在快速发展的无线通信领域,每一代技术的革新都推动着行业向更高效、更稳定、更智能的方向发展。今天,我们要为大家介绍的是一款来自康锡通信科技(KANGXI Communication Technologies)的杰出产品——KCT8539SD-1,这是一款专为5GHz WLAN系统设计的中高功率射频前端模组,它集成了IEEE 802.11a/n/ac/ax标准所需的关键射频功能,以其卓越的性能和高度集成的设计,成为了Wi-Fi 6时代的重要推动者。 KCT8570HE是一款工作频段为 5.15-5.85GHz 的高集成射频前端模组。此产品集成了IEEE 802.11 a/n/ac/ax WLAN系统所需的关键射频功能,如高效高线性功率放大器(PA)、包含旁路滤波器(BP)的低噪声放大器(LNA) 、LO抑制和谐波滤波器,并且内置直流电压功率检测以及耦合端射频功率检测。KCT8570HE 是一款优秀的 Wi-Fi 6 射频前端器件。 The KCT8570HE is a highly integrated RF front-end module operating in the 5.15-5.85GHz band. This product integrates key RF functions required for IEEE 802.11a /n/ac/ax WLAN systems, such as high efficiency high linear power amplifier (PA), low noise amplifier (LNA) with bypass filter (BP), LO rejection and harmonic filter, with built-in DC voltage power detection and coupled end RF power detection. The KCT8570HE is an excellent Wi-Fi 6 RF front-end device. 高度集成,精简设计 KCT8570HE将功率放大器、低噪声放大器、旁路滤波器、LO抑制和谐波滤波器以及直流电压功率检测和耦合端射频功率检测等关键射频功能集成于一个3mm*3mm的超小封装内,大大简化了外部电路的设计,降低了生产成本,提高了生产效率和产品的可靠性。 Highly integrated, streamlined design The KCT8570HE integrates key RF functions such as power amplifier, low noise amplifier, bypass filter, LO suppression and harmonic filter, DC voltage power detection and coupled end RF power detection in a 3mm*3mm ultra-small package, which greatly simplifies the design of external circuits and reduces production costs. Improve production efficiency and product reliability. 卓越射频性能,稳定传输 KCT8570HE的功率放大器具有高效率和高线性的特点,能够在保证输出功率的同时,降低对邻近信道的干扰。其低噪声放大器则提供了低噪声系数和高增益,从而提高了接收信号的灵敏度。此外,内置的直流电压功率检测和耦合端射频功率检测功能,能够实时监测输出功率和射频信号强度,确保射频性能的稳定性和准确性。 Excellent RF performance, stable transmission The KCT8570HE power amplifier has the characteristics of high efficiency and high linearity, which can ensure the output power while reducing the interference to neighboring channels. Its low noise amplifier provides a low noise figure and high gain, which improves the sensitivity of the received signal. In addition, the built-in DC voltage power detection and coupled end RF power detection function can monitor the output power and RF signal strength in real time to ensure the stability and accuracy of RF performance. 完整匹配方案,提升效率 KCT8570HE提供了完整的输入输出端匹配方案,确保了射频信号在传输过程中的稳定性和一致性。这种匹配方案不仅提高了射频信号的传输效率,还降低了信号的反射和损耗,从而提高了整个系统的性能。 Complete matching scheme to improve efficiency KCT8570HE provides a complete input and output matching scheme to ensure the stability and consistency of RF signals during transmission. This matching scheme not only improves the transmission efficiency of the RF signal, but also reduces the reflection and loss of the signal, thus improving the performance of the whole system. 强大静电防护,安全可靠 所有引脚均通过了ESD静电防护标准测试,确保了产品在使用过程中的安全性和可靠性。即使在恶劣的静电环境下,KCT8570HE也能够保持稳定的性能,为用户提供持续不断的射频信号传输服务。**** Strong electrostatic protection, safe and reliable All pins have passed the ESD electrostatic protection standard test to ensure the safety and reliability of the product during use. Even in harsh electrostatic environments, the KCT8570HE can maintain stable performance and provide users with continuous RF signal transmission services. 极简外部电路,降低成本 由于KCT8570HE的高度集成设计和完整的输入输出匹配方案,使得外部电路的设计变得非常简单。用户只需要根据产品手册中的推荐电路进行连接,即可轻松实现射频信号的传输和接收。这种极简的外部电路匹配方案不仅降低了设计成本,还提高了系统的可靠性和稳定性。**** Minimal external circuitry reduces costs Due to the highly integrated design and complete input/output matching scheme of the KCT8570HE, the design of the external circuit is very simple. Users only need to connect according to the recommended circuit in the product manual, which can easily achieve the transmission and reception of RF signals. This minimalist external circuit matching scheme not only reduces the design cost, but also improves the reliability and stability of the system. 产品规格 product standard**** 工作频段:5.15-5.85GHz Operating frequency band: 5.15-5.85GHz 传输增益:30.5dB(在5V电压下) Transmission gain: 30.5dB (at 5V voltage) 接收增益:16.5dB(在5V电压下) Receive gain: 16.5dB (at 5V voltage) 噪声系数:1.8dB(在5V电压下) Noise factor: 1.8dB (at 5V voltage) 输出功率output power**** : +16.5dBm @ -43dB DEVM, HE160/MCS11, 5V +20.5dBm @ -40dB DEVM, HE160/MCS11, 5V +22.5dBm @ -35dB DEVM, VHT80/MCS9, 5V +23.5dBm @ -30dB DEVM, HT20/MCS7, 5V 封装形式 encapsulation mode:QFN-16L,3mm x 3mm x 0.75mm 控制逻辑:简单的低电压控制逻辑,支持多种工作模式切换 Control logic: simple low voltage control logic, support a variety of working mode switching 环保认证:通过ROHS和REACH环保认证**** Environmental certification: ROHS and REACH environmental certification |
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
804 浏览 0 评论
TIKOOL太酷信息无线内部通话系统允许多个人一起讲话,频道内会不会很吵?
798 浏览 0 评论
各位大佬好,我用vco替代rtc6705,得到的图像不稳定是怎么回事啊?
1378 浏览 2 评论
1905 浏览 0 评论
1106 浏览 1 评论
GMT+8, 2024-12-22 02:05 , Processed in 0.420962 second(s), Total 35, Slave 29 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
