效果图如下: 全部显示效果 遗憾的是没有小数点 (原文件名:DSC_1779.jpg) 显示数字 (原文件名:DSC_1792.jpg) 背面 (原文件名:DSC_1794.jpg) HT1622 (原文件名:DSC_1796.jpg) 程序如下: /***************************************************************** HMS17AN段码液晶屏测试程序 Drive HT1622 CPU MSP430G2454 @ 1MHz 第十六位 第三十位 液晶屏内容: 8 8888888888888 8 第二排 8 8888888888888 8 第一排 第一位 第十五位 *****************************************************************/ #include "msp430g2452.h" #define SET 1 #define RESET 0 #define _ADD_STR(a, b) a##b #define ADD_STR(a, b) _ADD_STR(a, b) /* PxIN */ #define _IO_PORT_IN(PORT) (PORT##IN) #define GPIO_READ_BITS(PORT, BIT) ( (_IO_PORT_IN(PORT) & BIT) ? (SET):(RESET)) #define GOIO_READ_PORTS(PORT) ( _IO_PORT_IN(PORT) ) /* PxOUT */ #define _IO_PORT_OUT(PORT) (PORT##OUT) #define GPIO_SET_BITS(PORT, BIT) ( ( _IO_PORT_OUT(PORT) ) |= (BIT) ) #define GPIO_RESET_BITS(PORT, BIT) ( ( _IO_PORT_OUT(PORT) ) &= ~(BIT) ) /* PxDIR */ #define _IO_PORT_DIR(PORT) (PORT##DIR) #define GPIO_OUTPUT_DIR(PORT, BIT) ( ( _IO_PORT_DIR(PORT) ) |= (BIT) ) #define GPIO_INPUT_DIR(PORT, BIT) ( ( _IO_PORT_DIR(PORT) ) &= ~(BIT) ) /* PxIE */ #define _IO_PORT_IE(PORT) (PORT##IE) #define GPIO_ENABLE_IRQ(PORT, BIT) ( ( _IO_PORT_IE(PORT) ) |= (BIT) ) #define GPIO_DISABLE_IRQ(PORT, BIT) ( ( _IO_PORT_IE(PORT) ) &= ~(BIT) ) /* PxSEL */ #define _IO_PORT_SEL(PORT) (PORT##SEL) #define GPIO_PORT_FUNC(PORT, BIT) ( ( _IO_PORT_SEL(PORT) ) |= (BIT) ) #define GPIO_MULti_FUNC(PORT, BIT) ( ( _IO_PORT_SEL(PORT) ) &= ~(BIT) ) /* ------------------ High layer function ----------------------------------- */ #define TEST_BIT(x) ( GPIO_READ_BITS( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) ) #define SET_BIT(x) ( GPIO_SET_BITS( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) ) #define CLR_BIT(x) ( GPIO_RESET_BITS( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) ) #define BIT_OUT(x) ( GPIO_OUTPUT_DIR( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) ) #define BIT_IN(x) ( GPIO_INPUT_DIR( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) ) #define EINT_BIT(x) ( GPIO_ENABLE_IRQ( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) ) #define DINT_BIT(x) ( GPIO_DISABLE_IRQ( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) ) /* eg. */ /* #define HC165_SCLK_PORT P1 // 使用的是P1口 */ /* #define HC165_SCLK_BIT BIT5 // BIT5位 */ /* BIT_OUT( HC165_SCLK ); // 设置P1.5位输出 */ unsigned char DIS_BUF[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18};//显示缓冲区 //段码表 0 1 2 3 4 5 6 7 8 9 A b C d E F - _ 空 const unsigned char DIS[]={0xBF,0x06,0x7C,0x5E,0xC6,0xDA,0xFA,0x0E,0xFE,0xDE,0xEE,0xF2,0xB8,0x76,0xF8,0xE8,0x40,0x10,0x00}; /***************************************************************** HT1622 指令宏定义 *****************************************************************/ #define SYSDIS 0X00 // 关振系统荡器和LCD偏压发生器 #define SYSEN 0X01 // 打开系统振荡器 #define LCDOFF 0X02 // 关LCD偏压 #define LCDON 0X03 // 打开LCD偏压 #define TIMEDIS 0x04 // 禁止时基输出 #define WDTDIS 0x05 // 禁止WDT超时标志输出 #define TIMEREN 0x08 // 启用时基输出 #define WDTEN 0x0D // 启用WDT超时标志输出 #define TONEOFF 0x0F // 关闭声音输出 #define CLRTIMER 0x05 // 清除时基发生器的内容 #define CLRWDT 0x0F // 清除WDT的内容 #define RC32K 0x18 // 系统时钟源,片上RC振荡器 #define EXT32K 0x1C // 系统时钟源,外部时钟源 #define TONE4K 0x40 // 音的输出频率:4kHz的 #define TONE2K 0x60 // 音的输出频率:2kHz的 #define IRQDIS 0x80 // 禁止IRQ输出 #define IRQEN 0x88 // 启用IRQ输出 #define F1 0xA0 // 时基时钟输出:2Hz WDT的超时标志后:4s #define F2 0xA1 // 时基时钟输出:2Hz WDT的超时标志后:2s #define F4 0xA2 // 时基时钟输出:4Hz WDT的超时标志后:1s #define F8 0xA3 // 时基时钟输出:8Hz WDT的超时标志后:1/2s #define F16 0xA4 // 时基时钟输出:16Hz WDT的超时标志后:1/4s #define F32 0xA5 // 时基时钟输出:32Hz WDT的超时标志后:1/8s #define F64 0xA6 // 时基时钟输出:64Hz WDT的超时标志后:1/16s #define F128 0xA7 // 时基时钟输出:128Hz WDT的超时标志后:1/32s #define TEST 0xE0 // 测试模式下,用户不使用。 #define NORMAL 0xE3 // 普通模式 /***************************************************************** 管脚分配 CS P1.0 WR P1.1 DAT P1.2 *****************************************************************/ #define HT1621_CS_PORT P1 //HT1621使能引脚 #define HT1621_CS_BIT BIT0 //HT1621使能引脚 #define HT1621_WR_PORT P1 //HT1621时钟引脚 #define HT1621_WR_BIT BIT1 //HT1621时钟引脚 #define HT1621_DAT_PORT P1 //HT1621数据引脚 #define HT1621_DAT_BIT BIT2 //HT1621数据引脚 /***************************************************************** HT1622 底层驱动 Data 数据 Length 数据长度 *****************************************************************/ void Write_HT1622_Byte(unsigned char Data,unsigned char Length) { unsigned char i,Temp=0x80; for (i=0;i CLR_BIT ( HT1621_WR ); //“写”时钟置0 if (Data&Temp) SET_BIT ( HT1621_DAT );//数据线置1 else CLR_BIT ( HT1621_DAT );//数据线置0 Temp>>=1; //准备下一位 SET_BIT ( HT1621_WR ); //“写”时钟置1 } } /***************************************************************** HT1622写入数据函数 Address 写数据地址 Data 数据 *****************************************************************/ void Write_HT1622_Data(unsigned char Address,unsigned char Data) { CLR_BIT ( HT1621_CS ); //片选置0 Address <<= 2; //将实际地址挪到高位 Data <<= 4; //将实际数据挪到高位 Write_HT1622_Byte(0xA0,3); //写入写数据的ID 101 高3位有效 Write_HT1622_Byte(Address,6);//写入6个位初始地址 高6位有效 Write_HT1622_Byte(Data,4); //写入4个位数据 高4位有效 SET_BIT ( HT1621_CS ); //片选置1 } /***************************************************************** //HT1622写命令函数 Command 命令 *****************************************************************/ void Write_HT1622_Command(unsigned char Command) { CLR_BIT ( HT1621_CS ); //片选置0 Write_HT1622_Byte(0x80,3); //写入命令的ID:100 Write_HT1622_Byte(Command,8);//写入实际命令的高8位(CMD.):C8-C1 SET_BIT ( HT1621_DAT ); //|写入一个“1”即手册上所指“无关位”的那一个数据位 CLR_BIT ( HT1621_WR ); //| _NOP();_NOP();_NOP(); //| SET_BIT ( HT1621_WR ); //| SET_BIT ( HT1621_CS ); //片选置1 } /***************************************************************** 显示数字函数 *Data显示内容指针 Address 显示首位置 Length内容长度 *****************************************************************/ void Display(unsigned char *Data,unsigned char Address,unsigned char Length) { unsigned char i = 0,Temp=0x0F; unsigned char ADDH,ADDL; for(;i Temp=DIS[*Data]; //数据解析 ADDL = Address*2; //低4位地址解析 ADDL = ADDL*2+2-(ADDL/31)*59; //低4位地址解析 Write_HT1622_Data(ADDL,Temp&0x0F);//写低4位数据 ADDH = Address*2-1; //高4位地址解析 ADDH = ADDH*2+2-(ADDH/31)*59; //高4位地址解析 Temp>>=4; //高4位数据解析 Write_HT1622_Data(ADDH,Temp&0x0F);//写高4位数据 Data ++; //显示数据指针增一 Address ++; //显示地址增一 } } /***************************************************************** 主函数 上下两排显示 0到E *****************************************************************/ void main(void) { WDTCTL = WDTPW + WDTHOLD; //关看门狗 BIT_OUT ( HT1621_DAT ); //|IO口初始化 BIT_OUT ( HT1621_CS ); //| BIT_OUT ( HT1621_WR ); //| SET_BIT ( HT1621_CS ); //| SET_BIT ( HT1621_WR ); //| SET_BIT ( HT1621_DAT ); //| Write_HT1622_Command(SYSDIS);//关闭系统振荡器和LCD驱动 Write_HT1622_Command(SYSEN); //打开系统振荡器 Write_HT1622_Command(LCDOFF);//关闭LCD显示 Write_HT1622_Command(LCDON); //打开LCD显示 Display(DIS_BUF,1,15); //显示0到E 第一排 Display(DIS_BUF,16,15); //显示0到E 第二排 while(1); } |
10 个讨论
只有小组成员才能发言,加入小组>>
2970个成员聚集在这个小组
加入小组2754 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
3258 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2293 浏览 1 评论
4736 浏览 1 评论
2511 浏览 1 评论
1032浏览 3评论
3258浏览 2评论
2754浏览 1评论
1160浏览 0评论
GMT+8, 2024-10-3 11:21 , Processed in 1.465876 second(s), Total 68, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
