<p>综合词汇: </font>
<table height="0" width="0" align="left"></tr></td><!--script src="/ad/include/advert.asp?loca
tion=INFO006"--><!--/script-->
<script src="/ASNew/Include/A_Service.asp?AS_PID=631001"></script>
</td></tr>
<tbody></tbody></table><font face="Verdana">(更多资料,请点击:www.chinaicmart.com www.seekic.com www.tradeofic.com)</font>
<p>1、 印制
电路:printed circuit </font></p>
<p>2、 印制线路:printed wiring </font></p>
<p>3、 印制板:printed board </font></p>
<p>4、 印制板电路:printed circuit board (
PCB) </font></p>
<p>5、 印制线路板:printed wiring board(pwb) </font></p>
<p>6、 印制
元件:printed component </font></p>
<p>7、 印制接点:printed contact </font></p>
<p>8、 印制板装配:printed board assembly </font></p>
<p>9、 板:board </font></p>
<p>10、 单面印制板:single-sided printed board(ssb) </font></p>
<p>11、 双面印制板:double-sided printed board(dsb) </font></p>
<p>12、 多层印制板:mulitlayer printed board(mlb) </font></p>
<p>13、 多层印制电路板:mulitlayer printed circuit board </font></p>
<p>14、 多层印制线路板:mulitlayer prited wiring board </font></p>
<p>15、 刚性印制板:rigid printed board </font></p>
<p>16、 刚性单面印制板:rigid single-sided printed borad </font></p>
<p>17、 刚性双面印制板:rigid double-sided printed borad </font></p>
<p>18、 刚性多层印制板:rigid multilayer printed board </font></p>
<p>19、 挠性多层印制板:flexible multilayer printed board </font></p>
<p>20、 挠性印制板:flexible printed board </font></p>
<p>21、 挠性单面印制板:flexible single-sided printed board </font></p>
<p>22、 挠性双面印制板:flexible double-sided printed board </font></p>
<p>23、 挠性印制电路:flexible printed circuit (
FPC) </font></p>
<p>24、 挠性印制线路:flexible printed wiring </font></p>
<p>25、 刚性印制板:flex-rigid printed board, rigid-flex printed board </font></p>
<p>26、 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed </font></p>
<p>27、 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board </font></p>
<p>28、 齐平印制板:flush printed board </font></p>
<p>29、 金属芯印制板:metal core printed board </font></p>
<p>30、 金属基印制板:metal base printed board </font></p>
<p>31、 多重布线印制板:mulit-wiring printed board </font></p>
<p>32、 陶瓷印制板:ceramic substrate printed board </font></p>
<p>33、 导电胶印制板:electroconductive paste printed board </font></p>
<p>34、 模塑电路板:molded circuit board </font></p>
<p>35、 模压印制板:stamped printed wiring board </font></p>
<p>36、 顺序层压多层印制板:sequentially-laminated multilayer </font></p>
<p>37、 散线印制板:discrete wiring board </font></p>
<p>38、 微线印制板:
micro wire board </font></p>
<p>39、 积层印制板:buile-up printed board </font></p>
<p>40、 积层多层印制板:build-up mulitlayer printed board (bum) </font></p>
<p>41、 积层挠印制板:build-up flexible printed board </font></p>
<p>42、 表面层合电路板:su
RFace laminar circuit (slc) </font></p>
<p>43、 埋入凸块连印制板:b2it printed board </font></p>
<p>44、 多层膜基板:multi-layered film substrate(mfs) </font></p>
<p>45、 层间全内导通多层印制板:alivh multilayer printed board </font></p>
<p>46、 载
芯片板:chip on board (cob) </font></p>
<p>47、 埋电阻板:buried resistance board </font></p>
<p>48、 母板:mother board49、 子板:daughter board </font></p>
<p>50、 背板:backplane </font></p>
<p>51、 裸板:bare board </font></p>
<p>52、 键盘板夹心板:copper-invar-copper board </font></p>
<p>53、 动态挠性板:dynamic flex board </font></p>
<p>54、 静态挠性板:static flex board </font></p>
<p>55、 可断拼板:break-away planel </font></p>
<p>56、
电缆:cable </font></p>
<p>57、 挠性扁平电缆:flexible flat cable (
FFC) </font></p>
<p>58、 薄膜
开关:membrane switch </font></p>
<p>59、 混合电路:hybrid circuit </font></p>
<p>60、 厚膜:thick film </font></p>
<p>61、 厚膜电路:thick film circuit </font></p>
<p>62、 薄膜:thin film </font></p>
<p>63、 薄膜混合电路:thin film hybrid circuit </font></p>
<p>64、 互连:interconnection </font></p>
<p>65、 导线:conductor trace line </font></p>
<p>66、 齐平导线:flush conductor </font></p>
<p>67、
传输线:transmission line </font></p>
<p>68、 跨交:crossover </font></p>
<p>69、 板边插头:edge-board contact </font></p>
<p>70、 增强板:stiffener </font></p>
<p>71、 基底:substrate </font></p>
<p>72、 基板面:real estate </font></p>
<p>73、 导线面:conductor side </font></p>
<p>74、 元件面:component side </font></p>
<p>75、
焊接面:solder side </font></p>
<p>76、 印制:printing </font></p>
<p>77、 网格:grid </font></p>
<p>78、 图形:pattern </font></p>
<p>79、 导电图形:conductive pattern </font></p>
<p>80、 非导电图形:non-conductive pattern </font></p>
<p>81、 字符:legend </font></p>
<p>82、 标志:mark <br/></p>
