#include //52系列单片机头文件 #define uchar unsigned char #define uint unsigned int ***it dula=P2^6; //申明U1锁存器的锁存端 ***it wela=P2^7; //申明U2锁存器的锁存端 uchar code table[]={ 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; void delayms(uint xms) { uinti,j; for(i=xms;i>0;i--) //i=xms即延时约xms毫秒 for(j=110;j>0;j--); } void display(uchar num) { P0=table[num];//显示函数只送段选数据 dula=1; dula=0; } void matrixkeyscan() //矩阵键盘扫描函数 { uchartemp,key; P3=0xfe; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xee: key=0; break; case 0xde: key=1; break; case 0xbe: key=2; break; case 0x7e: key=3; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } P3=0xfd; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xed: key=4; break; case 0xdd: key=5; break; case 0xbd: key=6; break; case 0x7d: key=7; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } P3=0xfb; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xeb: key=8; break; case 0xdb: key=9; break; case 0xbb: key=10; break; case 0x7b: key=11; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } P3=0xf7; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xe7: key=12; break; case 0xd7: key=13; break; case 0xb7: key=14; break; case 0x77: key=15; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } } void main() { P0=0; //关闭所有数码管段选 dula=1; dula=0; P0=0xc0;//位选中所有数码管 wela=1; wela=0; while(1) { matrixkeyscan();//不停调用键盘扫描程序 } } #include //52系列单片机头文件 #define uchar unsigned char #define uint unsigned int ***it dula=P2^6; //申明U1锁存器的锁存端 ***it wela=P2^7; //申明U2锁存器的锁存端 uchar code table[]={ 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; void delayms(uint xms) { uinti,j; for(i=xms;i>0;i--) //i=xms即延时约xms毫秒 for(j=110;j>0;j--); } void display(uchar num) { P0=table[num];//显示函数只送段选数据 dula=1; dula=0; } void matrixkeyscan() //矩阵键盘扫描函数 { uchartemp,key; P3=0xfe; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xee: key=0; break; case 0xde: key=1; break; case 0xbe: key=2; break; case 0x7e: key=3; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } P3=0xfd; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xed: key=4; break; case 0xdd: key=5; break; case 0xbd: key=6; break; case 0x7d: key=7; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } P3=0xfb; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xeb: key=8; break; case 0xdb: key=9; break; case 0xbb: key=10; break; case 0x7b: key=11; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } P3=0xf7; temp=P3; temp=temp&0xf0; if(temp!=0xf0) { delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xe7: key=12; break; case 0xd7: key=13; break; case 0xb7: key=14; break; case 0x77: key=15; break; } while(temp!=0xf0) { temp=P3; temp=temp&0xf0; } display(key); } } } void main() { P0=0; //关闭所有数码管段选 dula=1; dula=0; P0=0xc0;//位选中所有数码管 wela=1; wela=0; while(1) { matrixkeyscan();//不停调用键盘扫描程序 } }
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2521 浏览 0 评论
5013 浏览 0 评论
PROTUES仿真no model specified for adc0809,谁有ADC0809的model?
17528 浏览 1 评论
单片机应用技术的ISIS professional电路设置仿真老是报错怎么办
17838 浏览 0 评论
21084 浏览 3 评论
/9
GMT+8, 2025-12-1 19:22 , Processed in 0.802675 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3537
