)) { if(temp==2) SaveSet(); set_flag=0; } } } } }
11个回答
Build target '目标 1'
compiling DS1302.c... DS1302.c(2): warning C318: can't open file 'ds1302_51.h' DS1302.c(3): warning C318: can't open file 'led.h' DS1302.c(4): warning C318: can't open file 'onekey51.h' DS1302.C(10): error C129: missing ';' before 'bit' 目标未创建 |
你头文件都放在哪里了?如果是#include "ds1302_51.h",这样包含的话,就需要把头文件放在你当前的工程文件中,或者放在keil根目录的keilc51inc文件夹中;或者就是直接包含头文件的路径如:
#include "c:xxxxxxxxxxx.h";你可以参考一下; 你还有error呢; |
虽然我还是不懂,但还是谢谢你了。 |
楼上说得对,把'ds1302_51.h等头文件包含在该工程文件的文件夹里,再试试吧!
加载。h的头文件
tu502201 发表于 2012-12-19 18:53 文件 不全 keil C 加载的文件中没有,或是没找到该文件 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
234 浏览 0 评论
514 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
826 浏览 0 评论
1366 浏览 2 评论
814 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16907 浏览 31 评论
/9
GMT+8, 2025-12-2 22:42 , Processed in 0.782008 second(s), Total 96, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4287
