library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity transfer is
generic(framlent:integer:=8);
port(bclkt,resett,xmit_cmd_p:in std_logic; --????/????
txdbuf:in std_logic_vector(7 downto 0):="11001010";
txd:out std_logic;
txd_done:out std_logic);
end transfer;
architecture behavioral of transfer is
type states is (x_idle,x_start,x_wait,x_shift,x_stop); --??????
signal state:states:=x_idle;
signal tcnt:integer:=0;
begin
process(bclkt,resett,xmit_cmd_p,txdbuf) --?????????
variable xcnt16:std_logic_vector(4 downto 0):="00000"; --??????
variable xbitcnt:integer:=0;
variable txds:std_logic;
begin
if resett='1'then
state<=x_idle;txd_done<='0';txds:='1';
elsif rising_edge(bclkt)then
case state is
when x_idle=>if xmit_cmd_p='1'then state<=x_start;txd_done<='0';
else state<=x_idle; --状态1,等待数据帧发送命令
end if;
when x_start=>if xcnt16>="01111" then state<=x_wait;xcnt16:="00000";
else xcnt16:=xcnt16+1;txds:='0';state<=x_start;
end if; --状态2,发送信号至起始位
when x_wait=>if xcnt16>="01110"then
if xbitcnt=framlent then state<=x_stop;xbitcnt:=0;
else state<=x_shift;
end if;
xcnt16:="00000";
else xcnt16:=xcnt16+1;state<=x_wait;
end if; --状态3,等待状态
when x_shift=>txds:=txdbuf(xbitcnt);xbitcnt:=xbitcnt+1;state<=x_wait;
--状态4,将待发数据并串转换
when x_stop=>if xcnt16>="01111"then
if xmit_cmd_p='0'then state<=x_idle;xcnt16:="00000";
else xcnt16:=xcnt16;state<=x_stop;
end if; txd_done<='1';
else xcnt16:=xcnt16+1;txds:='1';state<=x_stop;
end if; --状态5,停止位发送状态
when others=>state<=x_idle;
end case;
end if;
txd<=txds;
end process;
end behavioral;
